03-30-2016, 09:58 AM | #1093 | |
Long Distance Driver
I didnt do what you mentioned and connected the lines when the unit was already mounted to the block. As long as you have a helping hand and some pliers, you wont have a problem with those coolant lines with the unit already mounted to the block.
03-30-2016, 10:16 AM | #1094 | |
Driving Coach
When I inevitably boost mine it will be with the new Bosch 870cc Injectors They come the correct length with the extended tip like the factory injectors so the fuel is delivered correctly into the port.
The Following 10 Users Say Thank You to ATL BRZ For This Useful Post: | 86fun (03-30-2016), BigFatFlip (03-30-2016), Boofneenee (03-31-2016), Carlos_M (08-29-2016), clayrush (03-30-2016), CxG (04-01-2016), Luftwaffel (03-31-2016), Nitro22 (04-06-2016), Sargy (03-31-2016), shr133 (05-09-2019) |
03-30-2016, 10:23 AM | #1095 | |
Drives: 2013 FRS
This is good advice. During my install I found I could not connect the electrical connector to one of my injectors and found that the tab alignment was off, but it's possible you could also have misaligned and still be able to plug it in, I got lucky in that regard. |
03-30-2016, 09:56 PM | #1096 | |
Drives: 2015 FR-S Release 1.0
We had mine on jack stands. It took 3 people to carefully set it in while the front of the car was elevated and it took some finessing. We connected the lines after and it was a challenging task, but I think trying to set it in with the lines connected might be even more challenging and frustrating. It also doesn't help that the ears on the clamps they include are spaced so far apart, getting a grip on them in that cramped space seems impossible. We managed to do it, though and unfortunately, I can't remember how. I think we had one person hold the clamp open on one side of the car while the other person attached the hose. Once it was attached (lubed with spit- hey, it works!), the clamp was released onto the hose. At one point, we tried positioning the clamp on the fitting side and holding it so the hose can slide into place and through the clamp. I think that's what we ended up doing. |
03-31-2016, 12:49 AM | #1097 |
Boost Creep
Drives: 2016 HyperBlue BRZ
@Cockatoo - I just did mine a couple weeks ago... I was thinking this would actually be easier. Connecting the coolant lines after manifold placement is a motherfucker. There's no good way to do it and anyone that says there is might just be full of shit. There's no harm in trying it, to be honest. Angle the clamps down and rearward so they don't clip the trim and make sure you have the electrical wiring out of the way beforehand if possible. We zip tied some of the wiring out of the way so we would only have to nudge it around when we placed the manifold, then clipped the zip ties after. Took two of us to do it, and it's one of only maybe two things you need two people for.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
03-31-2016, 12:58 AM | #1098 |
Boost Creep
Can anyone provide a log of some milling around town on a good tune?
CARB/non-CARB doesn't matter.
03-31-2016, 02:37 AM | #1099 | |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
http://datazap.me/u/bigfatflip/16021...m?log=0&data=6 PM me if you need a longer log, I have the original but only uploaded a small section since datazap has a limit on the amount you can upload. |
03-31-2016, 08:42 AM | #1100 | |
Drives: 2017 CWP BRZ Performance Package
The Following User Says Thank You to spicyricecake For This Useful Post: | Cockatoo (03-31-2016) |
03-31-2016, 11:36 AM | #1101 | |
Drives: FRS, Supra, Colorado D, GLC63
Also, 3 people will be plenty to guide the supercharger down. |
The Following User Says Thank You to The Racers Line For This Useful Post: | Luftwaffel (04-02-2016) |
04-01-2016, 08:33 AM | #1102 |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
Can anybody that is running a Radium catch can (PCV) with this kit confirm weather or not the hoses that come with it reach the supercharger? Or does the one hose have to be extended?
04-01-2016, 02:06 PM | #1103 |
04-02-2016, 03:05 AM | #1104 |
Boost Creep
So I thought my fuel trims were batshit crazy, but it looks like Big's fuel trims are batshit crazy too.
I have insane afterfire on downshifts. On a completely unrelated topic, people don't seem to be following me closely anymore.
04-02-2016, 02:14 PM | #1105 |
Hmmm interesting. For what it's worth, I've had Edelbrock look at my logs before for some other thing and they didn't mention anything about the fuel trims. On the other hand, they may think it's normal since its their tune
04-02-2016, 10:10 PM | #1106 |
Drives: FRS,09 370z, 00 CelicaGT-S, 85 300Z
Just gonna trow this out and see if anyone might have some insight .
I have had the delitious flex kit on for over a year befor the charger, with zero issues. Even when it was freezing outside. After we installed the kit we were having issues when rolling to a stop. The car would either die or the rpm would seek up and down by 2.5k rpm. Only way to get it to stop was to gas it a bit. We do have a a lightened flywheel. But the heavier of the 2 from act. At first we thought it may have been contributing to the problem. We met up with bill when he was in the bay area. He worked on it a bit and gave us a hybrid tune. It fixed the idle and stalling issues. But now when the car first starts up / cold start, it dies right away and takes anywhere from 3 to 6 times to fire up. When it does it sits at a very low rpm nearly choking out, then it smoothes out after 30 seconds or so. We have sent delicious several logs and did smoke testing. we do not seem to have any vacuum leaks. I dont know if the orientation of my dw700 injectors makes any difference or not. According to the app our E content is around 80-84. I tryed blending a little 91 and got to about e55. Next step is to run out the e85 and try just 91 oct. For some reason I feel like the car is not getting enough power from the battery / alternator durring start up. I have no real basis for feeling like that, I just do. part of me feels like the intercooler water pump running during start up does not help. Once again just an odd feeling. |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
