Software Tuning Discuss all software tuning topics. |
08-27-2015, 06:16 PM | #15 |
Drives: 2013 subaru brz
What are your IATs when all of this is happening? You could have knock correction plus high IAT correction, this could all be causing high egts. My knowledge is limited but I was logging similar performance issues when running crap 91 with high IATs
08-27-2015, 07:14 PM | #16 | |
Drives: Toyota 86
Also, what port injectors are you running and how have they been balanced with the DI system? When I switched injectors, it took me a while to sort out the areas where the PI system turned on, but operated in a non-linear range - have you logged PI and DI pulses and to see if the hesitation occurs with switchover? |
08-27-2015, 07:20 PM | #17 | |
Drives: 2013 FRS Whiteout
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
08-27-2015, 07:25 PM | #18 |
My IAT were 98F max, low 93F it must have been around 90F outside and i dont have any source of cold intake.
08-27-2015, 07:28 PM | #19 |
Trying to attach a few logs I've taken.. see if anyone could check out. These are all city drives with the "morning" one having a lot of idle time as i sat in traffic and the rest have some mild throttle applied.
08-27-2015, 07:30 PM | #20 | |
Drives: FT86
The Following User Says Thank You to steve99 For This Useful Post: | yomny (08-28-2015) |
08-27-2015, 07:50 PM | #21 |
Drives: 2017 BRZ
Just to be sure, this happens with A/C off? Maybe you said and I missed it...
Stock, A/C definitely sucks away power. |
08-27-2015, 08:05 PM | #22 | |
Drives: Toyota 86
Your logged IAM = 0.2!! and still has (-ve) corrections. You'll need a better tune or fuel. With that IAM value, you'll be running much more of the Base timing table A (as defined in RomRaider) than Base Timing B (which is what most of the tuners adjust as it affects timing when IAM = 1.0). |
The Following User Says Thank You to ztan For This Useful Post: | yomny (08-28-2015) |
08-27-2015, 08:43 PM | #23 | |
Drives: FT86
side issue do you know the parameters the ecu uses to determine the base timing b to a switching or transition. i know it runs base b plus knock correction max a when iam is 1 so at what point does the transition occurr to base a plus i assume knock correction max a to determine overall base timing plus offsets due temp iat ect ? |
08-27-2015, 08:58 PM | #24 | |
Drives: Toyota 86
Base timing = IAM*(Base timing B) + (1-IAM)*(Base Timing A) IAM*KCA is added to this and then corrections are made to get a final timing value *** Ignore above... I was thinking of Primary OL fuel table which progressively adds in fuel from the OL additive table based on IAM. Just had a look at the dissassembly again and Base Timing tables do not have an obvious IAM modification. The Base Timing A and B tables in A01G are interpolated based on a value stored at FFF8ADB8 - this logs at 1.0 during normal operation (full Base_Timing_B map), and 0.0 (full Base_Timing_A) at startup and shutdown. Last edited by ztan; 08-31-2015 at 10:03 PM. Reason: Initial post wrong |
08-27-2015, 09:29 PM | #25 | |
Drives: '15 FRS
You're also seeing stoich AFR's while making boost, and you really should be seeing some enrichment when boost comes in -- the leaner AFR in boost will cause cylinder temps to shoot up which can cause some detonation. |
08-28-2015, 04:21 AM | #26 |
Considering you have wideband, why aren't you running full closed loop?
Enrichment on throttle as well as boost should be there as mentioned. I will not be loading your car at all with IAM that low, putt around and make sure you have fuel side sorted by getting better fuel to eliminate it from the equation. If it's still happening, you need to get your tuner to do something.
08-28-2015, 05:42 AM | #27 |
Drives: UK GT86
Base A is when the AVCS isn't operational, so when the car is in it's warmup phase
If it's ECUtek, could there be an issue with the hybrid SD? This would be impossible to determine by logs alone though as you would need to see how it's setup. FWIW, I haven't looked at the logs as it seems you have that covered above.
.: Stealth 86 :.
08-28-2015, 05:51 AM | #28 | |
Drives: FT86
here is an easier to read log from yommy http://datazap.me/u/steve99/log-1440...-35-39&solo=33 side issue :-) so your saying base timing A only get used at startup or limp mode and never used after that, ie their is no interpolation from B to A when IAM drops |
Similar Threads | ||||
CDC Autocross - Behavior | echan | Mid-Atlantic | 14 | 06-19-2014 04:48 PM |
Mann Engineering 2nd Quarter Tuning Days April 25th & 26th by Bill (Delicious Tuning) | DesertFrs | Northern California | 14 | 04-24-2014 03:15 AM |
Alarming nanny behavior | mid_life_crisis | Engine, Exhaust, Transmission | 52 | 03-03-2014 10:56 PM |
Delicious Tuning - Dyno Tuning Weekend at Mann Engineering's (San Jose, CA) | DeliciousTuning | Announcements, Contests, Giveaways | 6 | 09-19-2013 05:55 PM |
Visconti Tuning - Latest Forced Induction Tuning Info | Visconti | Forced Induction | 340 | 04-30-2013 06:33 PM |
