07-02-2015, 07:59 PM | #43 |
Drives: Slow
07-02-2015, 08:01 PM | #44 |
07-02-2015, 08:04 PM | #45 |
Site Moderator
Drives: ichi 86 Project
07-02-2015, 08:09 PM | #47 |
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
I'm not real fond of boxer motors from past experience... when it was announced that the 86 would be using a Subaru boxer motor my first reaction was: "Why?" I understand the technical reasons for going with a Boxer motor... but even so, give me an I4 every time over a flat 4. It's not like Toyota doesn't know how to make nice I4 motors perfect for sportscar use.... Was really hoping for a motor somewhat following 4AGE lineage, a nice rev happy one in the 2L range.
That said, I bought the car in spite of the motor that was put in it because even with that Subaru motor in it, I still wanted it - the only car in two decades that I have wanted enough to buy new. The FR-S has been the best Subaru I've ever owned along with being the worst Toyota I've ever owned at the same time... The FA20 is 'okay' as a motor mechanically other than the low oil pressure with high engine bay temperatures (I've noticed little issues start appearing once the oil temp gets over a constant 220F - really want to get an oil pressure gauge for this car.) It has a nice, smooth power delivery characteristic that I do like with a broad torque range that works well for daily driving. From 5K through redline the motor is really at home, just not as rev happy a motor as a Honda. The little quirks bug me though; the check engine light coming for ignition coil issue (stock motor no tunes or tinkering with it) and little hiccups it has not wanting to start sometimes - it's definitely not a Toyota or Honda level drivetrain in actual execution. I would definitely feel more at ease with an actual Toyota motor in it... My 2RZ powered Tacoma was bulletproof and I beat on it and redlined it daily for 170k miles...autocrossed it, tracked it, offroaded it, and cruised cross-country with it. And then there was the B18A in my '90 Integra RS....sweetest non-vtec I4 Honda motor that can take abuse and has a very nice rev-happy characteristic about it. With 8lb racing flywheel that motor LOOOVED to rev and increased/decreased RPMs extremely quick. It was a solid motor that you could use the full RPM range all day long, for 200k miles...and sounded very good as well. The FA20 just can't take the same abuse...it throws a fit and starts balking, you have to baby it to keep it happy. Babying a motor to keep it from throwing fits doesn't sit well with me...I don't care about power levels as much as a robust motor you can beat on daily and gives zero complaints back - the FA20 is not such a motor from my experience. Or maybe it's just the early one's issue? Not sure what I want to do in the future, but I absolutely know I want to keep the car. Just unsure of what to swap out the motor for when the FA20 finally lets go from not being up to the task...
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
The Following User Says Thank You to Vracer111 For This Useful Post: | frsvr4 (07-05-2015) |
07-02-2015, 08:10 PM | #48 |
Drives: 2013 asphalt fr-s
Years ago when I heard Toyota was working on the small sports car (FRS) my fear was the they would use the 2AZ-FE (I4 from Camry/RAV4) engine, 6500 rpm red line, 177 hp in RAV4 trim. IMO Toyota made a good decision going to Subaru for a engine. If you've every wound the RAV4s AZ engine to redline you'll agree. The Toyota AZ is tough as nails, but sounds like bees in a box to me.
The Subaru engine feels like it loves spinning all the way to redline all the time. Bottom line, I like the Subaru boxer, "REAL" or not. Sent from my iPhone using Tapatalk |
The Following User Says Thank You to Iand518 For This Useful Post: | strat61caster (07-02-2015) |
07-02-2015, 08:14 PM | #49 | |
Site Moderator
coil #1 or #3? |
07-02-2015, 08:18 PM | #50 |
Drives: Slow
The Following User Says Thank You to civdaddy For This Useful Post: | ichitaka05 (07-02-2015) |
07-02-2015, 08:21 PM | #51 | |
07-02-2015, 08:21 PM | #52 |
P0351 code... so coil #1. Going to get newest revision coil pack and do whatever I can to get heat out of the engine bay along with protecting all the coils thermally. Gold foil tape, heat shielding, ducting with active airflow, and making the TRD fender vents actual functional vents in addition to their primary aerodynamic deflector role is where I'm heading...
The Following User Says Thank You to Vracer111 For This Useful Post: | Tcoat (07-02-2015) |
07-02-2015, 08:25 PM | #53 | |
Site Moderator
07-02-2015, 08:34 PM | #54 |
Plenty of stock cars with this issue reading the massive P0351 issue thread....it will happen to all 86's given enough heat in the system. I live in a really hot & humid climate, so I imagine that accelerates things too along with oil temps reaching 220+ range daily...
07-02-2015, 08:37 PM | #55 | |
Why would you think Camry motor and not a newer version of this? [ame="https://www.youtube.com/watch?v=sbXTAI_guvk"]4AGE 20v Blacktop 110mm Open Trumpets At Full Throttle - YouTube[/ame]
The Following User Says Thank You to Vracer111 For This Useful Post: | Ultramaroon (07-02-2015) |
07-02-2015, 08:44 PM | #56 |
Priceless! A Camry with velocity stacks. Does that make the bees sound louder?
Tags |
stupid thread |
Similar Threads | ||||
Who's tired of the "Pedal Dance" and wants to be in real control of their car? | FT-86 SpeedFactory | Tracking / Autocross / HPDE / Drifting | 61 | 10-01-2015 07:44 PM |
Toyota/Subaru D4S "engine cover" rattle | canadaRS1.0 | Issues | Warranty | Recalls / TSB | 4 | 06-14-2015 07:12 PM |
Are there varying levels of engine leaks? Apparently this isn't considered a "leak" | tracerit | Issues | Warranty | Recalls / TSB | 9 | 05-26-2015 04:02 PM |
2015 Series.Blue Engine "Chirp"and 2nd Gear Grind | s30series | Issues | Warranty | Recalls / TSB | 33 | 09-07-2014 01:26 AM |
"Hot" smell coming from engine after latest OpenFlash - 1.59 | Kody | Software Tuning | 25 | 04-15-2014 05:07 PM |
