Forced Induction Turbo, Supercharger, Methanol, Nitrous |
View Poll Results: Air oil separator vs. Catch can | |||
Air oil separator | 6 | 27.27% | |
Catch can | 10 | 45.45% | |
Double catch can | 3 | 13.64% | |
Nothing | 3 | 13.64% | |
Voters: 22. You may not vote on this poll |
07-21-2015, 02:17 PM | #1 |
Drives: 2013 Scion FRS
Air oil separator vs. catch can
Hey all,
Just wanted to get some idea of what people are running and why? Air oil separator Catch can Double catch can nothing |
The Following User Says Thank You to snowdog For This Useful Post: | DAEMANO (07-21-2015) |
07-21-2015, 03:22 PM | #2 |
Time Traveller
PCV Side - Mishimoto Catch can w/ Boomba check valve
CCV Side - Nothing, but a vent-to-air separator or second catch can would probably be a good idea. |
07-23-2015, 12:51 PM | #3 |
Drives: 2013 BRZ black
I guess I don't understand the difference between an AOS and a catch can. Can someone please elaborate?
@DAEMANO, What does that Boomba check valve do exactly? Allow oil to drain back to block? |
07-23-2015, 01:25 PM | #4 | |
Time Traveller
A check valve helps prevent PCV failures, leaky gaskets, and blown seals caused by excessive pressurization on a boosted vehicle. Since our PCVs were designed for NA and not FI, a check valve is a cheap ($20-30ish) bit of insurance here. |
The Following User Says Thank You to DAEMANO For This Useful Post: | xkalelx (07-23-2015) |
07-23-2015, 01:58 PM | #5 |
Drives: '24 GR86
In EXTREMELY short:
Catch can will catch the oil and hold onto it, meaning you'll have to check the contents and empty out occasionally. Air Oil Seperator will seperate and then return through the engine.
07-23-2015, 09:01 PM | #6 |
Drives: gt-86 2013
Double catchcans two seperat systems drain it out and through it away dont want this oil,fuel mix going back into your oil supply.
07-24-2015, 08:28 AM | #7 |
Sarcastic SOB
I use a Cusco vehicle specific catch can with stainless steel wool that I stuffed inside. For the 2 weeks I ran at max 9 PSI on my HKS blower it accumulated a tiny bit of oil and I can see no oil inside the throttle body indicating the crank vent doesn't need oil retrieval.
07-24-2015, 12:18 PM | #8 |
Drives: 2014 Scion FRS monogram series
for N/A single catch can (PCV to manifold) should be enough unless you track often. if boosted, i suggest getting a dual catch can.
07-24-2015, 03:58 PM | #9 |
Drives: 2JZ FRS
dual 42 draft design cans vented to atmosphere
07-25-2015, 09:37 AM | #10 |
The Mechanic
Drives: Civic Turbo,FR-S
i dont really get the difference in what your asking lol im running the phastek catch can the separates the air and oil but vents the air back to the engine instead of the open vent. you still have to empty the can tho
Tags |
air oil separator, catch can, turbo |
Similar Threads | ||||
Perrin Air Oil Separator/Catch Can! FS | Batman | Engine, Exhaust, Bolt-Ons | 8 | 03-31-2014 02:02 PM |
Air Oil Separator? Do I need one? | hmong337 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 21 | 12-31-2013 10:14 PM |
FS: Cusco Oil Catch Can (Separator Type) | howiedoit | Engine, Exhaust, Bolt-Ons | 4 | 12-02-2013 12:47 AM |
Crawford Air / Oil Separator - 13+ BRZ/FRS/GT-86 | ngabdala | Engine, Exhaust, Bolt-Ons | 11 | 06-10-2013 09:22 PM |
Crawford Air Oil Separator | JPxM0Dz | Engine, Exhaust, Transmission | 2 | 04-16-2013 09:33 PM |
