#645 |
Drives: 2014 GT86
I'm not that against price of Ace's which i find reasonable. After all, to compare it's price with others one has to add up price of overpipe to their prices too. +To get best out there also may have some extra cost justified by that. Just that .. it's still expensive purchase and for now would be nice to find out how performance wise CS400 stacks up against A/350. Maybe King is dead, long live the King?
![]() Ace's prediction was some toque gain at cost of some hp loss. Who knows, maybe exchange will be at favourable rate. As i mostly DD mine, maybe that may favor my driving more, even if i haven't RHD fitment limitations. AceHeader-MT: btw, will CS400 also have choice of multiple overpipes with different merge points for different rpm optimisation? Or maybe even overpipes of A&B can be reused for that? |
#646 |
Drives: 13 BRZ, 16 FiST, 05 WRX
Would an Ace specific tune like the one from Delicious work reasonably well with any of the 150-400 overpipes? Or would the best tune change a lot among them all?
#648 |
How much is the customs fee for the cs 400 header?
#649 |
Drives: Corn Juice junkie
or $50.00, we have top people working on the answer. |
The Following 2 Users Say Thank You to seito23 For This Useful Post: | AceHeader-MT (02-21-2016), raven1231 (02-21-2016) |
#650 |
Drives: 2012 FR-S
#651 | |
Drives: 2012 FR-S
At this time the CS400 OP will only have the current size. We do not plan on making various OP lengths for this header set. Take care |
#652 |
Realtor/ Principal Broker
Drives: JRSC BRZ GBS LTD 2010 LTD Outback
Is the OP for the CS400 included? Also would I use the same front pipe as the one for the TypeA350?
#653 |
Drives: 2014 GT86
Jmonty: just check pics of CS400. Yes, overpipe that lengthens runners in similar fashion as with A & B header types is still there. It hasn't been stated, but i bet 99% that just like A & B, CS400 most probably also will be able to work with other exhaust bits that are made to fit stock mount dimensions/placement, so i see no reason for this header to be exclusively designed not to fit stock (or most other aftermarket made with stock fitment) frontpipes.
The Following User Says Thank You to churchx For This Useful Post: | AceHeader-MT (02-22-2016) |
#654 | |
Drives: 2012 FR-S
All header systems bolt up directly to ACE FP, OEM FP and most other aftermarket FP's as well. |
#655 | |
Hi Team Ace Thanks for the videos. The header sound very...unique Was that with stock FP and Stock Cat back? Im assuming if i only change the header it wouldn't be as loud? |
#656 | |
Drives: 2012 FR-S
That was ACE FP with a make-shift dual exhaust that we threw on for the test. We're still in development of the "low db" catback system so we took whatever pieces we had laying around to do a few passes. We agree, it sounds crapp...unique ![]() If you leave the stock FP and catback it will be much softer sounding. People have also said good things about the invidia q300 system. |
#657 |
Drives: Toyota 86 GTS
250, catted FP, stock cat-back. |
The Following 4 Users Say Thank You to Wayno For This Useful Post: |
#658 |
Drives: '13 SSM BRZ Limited 6MT
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
