Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
03-26-2015, 02:06 PM | #15 |
Drives: '13 asphalt frs
03-26-2015, 02:13 PM | #16 |
Drives: JAWS
That's your problem. Undo the overpipe to front pipe connection (use PB Blaster or wd-40 and let it sit for at least a few minutes before trying) after that get everything lined up with bolts hand tight, then start tightening at the header to engine bolts. Then tighten the overpipe to frontpipe. Then torque everything in that same order. If it still doesn't line up, you have a fitment issue.
03-26-2015, 02:14 PM | #17 |
Drives: Red BRZ
Never seen fitment issues on a Tomei... The flange isn't bent or anything is it? Also; I'd strongly reccomend disconnecting everything from the header itself, and then installing the header. No over\downpipe etc, just the header alone going on, and then connect everything else.
03-26-2015, 02:23 PM | #18 |
Drives: 2013 FRS Whiteout
When you say other side is on makes me think you pushed in one side completely, you do know you should try and push in both sides at the same time, making the studs come through evenly?
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
The Following User Says Thank You to yomny For This Useful Post: | strat61caster (03-26-2015) |
03-26-2015, 02:57 PM | #19 |
I feel like you are doing something incorrectly here. I bought my UEL tomei from myjdmparts on Amazon two weeks ago, and had infamous performance install it last week. They had no fitment issues, and the car runs and sounds great.
03-26-2015, 03:05 PM | #20 |
Drives: frs
Or you can go to a muffler shop for installation.
03-26-2015, 03:10 PM | #21 |
Sweeper
people who are saying I had no issues when I bought my Tomei aren't winning
people who are suggesting the dude takes 10 minutes to undo all exhaust components before attempting the header are winning |
The Following User Says Thank You to Koa For This Useful Post: | Bergen23 (03-26-2015) |
03-26-2015, 03:21 PM | #23 |
Sweeper
The Following 3 Users Say Thank You to Koa For This Useful Post: |
03-26-2015, 03:50 PM | #24 |
Did you loosen the joint and try to spread it apart or push it together to make it fit?
The Following User Says Thank You to vroom4 For This Useful Post: | RobertPaulson (03-26-2015) |
03-26-2015, 04:06 PM | #25 |
I took a hammer and tap it a couple times till it went in. End of story haha
The Following User Says Thank You to P_say86 For This Useful Post: | chas3wba0 (03-26-2015) |
03-26-2015, 04:07 PM | #26 |
P.s I tried everything and every suggestion
03-26-2015, 04:36 PM | #27 |
Ok, well that is the correct method, so congratulations.
Make sure you re-torque in a few days. |
The Following User Says Thank You to vroom4 For This Useful Post: | MokSpeed (03-26-2015) |
Similar Threads | ||||
WTB Tomei Type 80, Tomei UEL headers | Justin91M | Want-To-Buy Requests | 1 | 12-19-2014 11:42 AM |
FAIL! X3 | paulca | Other Vehicles & General Automotive Discussions | 9 | 07-29-2014 06:27 PM |
Tomei Exhaust with Tomei Straight Pipe | leech | Engine, Exhaust, Transmission | 10 | 01-07-2014 10:42 AM |
fail | BRZPDX | Northwest | 24 | 11-21-2013 07:24 PM |
If the FT-86 is a fail...what will you do? | SteelReign | Scion FR-S / Toyota 86 GT86 General Forum | 172 | 04-28-2011 02:49 AM |
