Old 08-14-2015, 12:48 PM   #1583
Astroboy
Astroboy's Avatar
Drives: None
Astroboy is offline   Reply With Quote
Old 08-17-2015, 11:18 AM   #1584
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
What over pipe is everyone using? I'm thinking about getting a Perrin.
I have a rattle coming from somewhere in the exhaust at 3k rpm and its driving me crazy.
I did find that a metal bracket was slapping the turbo oil pan because we didn't flatten the lower portion of the rad support bracket. So fixing that and adding bits of extra hose seemed to help in a few areas but the pinging sounds just like a heat shield and its only after it warms up so I'm banking on the OEM OP slapping the frame.. Even though I thought it wasn't supposed to hit anything.
I have the OEM over pipe with 2.75 front pipe and 2.75 evo3
bryan767 is offline   Reply With Quote
Old 08-19-2015, 05:13 PM   #1585
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
@Art_Mighty's Avatar
Drives: Asphalt AVO FR-S w/a Slushbox! :P
For 300-350 on pumpgas don't need bigger injectors.
So the AVO stage I/II kits will go up to 300-350 on pump gas? What's the PSI?
...because some men aren't looking for anything logical, like money. They can't be bought, bullied, reasoned, or negotiated with. Some men just want to watch the world burn
@Art_Mighty is offline   Reply With Quote
Old 08-19-2015, 08:11 PM   #1586
AVOturboworld
Until you start using e85, you are octane limited on power, not injector limited.
The Following 4 Users Say Thank You to AVOturboworld For This Useful Post:
CxG (06-25-2016), Draco_PR23 (08-19-2015), kbogarto (08-19-2015), Sportsguy83 (08-20-2015)
Old 08-20-2015, 12:49 AM   #1587
@Art_Mighty
uosɹǝdʎɐl ʇɹǝdxǝ
Yeah no....(?)
I just tried my Delicious E50 program with some tested E80 and my AFR's and fuel trims were atrocious. At just 9psi in WOT my AFR went from 12 to 16 or more under boost to redline and my fuel trims went from 15 and pegged at 25+. Shouldn't E85 need something like 30% *MORE* fuel?
(For comparison my AFR's on 93 octane are a nice cozy 10.8 at WOT)
...just reporting what I saw
Old 08-21-2015, 01:38 PM   #1588
tshrey
Drives: Black BRZ
AVO said on pump you are octane limited then you put in ethanol and found you didn't have enough injector? How does that disagree with their statement?
Sent from my Nexus 6 using Tapatalk
tshrey is offline   Reply With Quote
The Following User Says Thank You to tshrey For This Useful Post:
SkAsphalt (08-24-2015)
Old 08-23-2015, 05:13 PM   #1589
bryan767
bryan767's Avatar
Hey everyone,
One week on the AVO and I have to say I LOVE IT! Not only does it sound awesome and have so much more power.. but I actually GAINED mpgs! (2.5-3) I was not expecting this at all as most of my old turbo cars were 15-18mph (1jzgte Sc300/400s).
I did find a few things I did not like and need some input!
First off, what size hose should I be using for the line running from the turbo to the turbo oil pan? Mine was brand new and looks like its already melting onto the turbo.. and its starting to seep oil! It has worm clamps (and will be changed out when I replace the hose) but what else can we use here?
The line connecting the other side of the oil pan is also starting to seep at the plastic push joint, any suggestions?
Secondly, I checked everything out last weekend and had to tighten down the bolt holding the long rod bracket. After taking another look today, I found it loosened slightly. I believe this was the source of a vibration at 2.5-3k rpm. If you haven't I suggest taking the bolt out and getting a stainless locking washer. Since adding that, there is no more annoying metal ticking noise.. (I also removed the heat shield from my OEM over pipe).
The Following User Says Thank You to bryan767 For This Useful Post:
Dammod (08-24-2015)
Old 08-24-2015, 12:12 PM   #1590
Jonde875
Drives: GT86
Seriously thinking!!
I am seriously thinking to buy this avo kit for my GT but there is but in my mind...
I just wonder is this right place to ask questions of the right setup for me?
Jonde875 is offline   Reply With Quote
Old 08-26-2015, 02:11 PM   #1591
Draco_PR23
Fiebru
Draco_PR23's Avatar
Drives: Scion FR-S and Integra Type R
Yes, you can ask questions ... there are a few people with different power levels.
Also you can always ask Paul for something more specific of the kit.
Current Cars:
2017 White Platinum Ford Fiesta ST
2013 Raven Scion FR-S
2012 Spruce Mica Toyota Tacoma TRD Off-Road
2000 Phoenix Yellow Acura Integra Type R
Draco_PR23 is offline   Reply With Quote
The Following 2 Users Say Thank You to Draco_PR23 For This Useful Post:
Astroboy (08-26-2015), Jonde875 (08-30-2015)
Old 08-26-2015, 04:09 PM   #1592
Jonde875
Drives: GT86
OK thanks!
I have thinking about stage 2 kit with 3" full exhaust system but first thing that comes in my mind is it too loud for daily driving and second thing what would be the best thing to do for the ECU tune. We have here only one ECUTEC licensed company and he wont do dyno test only roadtest for car. Is that ECUTEC kit good if I do it myself?
Give me some advice and tell your opinions about this...
Old 08-26-2015, 04:39 PM   #1593
AVOturboworld
If you get the full 3" exhaust, but with the catted front pipe, it will be fairly quiet. I daily drive it with the catless front pipe, and it's not that loud for even my older ears. Road noise from the tires is louder than the exhaust still.
Do you know what octane gas you have there? Our free ecutek base tune file will usually be just fine in most cases as long as you have ok gas.
The Following User Says Thank You to AVOturboworld For This Useful Post:
Old 08-26-2015, 08:44 PM   #1594
kbogarto
Drives: 2013 BRZ limited WRB
OK thanks!
From my experience a good road tune can get the car running pretty flawlessly so I wouldn't be scared away by not having a dyno tune.
92 240sx (sold), 03 350z (sold), 13 BRZ (AVO turbo)
kbogarto is offline   Reply With Quote
Old 08-26-2015, 08:45 PM   #1595
kbogarto
And yes the tune from AVO has a pretty good reputation too.
The Following User Says Thank You to kbogarto For This Useful Post:
Draco_PR23 (08-27-2015)
Old 08-27-2015, 04:12 PM   #1596
Jonde875
Drives: GT86
We have here 98 octane gas. They said from fensport that I get the base tune file from them and I drive car here and send them data log to analyze it. Then they will send me updated tune file...and this goes on when my car works correctly (I think they ment this is free from them if I buy kit there).
I have thought this kind of setup from Fensport UK:
-Turbo Kit - Stage 1 & 2 Ceramic Coated Manifold and Turbo
-Breather System For Avo Turbo Kits
-3 Bar Map Sensor
-Ecutek License
-Pro Ecu Programming Kit
-AVO Dump Valve kit Recirculating or 50/50
- AVO 3" Stainless Steel - Full Exhaust System From Turbo Back - With Catalyser
I dont know how many horses that will give and will I blow my engine for too much PSI...
Please say your opinions about this!
avo, avoturboworld
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
OFF TOPIC: Spotted a Gallardo markmatley Hawaii 4 02-24-2013 04:26 PM
