Old 07-03-2015, 11:03 AM   #43
snidd111
snidd111's Avatar
Drives: Scion FR-S
I hooked up a vacuum gauge directly to the vacuum line and it gave the same readings as the Defi gauge. So the gauge and sensors are wired and working properly. But that vacuum line doesn't seem to be correct for me. Does it matter that I have an automatic and not a manual?
snidd111 is offline   Reply With Quote
Old 07-03-2015, 12:44 PM   #44
FyeaFRS
Drives: 1992 Nissan Skyline GTS-t Type-M
Do you have ecutek, oft or dash command? 30psi of vacuum seems like a lot.
FyeaFRS is offline   Reply With Quote
Old 07-03-2015, 10:20 PM   #45
snidd111
snidd111's Avatar
Drives: Scion FR-S
I have ecutek. But my OBDII reports normal boost levels, reaching 0 as I have WOT. I removed the T from the brake booster line and ran the line from the spare nipple out of the intake manifold. It's reading normal boost now.
I don't know why that other line is reporting -30psi constantly unless I'm punching the brakes. From all I've seen it should be reporting normal boost levels too.
Old 07-06-2015, 08:18 AM   #46
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Yeah I remeber hearing about something being different for autos...
@spdbydesignchris @spdbydesign
Cockatoo is offline   Reply With Quote
The Following User Says Thank You to Cockatoo For This Useful Post:
snidd111 (07-06-2015)
Old 07-06-2015, 09:04 AM   #47
snidd111
snidd111's Avatar
Drives: Scion FR-S
That must be it. Luckily since the intake has the spare port things are working properly. Hopefully whoever finds this post since it's still a top Google result in the future will have everything they need to get things installed quickly for a manual and an automatic now
Old 07-06-2015, 10:50 AM   #48
spdbydesign
spdbydesign's Avatar
Drives: 2010 Nissan GTR
Yep, for the automatic, you'll need to tap the line right off the back of the intake manifold.....
spdbydesign is offline   Reply With Quote
Vortech Supercharging System Update - More boost, more POWER! Brian@Vortech Forced Induction 337 03-12-2016 03:42 PM
DIY - Defi 60mm Boost Gauge Install in AC Vent msile DIY (Do-It-Yourself) Guides 55 02-27-2016 01:10 PM
Which boost gauge? Bigmaxy Forced Induction 3 07-07-2013 07:11 PM
Memorial Deal!!White MaxTow 30 PSI Boost/Vacuum Gauge Tubano-shop Interior Parts (Incl. Lighting) 0 05-27-2013 07:47 AM
Temperature Gauge a dummy gauge? bambbrose BRZ First-Gen (2012+) -- General Topics 40 08-19-2012 04:29 PM
