Electronics | Audio | NAV | Infotainment Anything related to in-car electronics, navigation, and infotainment. |
Engineering Student
Drives: Scion FR-S 2015
Toyota Axes Scion - Change Splash screen logo
Well, I hate scion now! Haha!
Is there a way to change the startup screen (splash screen) of the Scion FRS head unit on 2014+ model. I have the 2015 stock head unit. Basically I just want to remove the Scion splash screen to Toyota ![]() Offtop: What about the steering wheel, just overlay with a toyota badge ![]()
There’s no time to stop for gas, we’re already late
#2 | |
The Following 3 Users Say Thank You to funwheeldrive For This Useful Post: |
#3 |
Engineering Student
Since you ask, lol. I did, found nothing for the FRS only the brz.
#4 |
Sporadic Member
Drives: 2016 Halo FR-S M/T
The thought popped into my head to try and change the splash screen too. Doesn't look like there's anything on changing the splash screen on the FR-S.
#5 |
Drives: Mazdarati
Plus 1 billion................
![]() ![]() ![]() And you might of found this....... http://www.ft86club.com/forums/showt...radio+settings
The Following User Says Thank You to IceFyre13th For This Useful Post: | go_a_way1 (02-05-2016) |
#6 |
Not Bаnned Anymore
Drives: Heavily Modified FRS
In before lock
#7 |
Killed Scion
Drives: 2013 FR-S Whiteout
Actually I'm kind of interested as well
Miyuki みゆき "Beautiful Snow" The Whiteout FR-S Instagram: trevor.parque |
The Following User Says Thank You to MisterSheep For This Useful Post: | KR-S (02-06-2016) |
#8 | |
Time Traveller
1. Print this... 2. Cut it out with scissors. Be careful with the outlines. 3. Now using your hands, tape over front of your factory Scion head unit (stereo). 4. Remove when needed. |
The Following 7 Users Say Thank You to DAEMANO For This Useful Post: | Blu-by-U (03-26-2016), go_a_way1 (02-05-2016), GT86_PRAGUE (04-12-2016), KR-S (02-06-2016), lbroskee (02-05-2016), MisterSheep (02-05-2016), wbradley (02-06-2016) |
#9 |
Not Bаnned Anymore
TDRL or w/e the hell it is/means:
YOU CANT so get over it and if it bothers you so much buy an aftermarket unit. /thread |
The Following User Says Thank You to go_a_way1 For This Useful Post: | MisterSheep (02-05-2016) |
#10 | |
Killed Scion
#11 |
Drives: 2023 WRB BRZ (MT)
The Following User Says Thank You to lbroskee For This Useful Post: | go_a_way1 (02-05-2016) |
#12 |
Not Bаnned Anymore
LMAO thanks I never figured that one out and didn't want to google it. Was way more fun learning this way
#13 | |
Drives: 2015 FRS
Here's how to change the startup image on the entune nav: Load a usb device, such as a flash drive with the image of your choice. The images file name, including the file extension, can be up to 32 characters. Name the image without spaces or strange characters. When saving the images to a USB, name the folder that the startup image is saved to “StartupImage” and name the folder that the screen off image is saved to “DisplayOffImage”. If these folder names are not used, the navigation system cannot download the images. (The folder names are case sensitive.) The images file extension is JPG or JPEG. Image files of 10MB or less can be saved. Up to 3 images can be downloaded. Plug the flash drive into your car usb port. On the entune nav system: Press the “SETUP” button Touch “General” on the “Setup” screen. Touch “Customize Startup Image” Touch “Transfer” Touch “Yes” You can also delete and switch between screens. You should now see your new startup screen flash by when the entune system is started each time. This forum is really starting to suck with the the un helpful replies, sure i can be unhelpful too at times, but those are to people with really stupid questions. |
The Following 13 Users Say Thank You to Lorico For This Useful Post: | D_Thissen (02-06-2016), FRSBRZGT86FAN (03-05-2016), gatorbushmen (02-09-2016), go_a_way1 (02-06-2016), GT86_PRAGUE (04-12-2016), HyperTech (02-20-2016), KR-S (02-06-2016), Lonewolf (02-06-2016), Mikeez (02-09-2016), S84kam (02-06-2016), saj (04-06-2016), Scourge (07-14-2017) |
#14 |
Drives: FBRZS
I changed my head units logo as well. But I went to the dealer and they did something similar to what lorico said.
Do you guys assume the scion symbol magically appeared when the vehicle rolled out of the production plant? Obviously someone added it there. Therefore it CAN be changed As of late. There have been the same douche bags replying. Answering as quick as possible without the slightest bit of help. With the usual answer "have you searched yet" in hopes to receive their "thanks" |
headunit splash screen. | encity5 | Electronics | Audio | NAV | Infotainment | 21 | 08-11-2017 03:00 PM |
How to remove SCION silk screen logo from Headunit | Danklvr | DIY (Do-It-Yourself) Guides | 78 | 05-29-2016 07:09 PM |
Scion stock HU change boot up logo | Lorico | Electronics | Audio | NAV | Infotainment | 2 | 10-16-2015 02:49 PM |
Custom splash screen with OFT? | CaptainSlow | Software Tuning | 0 | 02-15-2014 08:30 AM |
T7019A HELP boot screen or splash screen change | Trap63 | Electronics | Audio | NAV | Infotainment | 2 | 06-09-2013 05:04 PM |
