12-15-2015, 09:18 AM | #99 |
NASA SpecE30 Racer
I'm just here for the facts. Did I miss them?
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
The Following 10 Users Say Thank You to King Tut For This Useful Post: | Apoc (12-16-2015), ATL BRZ (12-15-2015), clayrush (12-15-2015), Dimman (12-18-2015), Fakk (12-16-2015), ravisraval (12-15-2015), Slysdexia (12-16-2015), Sportsguy83 (12-15-2015), strat61caster (12-15-2015), toast (12-15-2015) |
12-15-2015, 09:31 AM | #100 |
Drives: 2013 Ultramarine FR-S
The Following 3 Users Say Thank You to Freeman For This Useful Post: |
12-15-2015, 10:48 AM | #101 |
Drives: Sterling BRZ Ltd
There are really to many variable to draw a definitive line in the sand as to when a rod will fail. So it comes down to do you want to be proactive or not on replacing them, that decision is based on opinion, the purpose of this post.
12-15-2015, 11:15 AM | #102 |
I Love custom Turbo kits
Drives: Limited BRZ
Thread title: "F/I Blowing motors facts"
Quite the contradiction Aye? Usually when you talk about how you set records etc., it's like when the dog has all the bark and no bite.
The Following 9 Users Say Thank You to Sportsguy83 For This Useful Post: | ATL BRZ (12-15-2015), BRZoomTX (12-16-2015), clayrush (12-15-2015), CSG Mike (12-15-2015), mrloko (06-27-2018), ravisraval (12-15-2015), Slysdexia (12-16-2015), strat61caster (12-15-2015), toast (12-15-2015) |
12-15-2015, 11:45 AM | #103 |
Drives: 370z
I thought his "fact" was that the rods are weakest and first to brake, based on his experience. Then what happens when the rod brakes.
Then his opinion is that around 300hp fi is where you can expect failures. Don't know why everyone is being so harsh? No one has presented anything that says otherwise... |
The Following User Says Thank You to totopo For This Useful Post: | FRS Justin (12-15-2015) |
12-15-2015, 11:54 AM | #104 |
Drives: Scion FR-S
In my opinion the weakest link on these motors are the heads for sure. i snapped a valve spring stuck open the intake valve and dropped a retainer into the cylinder. just holding the stock valve spring in my hand i could fully depress them with my fingers. i replaced the rods with skunk 2 I beams and lowered compression .08 - 1.0 with cosworth head gaskets.
i have the hks gt supercharger kit on 10 psi, bumping her up to 17. setup: hks gt sc hks oil cooler fic 660 injectors dw65c pump skunk 2 I beam connecting rods titanium valve springs cosworth head gaskets lowering compression 0.8-1.0 ft86speedfactory headers - no cat act 6 puck clutch LW flywheel e-85 95mm pulley no restrictor trd catch can. Last edited by Andew727; 12-15-2015 at 02:54 PM. |
The Following 2 Users Say Thank You to Andew727 For This Useful Post: | FRS Justin (12-15-2015), Toyarzee (12-15-2015) |
12-15-2015, 12:06 PM | #105 |
Shibby!
Drives: '14 White FR-S, '01 turbo mini taco
The Following User Says Thank You to Toyarzee For This Useful Post: | FRS Justin (12-15-2015) |
12-15-2015, 12:52 PM | #106 |
Drives: 2014 BRZ
Edelbrock seems to think their level of boost is safe enough to offer an engine warranty with their kit...
