Old 04-01-2016, 03:55 AM   #1
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
OEM Crash Bolts, top and bottom
Anyone running OEM crash bolts top and bottom on the track?
I'd be interested to hear your observations and opinions.
I've run crash bolts in top hole only (-1.3°) for 2 years (28 track days) but I'd like a bit more camber and I don't want to go the coilover route.
Fish Eagle is offline   Reply With Quote
Old 04-01-2016, 06:50 AM   #2
scirocco78
Drives: Scion FRS
The OEM bottom bolt is the same as the crash bolt you put in the top.
scirocco78 is offline   Reply With Quote
Old 04-01-2016, 08:11 AM   #3
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Oh, I didn't know that.
Thanks. So I guess that plan won't work...
Old 04-01-2016, 10:38 AM   #4
ka-t_240
You could look into aftermarket tophats.
Are you still on stock struts and springs?
ka-t_240 is offline   Reply With Quote
Old 04-01-2016, 10:39 AM   #5
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
Or just use aftermarket camber bolts in addition to the OEM crash bolts.
jawn is offline   Reply With Quote
The Following User Says Thank You to jawn For This Useful Post:
funwheeldrive (04-04-2016)
Old 04-01-2016, 10:54 AM   #6
flais
Band
flais's Avatar
Drives: Asphalt FR-S
Yes, I'm running SPC bolts top and bottom with the Swift Spec-R springs, aligned to -2.5 degrees camber. It's probably not the best setup long term since the overall bolt diameter is lower than normal, but at least they are high grade bolts.
Since moving from just lower camber bolts to both upper and lower in october, I've only done 3 track days, 4 time attacks, and 2 autocrosses. One of the time attacks I went sideways into the curbing hard enough to fold in the rocker panel, and the bolts held up.
flais is offline   Reply With Quote
The Following User Says Thank You to flais For This Useful Post:
DarkSunrise (04-01-2016)
Old 04-01-2016, 11:11 AM   #7
Cartman
Cartman's Avatar
Drives: 10 Series Scion FR-S
I have this exact same setup, running -2.3 degrees. have done 6 track events and DD my car with this setup without issues.
Cartman is offline   Reply With Quote
The Following User Says Thank You to Cartman For This Useful Post:
flais (04-01-2016)
Old 04-01-2016, 11:27 AM   #8
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
I can also vouch for the SPC bolts on the bottom as well.
But Toyota does make OEM crash bolts in different sizes if you need it for legality/classes rules. The MR2 Slyder guys I have seen run multiple at times but cant give feedback on slipping (though I havent seen anyone complain).
12mm: 90105-14147
13mm: 90105-14146
Its wierd cuz the 14mm bolt is different part numbers for the FRS and the older cars but these bolts are generic across the Toyota line. Dont see why it wouldn't work but again all this is just searching google and the spyder forums so ymmv
And actually curious why nobody tried this in CS lol.
Old 04-01-2016, 12:34 PM   #9
SeanRTR
C-Street AutoX
SeanRTR's Avatar
Rules are very clear, you can only use the Subaru part # nothing aftermarket/SPC
-2013 Scion FR-S C-Street
Gearhead Homes - Homes geared towards car enthusiasts: https://www.facebook.com/GearheadHomes.RealEstate
SeanRTR is offline   Reply With Quote
Old 04-01-2016, 12:41 PM   #10
finch1750
finch1750's Avatar
I just listed multiple size Toyota OEM part numbers with different size bolts that would work in the lower hole as well as the upper hole.
Or does it specifically have to be an option for that car?
edit: nevermind. read the fule and it has to be factory way of adjustment so that would be car specific.
Old 04-07-2016, 08:48 AM   #11
troek
troek's Avatar
Drives: 2012 Toyota 86
Ive ran double crash bolts. Did for about 8 hours on Fuji speedway, never had an issue.
troek is offline   Reply With Quote
Old 04-08-2016, 12:31 AM   #12
mb_
Ex-MR2 owner
Drives: Scion FRS
I'm running the OEM crash bolts on top, SPC camber bolts on the bottom. I was able to get -2.1 of camber on stock suspension.
mb_ is offline   Reply With Quote
Old 04-08-2016, 01:44 AM   #13
Joe-G
Canada Eh!
Joe-G's Avatar
Drives: '13 FRS
OEM 14mm crash bolts up top, SPC 14mm camber bolts in the bottom. Going in for alignment this weekend.
Before (Stock Camber) on TRD Lowering Springs
After (14mm OEM top, SPC bottom) still on TRD springs
Joe-G is offline   Reply With Quote
Old 12-16-2016, 02:57 PM   #14
Joesurf79
Joesurf79's Avatar
Drives: 2016 White Pearl BRZ Premium
Have SPC bolts in the top holes up front, and got roughly -1.0 degree on each side. SPC 14mm camber bolts en route for the lower holes. Looking for that -2.5 deg sweet spot... Anyone think that will be doable with the SPC bolts in both holes?
Joesurf79 is offline   Reply With Quote
Alignmemt w/ Crash Bolts. Thoughts? EAGLE5 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 07-21-2014 02:06 PM
Crash bolts alignment change ABQautoxer Tracking / Autocross / HPDE / Drifting 39 03-24-2014 05:45 PM
Cheapest Crash bolts FReSh Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 08-14-2013 11:12 AM
FS: OEM Subaru crash bolts (2) ayau Brakes, Suspension, Chassis 0 12-27-2012 11:29 PM
Another crash bolts alignment thread jeebus Suspension | Chassis | Brakes -- Sponsored by 949 Racing 42 10-28-2012 12:29 AM
