go_a_way1
Old 12-23-2015, 04:51 PM   #3137
Binary_fission
Binary_fission's Avatar
Drives: FRS
Originally Posted by JDMChris View Post
You absolutely need a tune. The car will run lean if not, and will cause damage in time if not tuned.
Talked to churches, they won't be available till next year. So gotta wait but decently will get it tuned thanks. And for pulleys and driveshaft no need tune?
Sent from my SM-N910T using Tapatalk
Binary_fission is offline   Reply With Quote
Old 12-23-2015, 06:20 PM   #3138
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
As long as the pulleys are OE size, you don't need to tune for them.
JDMChris is offline   Reply With Quote
The Following User Says Thank You to JDMChris For This Useful Post:
Binary_fission (12-23-2015)
Old 12-26-2015, 06:19 PM   #3139
enivid
enivid's Avatar
Drives: WRB JR BRZED
Has anyone figured out how to remove the A/C when using this kit? Both the OEM and Raceseng ac delete kits do not work.
enivid is offline   Reply With Quote
Old 12-26-2015, 06:50 PM   #3140
ScionOfHorus
ScionOfHorus's Avatar
Drives: 2015 Series.Blue BRZ
You will have to make a custom kit.
Sent from my MotoE2(4G-LTE) using Tapatalk
ScionOfHorus is offline   Reply With Quote
Old 12-26-2015, 07:36 PM   #3141
menikmati
Drives: 2015 BRZ, 2005 STI
The guys at Speed Academy notched out their Raceseng AC delete to make it work with the JRSC.
menikmati is offline   Reply With Quote
The Following User Says Thank You to menikmati For This Useful Post:
CSG Mike (12-28-2015)
Old 12-26-2015, 08:30 PM   #3142
enivid
enivid's Avatar
Looks easy enough. Thanks
Old 12-26-2015, 08:48 PM   #3143
Binary_fission
Drives: FRS
Delete
Old 12-28-2015, 03:49 PM   #3144
CSG Mike
CSG Mike's Avatar
Anyone know if i have to tune ecu with custom tune. I have headers, front pipe and exhaust, no cats. I'm running carb tune that came with the kit. One of friends mentioned that I have to get custom tune with those mods otherwise it's bad for the car.
Honestly I don't want more hp or boost, im still gettin used to the car with its current set up, i just want to make sure car runs good and it won't have problems with those mods. Also future mods are lightweight pulleys, lightweight driveshaft, flywheel and clutch. Are those mods will require tune as well or nah?
Thanks
You need to baby that car until you have a proper tune.
Binary_fission (01-02-2016)
Old 01-01-2016, 08:38 PM   #3145
briang0901
briang0901's Avatar
Drives: 2024 MT Toyota GR86
I have the Nameless 2.5" overpipe/downpipe and their axleback. can i still use the carb tune or no?
2024 Toyota GR86
2013 Scion FR-S
briang0901 is offline   Reply With Quote
Old 01-02-2016, 05:56 AM   #3146
cookiesowns
Drives: WRB BRZ Series.Blue
Make sure your seal is good from the sandwich plate and adapter. If it's slightly off, you should replace the seal.
Hey mike,
Been awhile. I've been noticing some smell of oil when running hard, I noticed there's small drips of oil on the oil filter mount. Is it possible my seal is going out? Where should I source the seal?
cookiesowns is offline   Reply With Quote
Old 01-02-2016, 09:14 PM   #3147
CSG Mike
CSG Mike's Avatar
Originally Posted by cookiesowns View Post
Hey mike,
MoCal or Jackson Racing.
Make sure your adapter nut is properly torqued.
Old 01-02-2016, 09:14 PM   #3148
CSG Mike
CSG Mike's Avatar
Stock header + stock front pipe? Yes, you can use the CARB tune!
CSG is ready for your order
Old 01-02-2016, 11:09 PM   #3149
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
I believe the nameless overpipe/downpipe replaces the secondary cat with a high flow cat, so it technically wouldn't be "CARB" legal but probably doesn't affect the flow significantly enough and should be OK to use the CARB tune, correct?
Old 01-02-2016, 11:29 PM   #3150
CSG Mike
CSG Mike's Avatar
I wouldn't recommend it if a OEM cat is changed.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
