#155 |
Drives: UK GT86
Whatever you do don't take the stock O2 sensor output as what's happening, it won't necessarily be accurate.
How are you reading the AFR of the wideband? Custom map result from the ECU in logs or just the visual display in the car? If it's properly setup you could easily rescale the stock sensor to your wideband output, especially if the wideband in a similar position. Or you could not bother and log the wideband output rather than the front O2. So long as the difference is minimal around the CL area, which it should be, then it won't have much of an impact on fueling error.
.: Stealth 86 :.
#156 | |
Drives: 86 GTS White
I'm looking at the visual display and the custom map result from ECU logs. Just to confirm, I should do this: 1. Scale the custom map output to match the visual display. 2. (Optional) Rescale stock O2 sensor based in wideband data. Do I have this right? |
#157 | |
Drives: UK GT86
.: Stealth 86 :.
#158 | |
However, the reading from the ECU is a constant ~0.25 less than the reading on the display. It's an AEM Failsafe gauge. I might have to just live with it. |
#159 | |
Drives: UK GT86
.: Stealth 86 :.
#160 | |
http://www.datazap.me/u/skorov/aem-f...log=0&data=3-6 Do you think this is an acceptable error? Thanks! |
#161 | |
Drives: UK GT86
So long as your closed loop operation is scaled using the OEM sensor to reduce trims, use the wideband just to keep an eye the sensor isn't failing over time. Remember to try and calibrate the wideband every once in a while. Most recommend annually.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Skorov (04-07-2015) |
#162 | |
I want to use the rear O2 to rescale the open loop portion of the MAF sensor. Any reason why that's a bad idea? |
#163 |
Drives: UK GT86
Nope, that's what you should do. To make it more accurate you could set a flat AFR in the fuel table, and if you're using vgi's tool remember to increase the row offset by 1 or 2.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Skorov (04-08-2015) |
#164 | |
Senior Addict
Drives: 86 GT
#165 |
Drives: UK GT86
Could I recommend the NGK AFX, or it's replacement as it's now discontinued. Better sensors which are likely to last longer and be more accurate.
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | Fizz (04-23-2015) |
#166 |
Senior Addict
Drives: 86 GT
#167 |
Drives: UK GT86
This is basically a replica of the NTK AFX - Make sure you go for the NGK sensor, that is what I was told.
AFR500 Or NTK's replacement for the AFX: NTK AFRM
.: Stealth 86 :.
#168 |
Senior Addict
Drives: 86 GT
Thanks, but lol at the backorder till June 2015. Anyways I found a very good deal on the AEM UEGO so might jump on that instead...
BRZ Front and Rear LED Turn Signal Bulbs | convoy | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 11-25-2013 07:51 AM |
Aftermarket Rear Diffuser | Realm | Cosmetic Modification (Interior/Exterior/Lighting) | 8 | 05-08-2013 11:23 PM |
FS: BNIB Concept Three LED Amber/White signal bulbs Front and Rear with Relay | xxscaxx | Exterior Parts (Aero, Lighting, Etc.) | 10 | 03-27-2013 10:17 AM |
DIY: front and rear LED turn signal bulbs | jjdrivesajazz | DIY (Do-It-Yourself) Guides | 6 | 10-15-2012 09:53 PM |
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** | Titanmotorsports | Audio/Visual, Electronics, Infotainment, NAV | 2 | 09-14-2012 12:42 PM |
