02-27-2015, 10:11 AM | #71 |
I'm running 205/50/17 winter tires. Love 'em.
03-03-2015, 11:53 PM | #72 |
Drives: Subaru BRZ-Black
Continental Extreme Contact DWS. Car drive really well with them even in fairly deep snow. Turn off the traction control and it was a nightmare.
03-03-2015, 11:58 PM | #73 |
PandaPandaPandaPandaPanda
Drives: 2015 BRZ Limited CWP
So I had a bad (or fun? scary fun..) time this past Sunday.
Weather predicted 1-3" of snow max. Roads were not preemptively salted and plows did not seem ready to come out ASAP. Likely because of the low estimates. Also because of the low estimates, I figured I would be fine driving. Made it to dinner. Getting back was a different story. Ended up coming across a hill in Bayside, Queens where the road was completely unplowed and there was around 4-5" of snow. Going up the hill, my back wheels lost traction and slid towards the right, I managed to correct/stop before I spun completely. Ended up turning off traction control and rocking myself up the hill at a 45degree sideways angle to the lane. Even when I got to the flat part, my rear wheels gave away again and I had to stop before regaining control and moving forward. Sigh. Definitely need to avoid the snow until I get winter tires. |
03-04-2015, 10:43 AM | #74 | |
Hail Magnet
The Following User Says Thank You to HunterGreene For This Useful Post: | MTCRX (03-04-2015) |
03-04-2015, 10:55 AM | #75 | |
My downfall was trusting the weather forecast this past weekend, combined with unplowed roads. But as long as you're not a complete retard when driving in bad conditions, you'll make it home. Planning to get new wheels in the summer after I get more use out of OEM tires and then I can use my OEM wheels for snow tires next winter. But thanks for your helpful post. |
03-04-2015, 11:04 AM | #76 | |
Hail Magnet
I'm glad you are safe and lucky in this instance. But I am assuming you read this thread and others, the "Guess I shouldn't have driven my car in snow without winter tires" statement is almost cliche at this point. Hence the sarcasm. |
03-04-2015, 11:22 AM | #77 |
Drives: BRZ DGM Limited
MORE SNOW COMING FOR THURSDAY!
03-04-2015, 11:33 AM | #78 |
Drives: Whiteout FRS- autocross ready
03-04-2015, 11:46 AM | #79 | ||
Drives: 2013 GBS BRZ Limited
I took my BRZ out in the beginning of a snow storm on the stock tires. It was PURE LUCK that I did make it home. I disabled the TC/VSC system before I left and when IT RE_ENABLED ITSELF at 50 MPH on the highway, it spun the car directly into oncoming traffic. If the car coming straight at me had not been able to go around me on the shoulder it would have totalled both of our cars. DO NOT TAKE THESE CARS OUT IN THE SNOW WITH THE STOCK TIRES. PERIOD. EVER. PERIOD. Quote:
The Primacys might as well be made out of granite below 40 deg F. |
The Following User Says Thank You to stugray For This Useful Post: | MTCRX (03-04-2015) |
03-04-2015, 12:50 PM | #80 | ||
And I didn't even go past 30mph (even on the highway) when I got caught out in the snow. Basically limped it home as safe as I could. I did leave all the TC/VSC safeties on except for when I got stuck and had to rock my way out of it though. I'm well aware of all the risks of driving in the snow with this car thanks to these forums. So was it stupid? Yes it was, and I figured I'd share my experience here to further reinforce how stupid it is for future new drivers. I figured that's what the thread was for. Which is why I didn't appreciate sarcastic comment, regardless of whether or not it was warranted. I can't say I regret it though. No one was hurt, nothing was damaged, and its something I wont ever forget. So luckily I can take it as a learning experience. EDIT: Kinda scary that the TC/VSC would re-enable itself... I didn't think it'd do that. |
The Following User Says Thank You to PandaSPUR For This Useful Post: | Lo (03-04-2015) |
03-04-2015, 01:13 PM | #81 |
Time Traveller
Gonna re-post the whole thing because it's apparently not common knowledge.
From TireRack - http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=273 Don't Drive Summer Performance Tires in Cold Temperatures When faced with near- and below-freezing temperatures, drivers should leave their summer performance tire-equipped vehicle at home and drive a vehicle equipped with all-season or winter tires. Summer performance tires feature tread compounds engineered to provide traction in warm to hot ambient temperatures. They were never intended to experience near- and below-freezing temperatures, nor the wintry driving conditions that often accompany them. As ambient temperatures get colder, typically in the 40-45° Fahrenheit range, summer performance tires lose a noticeable percentage of traction as their tread compound rubber properties change from a pliable elastic to inflexible plastic. The tire industry uses the term "glass transition" to describe the temperature where a summer performance tire's grip/slip performance changes dramatically. This means the summer performance tires that provide predictable traction in warm to hot conditions will be found to be very challenging to drive in cold to freezing temperatures. This is especially true when the tires first begin to be driven or if the driver aggressively applies gas pedal pressure with today's turbocharged fours or high-torque sixes and eights. Fortunately, glass transition is a reversible condition that allows the tires' normal traction to return as the ambient temperatures climb. If ambient temperatures drop to near- or below-freezing, driving or rolling a vehicle equipped with summer performance tires risks the possibility of tread compound cracking. Tread compound cracking is a permanent condition that requires the tires to be replaced. The other condition that can be caused by running summer performance tires in cold temperatures is the possibility of chipping away the edges of the tread blocks. Since both of these conditions only occur as the result of what's considered improper use or storage, they are not typically covered by the manufacturer's warranty. |
03-04-2015, 01:13 PM | #82 |
Drives: 16 CBS WRX Limited
^Best part of that post is that you pasted it twice for people that will just skim it!
03-04-2015, 01:16 PM | #83 |
Time Traveller
03-04-2015, 01:33 PM | #84 |
Similar Threads | ||||
Brand new FRS, no snow/sport mode?? What the hell?? | Sambo FRS | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 01-06-2015 12:51 AM |
The hell is BMW doing? | dem00n | Other Vehicles & General Automotive Discussions | 39 | 01-27-2014 11:15 AM |
snow....starting to like snow! | brzr | CANADA | 19 | 01-23-2014 12:10 PM |
Stay safe in snow 86ers. Don't go out with crap stock tires, only snow tires | stockysnail | Northwest | 36 | 12-19-2013 01:12 PM |
Hell yea!! | _F-R-S_ | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 1 | 11-23-2012 08:46 PM |
