#71 |
Drives: Scion FR-S A/T, Whiteout
I think your map is a good middle ground between standard and sport as it is. If we can get the low RPM, high load scenario figured out, you'll probably be able to extend prespool down lower in the RPM range.
#72 | |
Lightning McQueen Driver
Drives: Limited Red 6MT BRZ
Working on the procede map currently. Also I really like my new map on e85. Going to try to keep the performance the same while implementing safety features. Sent from my iPhone using Tapatalk
Installed Mods: Phantom Electric Super Charger | Open Flash Tune | Perrin OP/ HFC Front pipe | Invidia Q300 catback | ST Suspension | JDL Header | Flex Fuel |
#73 |
Here's revision 2: @PantsDants Want to try out the same scenario?
https://drive.google.com/file/d/0B1R...ew?usp=sharing
#74 | |
#75 |
Drives: DGM BRZ 6MT
@Shiv@Openflash, I am having trouble connecting my laptop to the PROcede controller for some reason. I am using Windows 7 on my Macbook. I have all the wires tapped except the black audio switch (not sure if that matters).
When I connect it to my computer, it detects the controller as a device, but I cannot make it go online on the procede software. The only difference I see between my laptop and the readme is that the device USB is named "CP210x" instead of "2P210x". ![]() When I change the COMM SETUP to COM3 and click on Go Online/Offline, nothing happens. It's not giving me an error, just nothing. This is different from when I try another port. I.e., when I change the setup to COM1 and click Go Online/Offline, it'll give me an error that says "Unable to open COM1".
#76 |
Drives: Firestorm FR-S AT
The software will not connect to the Procede unless the ignition is on.
Phantom Electric Supercharger with Procede controller, GReddy SP Elite, CA-FI Dashlinq4
#77 | |
Drives: DGM BRZ 6MT
The ignition was on when I was trying to connect to it. Sent from my iPhone using Tapatalk
#78 | |
Drives: 2011 Outlander XLS, 2013 FR-S Blue
There is a SINGLE wire running to the foot switch. There are TWO wires running to the LED/power switch box. Robs instructions say to test the two wires going to the micro switch but that makes it sound like the foot switch. I need to cut off the 3.5mm jack off the proceed harness, and I need to tap it to something. Also, the procede box I got, the wires were of such lengths that the unit should be on the DRIVER's side (short power and ground) with 2 loooong wires going to the ECU taps, and the 3.5mm jack soon to be cut off and spliced into ... something. |
#79 | |
All installed, on the drivers side, with the foot switch center/red wire soldered to the now-removed 3.5mm plug wire on the procede side. Going to try Sojhinn's map and report back tomorrow. |
#80 | |
Snag rev 2. I added a few safety features... Few posts back. Sent from my iPhone using Tapatalk
#81 | |
Drives: DGM BRZ 6MT
My foot switch center wire is white. I still need to find a multimeter to test which one I need to tap from the WOT switch conductors. Sent from my iPhone using Tapatalk
#82 |
I had already cut the switch, so I just tried both (one at a time) turned the car on and saw which one made the volts drop while rev'ing it.
The Following User Says Thank You to Khyron686 For This Useful Post: | TM (05-31-2015) |
#83 |
Any feedback?
#84 |
Addicted
Drives: 2013 Asphalt FR-S 6MT
Haven't had an opportunity to test it yet. I'm still getting a feel for the standard map which I now think could activate a bit earlier. I'll try the new map soon.
Phantom Supercharger | Tsudo Cat-Back Exhaust | K&N Drop-in Filter | Winjet Headlights | Opti-coated | 35/20 Tint | Radar/Dashcam Hardwired | OFT tuned | OEM Audio+ Reference 400CF | Uber Sound Deadened | LED DRL strips | JPM Coachworks Kneepads
What does your user name mean? | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 356 | 05-01-2016 08:52 AM |
OFT: New firmware and new user software | Shiv@Openflash | Software Tuning | 9 | 10-15-2014 02:45 PM |
EcuTek End User/Retail Tuning Software Release! | Dustin@Dynosty | Forced Induction | 27 | 12-19-2013 09:17 AM |
user tags | scottmcphee | Site Announcements / Questions / Issues | 3 | 04-11-2013 03:15 PM |
User name | trueno86power | Site Announcements / Questions / Issues | 7 | 11-28-2012 12:48 AM |
