Old 10-16-2015, 12:18 PM   #99
DaiTT500
DaiTT500's Avatar
Drives:
http://www.power-division.com/produc...cat=414&page=1
These are the GSC springs I got.
DaiTT500 is offline   Reply With Quote
The Following 4 Users Say Thank You to DaiTT500 For This Useful Post:
Draco-REX (10-16-2015), smudge (12-04-2015), strat61caster (10-16-2015), Xero-Limit (10-19-2015)
Old 10-19-2015, 04:29 PM   #100
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Originally Posted by Draco-REX View Post
Do you have a part number? I see two sets from GSC, but I didn't notice a mention of beehive.
Also, I'm still at the stock redvline. Any downsides I should be knowledgeable about?
Thanks.
The cheaper one is the standard kit, the more expensive one (400-500) is what Dai got below and includes the beehive springs. Beehive spring setups are superior in racing use where you are prolonged at high rpm. For most people the cheaper kit is plenty to keep the rockers from getting banged up.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Draco-REX (10-19-2015)
Old 10-19-2015, 05:54 PM   #101
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Thanks. Ordered and on the way.
Old 10-19-2015, 07:09 PM   #102
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Such a nice read, this reminds me starting from 2015 model subaru actually changed the valve & part of the head, the new valve is actually longer (from 103.3mm to 105mm). Would that have anything to do with this?
Old 10-19-2015, 08:47 PM   #103
Draco-REX
Corner Junkie
Draco-REX's Avatar
Don't know. It's possible the longer valve would make it less likely it would lose touch with the rocker. Depends on what other changes were made.
Old 10-20-2015, 02:46 AM   #104
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Looked around & found this. http://www.ft86club.com/forums/showp...&postcount=642
looks like other then valve & cam/cam gear, rocker is also changed. Maybe some other parts as well in steps.
Old 10-20-2015, 05:01 AM   #105
matchamochi
matchamochi's Avatar
Drives: swp brz
If people decide to go S/C route do you feel like upgraded springs (and possibly rockers) are a requirement for safety?
These pictures are giving me nightmares.
matchamochi is offline   Reply With Quote
The Following User Says Thank You to matchamochi For This Useful Post:
ATL BRZ (10-20-2015)
Old 10-20-2015, 05:06 PM   #106
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Debating this as well.
Old 10-20-2015, 08:42 PM   #107
Draco-REX
Corner Junkie
Draco-REX's Avatar
I noticed that the spring descriptions said they were for various levels of boost. I'm not sure how that works since I would think that higher cylinder pressures would only help the springs. But I'm sure there's a good reason. That being the case, then springs on a boosted motor (definitely pre '15 according to the above post) would seem to be a good idea. However, with the sheer number of boosted twins that are running just fine without valvetrain issues, I don't think it would be an immediate concern. Maybe an off-season upgrade?
The Following User Says Thank You to Draco-REX For This Useful Post:
Old 10-20-2015, 10:01 PM   #108
DaiTT500
DaiTT500's Avatar
Drives:
It's just randomly being unlucky my opinion.
Old 10-21-2015, 08:18 PM   #109
Draco-REX
Corner Junkie
Draco-REX's Avatar
Let's hope I'll reduce the randomness to near 0.
Old 10-24-2015, 04:22 PM   #110
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
I personally removed my check valve on my pcv passenger side and have a tiny cone filter on both engine pcv to vent to atmosphere. I plugged the the hole on the intake with a vacuum plug with clamp.
I think if you get boost into the engine and it creates a back pressure on the valve, the valve will float. The piston will kiss the valve and the valve will throw the rocker to the moon. the tube from intake to passenger pcv. When under boost the tube now has boost. The pcv is closed. The only pcv that can open is the front near the ac. That doesn't seem good the rear passenger pcv is unable to let boost out and can cause back pressure.
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 12-02-2015, 06:47 PM   #111
Draco-REX
Corner Junkie
Draco-REX's Avatar
Well, the plan of getting a used head and building it with better springs fell through. Of the 4 used heads I found: one was listed twice and turned out to be damaged, I couldn't get a hold of the salvage yard of the second one, and the third when it showed up was from a FA20DIT. When I called the yard about the mixup they tried to convince me it was out of a BRZ and sent pictures of the car as if that meant something. The car was obviously flood damaged so I didn't bother to try and get the correct head from them.
At this point I had to look into other options. 1. build a new head, 2. buy a set of built heads. Pricing out option #1, building a single head and having a shop change the springs on the other, it turned out to be a significant portion of the cost of buying a pair of built heads. So I decided to go with the built heads.
Finally, they were delivered today:
Full Blown Motorsports Stage 2 heads.
Ferrea hardware including dual springs, titanium retainers, Comp Plus valves, seals, etc.
Shiny new valves. Exhaust valves at 1mm over-sized. Also FBM performed their "Competition Valve Job".
And a full P&P:
Exhaust.
Intake.
Can't wait to get these on! These, plus the Delicious 9.0 tune, should make for some pretty good numbers. Unfortunately, it will probably be Spring by the time I can get the car on a dyno.
The Following 3 Users Say Thank You to Draco-REX For This Useful Post:
SkAsphalt (12-23-2015), smudge (12-04-2015), tinma (12-02-2015)
Old 12-02-2015, 06:59 PM   #112
GsxrMe
GsxrMe's Avatar
i assuming since I don't see aftermarket rockers. The factory rockers are fine if the valves are shimmed correctly?
2014 Subaru BRZ
I Need Advice About An Fr-s! DViper0020 Issues | Warranty | Recalls / TSB 13 05-09-2014 10:15 AM
Some advice zoomzoomers Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 04-22-2013 05:16 PM
Advice EDCOVEY FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 12-10-2012 08:16 AM
Need advice Ikmv Scion FR-S / Toyota 86 GT86 General Forum 7 08-23-2012 12:17 AM
Need advice FRSMAK86 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 08-06-2012 05:39 PM
