Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
01-02-2016, 02:53 PM | #15 | |
01-02-2016, 05:11 PM | #16 |
I used waterproof outdoor silicone around the hole perimeter in case water seeps through the adhesive.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
01-02-2016, 05:14 PM | #17 |
I'm talking 2-3 years out, with a constant barrage of water and wind like on a highway at 60+ mph or something it will eventually wear away, most outdoor silicone aren't meant for that....
01-02-2016, 05:16 PM | #18 |
Ah k...well the silicone isn't exposed to the outside elements just temp. If it fails I'll just try something else.
01-02-2016, 08:50 PM | #19 |
Get a circle of metallic blue vinyl cut just big enough to cover it. They make thicker vinyls that won't be an issue as far as durability. Will be much less noticible.
The Following User Says Thank You to jadewbj For This Useful Post: | stevesnj (01-02-2016) |
Similar Threads | ||||
***NEW***Beatsonic Version 2 Sharkfin Antenna | FT-86 SpeedFactory | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 03-27-2016 04:32 PM |
FS: Beatsonic Sharkfin Antenna - Sterling Silver/Argento FDA9 (Version 2) | chermo12 | Canada Classifieds | 3 | 06-02-2015 08:45 AM |
"86" Dash Plaque - VG Shark fin antenna - Hot Lava | seven | Interior Parts (Incl. Lighting) | 3 | 04-16-2013 11:24 PM |
VG Shark fin antenna - Hot Lava - "86" Dash Plaque | seven | Exterior Parts (Aero, Lighting, Etc.) | 1 | 04-16-2013 11:24 PM |
1st 86 Final Gift : Carbon look Coin Tray badge, Plaque, FR-S Book, CNC Aluminum Box | MarkRacerX | Interior Parts (Incl. Lighting) | 3 | 12-14-2012 12:30 PM |
