Software Tuning Discuss all software tuning topics. |
01-02-2016, 04:49 AM | #29 | |
Drives: FT86
Unfortunatly when the tune database becomes corrupted and you cannot read\write tunes or flash back to stock your snookered as you cannot un marry the tablet to erase. As the tune datavase is part of the marry unmarry your locked out as otherwise you would be able to unmarry oft while still tuned. So it like y going to jave to be sent back for reset. Of you send that prolog file to the openflash guys they might find out what happens. It in some proprietry format so not readable OFT are alientech powergate 3 devices http://www.powergate-alientech.com/en/ |
The Following 3 Users Say Thank You to steve99 For This Useful Post: |
01-02-2016, 04:16 PM | #30 |
Drives: 86 A00I
All makes sense Steve, cheers for your always on-the-ball input in the OFT scene.
Unfortunately there's a notable absence official OFT guys in this thread - are they aware of this issue, and are they working on a fix? Arbitrarily bricking customer's products is pretty bad publicity, and I really don't like my chances going to a Toyota dealer with all this altered hardware/software and getting them to sympathise with a reflash of the ECU. Also: I think it's safe to say at this point if you're an OFT user, especially if you haven't let it connect and update via OFT Manager in some time, do not allow it to connect to the internet and do the update process until this problem is resolved... unless of course you want yours bricked. Last edited by dtek; 01-02-2016 at 04:43 PM. Reason: added heads-up to other users |
01-02-2016, 07:25 PM | #31 | |
Drives: Scion FR-S
01-02-2016, 07:45 PM | #32 |
Drives: FT86
Toyota/subaru flash ecu 's all the time. however they are reluctant to flash ecu's for people unless their is a TSB issued
01-02-2016, 08:13 PM | #33 |
Drives: Scion FR-S
All I can report is my experience, which is that both dealers I went to tried and failed to flash the ECU. They had no reason to not do it as I was paying for them to do so.
01-02-2016, 08:16 PM | #34 | |
Drives: FT86
The only thing i can think of is the OBD port in your car is faulty , many 2013 and earlier cars had intermittent obd port connectors, the OFT cable is good quality thick pins and works well. however many other obd devices like tactrix and dealers cables have thinner pins which show up the problem. |
01-02-2016, 09:42 PM | #35 |
My dealer tried first time, failed. Needed to call corporate to find out how to flash my 2013 to B01. But they were able to do it the second time.
01-02-2016, 11:49 PM | #36 | |
01-03-2016, 01:05 AM | #37 | |
Drives: Scion FR-S
Interesting, simply an update or was it over riding a custom tune? They were working on the car for quite a bit, so we actually thought they may have called corporate to ask. Either way, I'm quite sick of taking the car in with no fix, so going to rely on the new tablet to fix. |
01-03-2016, 01:44 AM | #38 | |
Drives: FT86
The Following User Says Thank You to steve99 For This Useful Post: | kodyo (01-03-2016) |
01-03-2016, 01:48 AM | #39 | |
Drives: FT86
If your original calid was say ZA1JB01C then any rom with that calid is ok see the tactrix link below end of that post has a lot of the stock roms, i have some of the older ones as well if you need one. |
The Following User Says Thank You to steve99 For This Useful Post: | dtek (01-12-2016) |
01-03-2016, 03:06 AM | #40 | |
01-03-2016, 03:07 AM | #41 | |
My take on it was that they had the tune update file but did not have the current version of the flash software, and corporate just gave them the new version. Makes sense if it's different ECU than what Toyota typically uses.
The Following User Says Thank You to phrosty For This Useful Post: | kodyo (01-03-2016) |
01-09-2016, 10:48 PM | #42 |
Drives: Scion FR-S
Got new tablet and that fixed the issue. Was able to successfully load tune back onto the car. I suspect issue may have stemmed from unplugging tablet from computer after browsing for the tunes but not clicking the 'start' button to fully load them in section 3 of the upload section.
Similar Threads | ||||
Error in opening file | chickencornsoup | Software Tuning | 14 | 04-27-2016 01:11 PM |
Trunk opening after "spirited" uturn. | JDM FRS | Issues | Warranty | Recalls / TSB | 30 | 08-22-2013 10:08 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
New 8" Alpine fill the stock opening? | Roborat | Electronics | Audio | NAV | Infotainment | 3 | 08-20-2012 07:43 PM |
"Senna" opening this weekend | tranzformer | Off-Topic Lounge [WARNING: NO POLITICS] | 31 | 08-20-2011 03:21 AM |
