Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
05-05-2015, 08:02 AM | #15 |
Drives: Subaru BRZ 2015
05-05-2015, 08:32 AM | #16 |
05-05-2015, 08:47 AM | #17 |
Drives:
The Following User Says Thank You to N234 For This Useful Post: | Racecomp Engineering (05-05-2015) |
05-05-2015, 09:35 AM | #18 |
Drives: MT WRB BRZ Limited, 2007 911s
100% this! I spent my first year autocrossing a stock BRZ and learned a ton about how to handle this car at the limits. There were a lot of spinouts that first year but you're in a safe environment and every one is a good learning experience.
The Following 2 Users Say Thank You to was385 For This Useful Post: | CSG Mike (05-05-2015), Racecomp Engineering (05-05-2015) |
05-05-2015, 03:29 PM | #19 | |
As @racecompengineering said, an AutoX or a Skidpad day is the perfect way to learn. Watered skidpads are even better! |
The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (05-05-2015) |
05-05-2015, 06:41 PM | #20 |
Looks fun too!!
[ame="https://www.youtube.com/watch?v=j8qggahGNH0"]Toyota 86 Traction Control Demonstration [SKIDPAD] - YouTube[/ame] WEEEEEEEEEEE! [ame="https://www.youtube.com/watch?v=Od3NQoPZeso"]Scion Frs Skid Pad Test - YouTube[/ame]
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
09-12-2015, 03:26 AM | #21 |
Drives: GTS 86 auto
I now have 38 front 34 rear. Previously I had little feel for what the front or back was doing. Now it is easy to tell. Call me insensitive if you like.
Surprisingly the front does not feel harsher but certainly (even) more accurate. The car is less twitchy feeling and more chuckable into corners..
GTS86 Auto (Australia)
Similar Threads | ||||
FS: OEM FRONT PIPE & CAT BACK | Privman | Engine, Exhaust, Bolt-Ons | 0 | 04-07-2015 07:39 PM |
FS: OEM Cat Back & Front pipe | Privman | Wheels and Tires | 0 | 04-07-2015 07:34 PM |
Front end sounds loose | Jamesbrz | Issues | Warranty | Recalls / TSB | 23 | 02-14-2014 08:28 AM |
18x8.5 with 235x35 on all 4 corners OR 18x8 front + 18x9.5 back 235/35 + 255/35 back | KSpider | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 09-14-2013 07:06 PM |
FRont back up lights | Subabie | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 03-08-2013 01:07 PM |