12-15-2015, 01:06 PM | #107 |
Drives: blue - Cosworth SC stage 3.0
all depends on how much testing they've done, as the cylinder pressure and rod loads will be effected by boost but also by the amount of spark, where the cams are etc etc
so the engine load is entirely dependent on the tune / calibration I'd say knowing Edelbrock's reputation they are probably being quite conservative with their tune and only warrantying installations that use their tune that's what I'd do anyway when we produced our kit we measured cylinder pressure on the test bed and had a target figure not to exceed - the end result is what we got whilst being careful not to exceed this figure |
The Following 9 Users Say Thank You to Matt@Cosworth For This Useful Post: | CSG Mike (12-15-2015), FRS Justin (12-15-2015), raven1231 (12-17-2015), Slysdexia (12-16-2015), Spartarus (12-15-2015), Sportsguy83 (12-15-2015), totopo (12-15-2015), uRBAN_Metal (12-15-2015), weederr33 (12-16-2015) |
12-15-2015, 01:17 PM | #108 | ||
Drives: 370z
It makes sense that the springs and rods arent that beefy. They were pushing for max hp number and fuel efficiency at cheap price. Heavy springs are bad for hp and reliability, heavy rods are bad for hp and efficiency. Quote:
Edit: and yes, must be their tune, which is about 240 whp 185wheel tq, which is nowhere near 300whp... Last edited by totopo; 12-15-2015 at 01:29 PM. |
The Following 3 Users Say Thank You to totopo For This Useful Post: |
12-15-2015, 02:39 PM | #109 |
Drives: Scion FR-S
another very bad issue i noticed when building my motor was the RTV overuse on mating surfaces that contain oil galleries. i had some that had so much RTV is was pretty much closed off. i went with a new engine gasket kit and tried to use the least amount possible or replaced some areas with aftermarket caps ect.
i heard of this on someones else build and could not believe how bad it actually was in there. |
The Following User Says Thank You to Andew727 For This Useful Post: | FRS Justin (12-15-2015) |
12-15-2015, 02:42 PM | #110 | |
Drives: Scion FR-S
my failure also occured at idle at a stop light so i was lucky to not have serious damage done when the retainer dropped. im not sure how to upload pictures but i have some on my instagram page " @AndyB727 " the next thing will be your transmission when you get up around 400whp ive heard but who knows when you are way above double this cars stock power. anything may pop. |
The Following 3 Users Say Thank You to Andew727 For This Useful Post: |
12-15-2015, 02:54 PM | #111 |
Drives: 2013 Asphalt FRS
36000 miles warranty is based on a new car 0 miles, so who really gets all 36000 miles?
I would buy a factory mustang and save 10k and have more hp before I did that. Its proven E85 car N/A have made over 200hp, why would anyone buy a s/c kit that makes 243 hp for 5k? 40hp for 5k seems a little steep to me. Edelbrocks factory tune works with all exhaust system?? so a tune to optimize your 5k investment is required oops no warranty now. E85, new pulley, race rom features, no warranty now I wish to everyone good luck who buys one being happy at 243hp and a warranty for 5k you deserve to be happy I myself would buy a Jackson for 3999 and make 300 plus hp and have my race rom and optimized tune One more thing you get for your 5k edelbrock s/c that no one has mention is that remaining powertrain factory warranty to 60k that is usually needed by45 to 50k bye bye SO in my mind that warranty or so called warranty is really more of a marketing tool than a warranty go ahead and put that bad boy on your car that has 20 to 25 k miles on it because in a year to a year and a have when they might start having a problem edelbrock won't even know your name I will admit I looked at them but its not for me, to many options out there, for that money
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-15-2015 at 03:08 PM. |
The Following User Says Thank You to FRS Justin For This Useful Post: | raven1231 (12-15-2015) |
12-15-2015, 02:59 PM | #112 |
Drives: Scion FR-S
take everyones advice in to your choices, i like to buy once cry once as much as possible but that can get expensive. im not extremely experienced with these cars but i learn something new every day i work on them. i am really trying to push the centrifugal sc output on a budget. all the advice in here seems pretty legit to me. most tunes have a pretty aggressive cam angles on these cars if im not mistaking.
Tags |
kill brain cells, not facts |
Similar Threads | ||||
FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 01:08 PM |
Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
