Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
02-03-2015, 08:59 PM | #2283 | |
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | YouShallKnow (02-03-2015) |
02-03-2015, 09:00 PM | #2284 |
They are free! I'll go alk and skip the bump steer kit. Thanks for your guidance I really appreciate it.
The Following User Says Thank You to YouShallKnow For This Useful Post: | Racecomp Engineering (02-03-2015) |
02-10-2015, 05:01 PM | #2285 |
Junior
Drives: a car
@TekPrime -his question, saving some time here.
"Would someone mind explaining how the roll center is adjusted on our double wishbone emulated multi link rear suspension? I'm looking to understand how the geometry changes under force. Thanks for your help!"
The Following User Says Thank You to cdrazic93 For This Useful Post: | TekPrime (02-10-2015) |
02-16-2015, 03:59 PM | #2286 |
Drives: 2013 FRS Whiteout
If you had to recommend a group or set of bushings to a beginner for upgrading, what would you say was the best bang for the buck to eliminate some o that elastic feeling in corners when grippier tires have been added. Is this one of those subjects where you should replace them all or you could do the rear subframe bushings then front control arms...? Thank you.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
02-23-2015, 09:37 AM | #2287 | |
Front control arm (front) bushing. Whiteline ALK steering rack bushings Rear: trailing arm front crossmember inserts diff bushings rear upper control arm bushings (either the camber adjustable or the fixed) I bolded the ones I recommend most and are the better bang for the buck. The others are good too. Might as well do as many as you can stand at the same time since they're almost all kind of a pain to install. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | yomny (02-23-2015) |
02-23-2015, 02:43 PM | #2288 |
So I ended up taking your advice, I removed the Swift Sports springs replacing them with BRZ front springs and FR-S rear springs for the stiffest OEM springs possible.
Then I installed (or tried to) the Whiteline ALK, but I thrashed my ball joint boots in the process so I need to replace them now. No dealerships have them in stock, soonest they can get them is Wednesday. So I'm considering picking up the Whiteline roll center / bump steer kit just so I can get my car on the road today. But now that I'm at stock ride height, I know there won't be much benefit. My question is, will using the roll center kit HURT my handling at stock ride height? Or will I just not see much of a benefit? I'm fine having the kit installed because I sure as hell never want to take my control arms off again and I will probably go lower again in the future once I get money for proper coilovers, but I also don't want to spend time and money on a part that hurts my handling. Thanks for all your help, this thread is massively helpful to newbies like me. My other option is to wait 2-3 days for the dealership to get stock ball joints in. What do you think? |
02-23-2015, 03:03 PM | #2289 | |
Drives: MT WRB BRZ Limited, 2007 911s
02-23-2015, 03:10 PM | #2290 | |
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | YouShallKnow (02-23-2015) |
02-23-2015, 03:13 PM | #2291 | |
- Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | was385 (02-23-2015) |
02-23-2015, 03:23 PM | #2292 |
The Following User Says Thank You to YouShallKnow For This Useful Post: | Racecomp Engineering (02-23-2015) |
02-23-2015, 03:30 PM | #2293 | |
Sweeper
I have those bushings as well- If one perceives it as "clearer feedback" than introduced NVH, then you'll love the mods |
The Following User Says Thank You to Koa For This Useful Post: | sunset_blvd (02-24-2015) |
02-23-2015, 07:17 PM | #2294 |
Undisputed El Presidente
Drives: Zenki 37J ZN6
That's really true. I have the subframe insets and rear UCA bushings and some would say NVH has definitely increased but I think it is just better connected to the road. However, I think its my limit so no more bushings for me as long as this remain my DD
The Following User Says Thank You to finch1750 For This Useful Post: | yomny (02-23-2015) |
02-24-2015, 02:22 PM | #2295 |
Drives: Lava 2014 Scion FRS
I just saw that you guys carry the "Whiteline MOTORSPORT Front Lower Control Arm Assembly Kit", but there is no picture or description. Can you give us some more information on this? Have you had any experience with it on your cars?
02-24-2015, 08:20 PM | #2296 | |
Part number KTA147. - Andy |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
