Old 04-20-2015, 09:16 AM   #1
geruta
Catless Front Pipe VS Test Front Pipe. What's the Difference?
I was looking on ft86 speed factory for a new front pipe. I want to go the catless/test pipe route. But honestly, I can't tell what the difference is.
The test pipes do look a bit straighter and most of the catless labeled pipes appear to have a more slightly curved look. But other than that, can't tell.
Is it just a marketing thing? Or is there truly a difference? In which case if there is, what makes one different from the other?
Thanks.
geruta is offline   Reply With Quote
Old 04-20-2015, 09:28 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
same
The Following User Says Thank You to zc06_kisstherain For This Useful Post:
geruta (04-20-2015)
Old 04-20-2015, 09:46 AM   #3
geruta
Awesome! Thanks for the clarification.
So essentially it's just a marketing reason then to label it as one or the other?
Old 04-20-2015, 09:48 AM   #4
raven1231
Yeah both are straight pipes without a cat
geruta (04-20-2015)
Old 04-20-2015, 11:51 AM   #5
geruta
Right on!
Another question if I may,
What seperate the quality between a cheaper Tanabe Front Pipe at $152 vs a more expensive one for example Motiv Concepts Test Pipe at $224?
If they are exactly the same thing, then it seems dumb to spend more on the Motiv over the Tanabe. But if there are other things to consider like one being more polished on the inside, one having better alignment, one using better materials, one being better welding, etc.
Then I want to know what what I risk by buying the Tanabe at a cheaper price over buying the more expensive front pipes.
Old 04-20-2015, 12:30 PM   #6
raven1231
both are very high quality, and neither will disappoint. I'm sure the welds, material, and quality difference between the two, and given what it is, are marginal.
geruta (04-20-2015)
Old 04-20-2015, 12:31 PM   #7
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
The difference is one stinks, and one doesn't. You will find a negligible difference between both while N/A. Turbo is a different story. I say keep the cat to keep people behind you from choking and black crap forming around your bumper and exhaust tips. Also the cat helps with rasp as you upgrade the rest of the exhaust as it acts as a slight resonator.
2016 Camaro SS is offline   Reply With Quote
Old 04-20-2015, 12:32 PM   #8
raven1231
Well both a catless front pipe and test pipe have zero cats. SO....both will stink as they are essentially just different names for a straight pipe.
Old 04-20-2015, 12:35 PM   #9
2016 Camaro SS
Drives: Fast
For some reason I thought this was comparing a catted and a catless. Woops.
They're the same thing just as said above, and yes, they both stink, lol.
The Following User Says Thank You to 2016 Camaro SS For This Useful Post:
raven1231 (04-20-2015)
Old 04-20-2015, 12:47 PM   #10
geruta
Sorry for the confusion but I'm switching now to difference between one brands catless front pipe to another's. Thanks to raven1231 for your opinion. Anyone else?
Old 04-20-2015, 12:47 PM   #11
akahenry
akahenry's Avatar
Drives: '18 STi
a test pipe and a catless front pipe is basically the same thing lolzzzzzzzzzz
+1 to keep a cat.
akahenry is offline   Reply With Quote
Old 04-20-2015, 12:58 PM   #12
geruta
Why keep the cat? I'm doing it for making my existing greddy axel back a bit louder as I love the looks and sound, just not loud enough.
Catted will reduce potential loudness right?
Old 04-20-2015, 02:12 PM   #13
zc06_kisstherain
Drives: SWP BRZ
ok. you need to search in forum. all the questions you asked, answers are in this forum.
answering last one here.
catted will reduce loudness but not very much! Exhaust will tribute most of loudness as well as Header (if you getting it catless later)
Overpipe, Front pipe adds sounds little but not much!
I've owned both Motiv Catless FP & Berk Catted FP and it's barely hear difference.
Old 04-20-2015, 03:23 PM   #14
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
I would have to disagree. Having a catted front pipe is quieter than having no cat.
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
FS: Motiv Concepts Test Pipe (catless front pipe) $175 shipped s30series Engine, Exhaust, Bolt-Ons 2 12-03-2014 02:40 PM
invida catless over pipe and front pipe bnb kingkai23 NY / NJ / CT / PA 0 03-14-2014 06:32 AM
PTUNING Weekly Special: Invidia Catless Front-pipe / Test pipe $229 INSTALLED! Patrick@Ptuning Engine, Exhaust, Bolt-Ons 3 10-01-2013 03:16 PM
What is the difference between a Front pipe, a down pipe and an over pipe? liajet24 Engine, Exhaust, Transmission 5 09-19-2013 10:03 PM
Track pipe + catless front pipe diss7 Engine, Exhaust, Transmission 21 10-09-2012 01:10 AM
