08-26-2015, 01:21 PM | #43 |
Add lightness!
Drives: 17' WRX
08-26-2015, 04:28 PM | #44 | |
Drives: 2013 Black FR-S
But it works. Temps stabilize at 200 deg F driving really hard on track.
08-27-2015, 03:24 PM | #45 |
Drives: Subaru BRZ Limited
Going high boost in a few weeks with Mike @ moto-east. I just drove the car through 130 degree temps on 91 through death valley a few weeks ago. Altitude went from 12,000 ft to sea level on my trip. No issues at all, Mike's tune was awesome. Car is on JRSC with stock exhaust now, just headers.
Mods to be done next week or the week after: Full Amuse system (mid, over and exhaust) Upgraded pulley Flex Fuel Injectors Pump Ill post the dyno as soon as Mike is done with it. We are going to run 93 as much as possible (I cant find e85 every where in NJ / NYC). But he said the kit should be good to switch back and forth. He knows I drive the car like I stole it. If I do ship the car out west. Where we will have extreme altitude / temps, I will have mike do a retune.
The Following User Says Thank You to Parikh1234 For This Useful Post: | Toyota86.ir (12-29-2015) |
08-29-2015, 02:40 PM | #46 |
Drives: FRS
This is amazing news. Time to get ready to go all out on this pckg. Was going to go FI this December or January since not being used over the winter.
The Following User Says Thank You to Evil Rocky For This Useful Post: | CSG Mike (08-29-2015) |
09-01-2015, 03:45 PM | #47 |
Curious cat.
Drives: 86 GT base M/T - Red
Would this be track worthy on a stock block with all of the mentioned supporting mods on 93 octane, plus an oil cooler?
Or is this setup more of a 'street' solution? I was playing with the idea of the regular CARB kit but I ve got a full exhaust so a custom tune would have been necessary anyways. At least with this setup there'd be more power on the table, assuming that the reliability is there.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
09-01-2015, 04:02 PM | #48 | |
Drives: 2015 Series.Blue BRZ
Sent from my XT1095 using Tapatalk
09-01-2015, 04:22 PM | #49 |
Curious cat.
As far as I know they've been tracking the CARB setup of the JRSC on their shop car for some time which is great, but that's not the same thing as tracking the small pulley/high boost version.
09-01-2015, 09:38 PM | #50 | ||
Can you? Sure. Are you putting your engine at a large risk? Yes. |
09-02-2015, 06:35 AM | #51 |
Drives: GT86
Any video with the high boost pulley?
09-02-2015, 06:39 AM | #52 |
Drives: toyota mr2/ Toyota GT86
so its a bit marginal when on boost then? by that I mean you need the safety margin of E85 to support the boost without grenading the stock bottom end?
this still seems a sketchy to me as rods fail due to high pressure and its known that they are the weak link, just piling the boost in I think will result in tears down the road |
09-02-2015, 08:07 AM | #53 | |
Drives: '23 BRZ Limited
Real track work is hard on the stock engine (hence the need for oil coolers, different oil, etc), why wouldn't you think more than doubling the output of the engine wouldn't accelerate that? |
09-02-2015, 02:39 PM | #54 | |
In our experience, we haven't had any issues caused by the increased output, except needing a new clutch. |
09-11-2015, 11:38 AM | #55 |
Driving Coach
+1 for HBP driving videos, preferably on a track.
09-11-2015, 04:31 PM | #56 | |
If I've read and understood the reporting correctly, you can run the pulley on 93 octane under street conditions, but you need E85 or 100+ octane for track conditions. That's straightforward enough, but if a higher spec clutch is also a must for track conditions (or even street conditions) then I'd like to confirm this for a proper set-up. Thanks. |
Similar Threads | ||||
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! | CSG Mike | Forced Induction | 24 | 04-27-2016 12:59 PM |
Jackson Racing BRZ | Parikh1234 | Member's Car Journals | 31 | 12-29-2015 09:26 AM |
Why no high rpm boost for Phantom ESC? | stevo585 | Forced Induction | 11 | 02-11-2014 07:51 PM |
Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 02:29 PM |
