steve99
Old 12-18-2014, 05:45 PM   #253
rcampici
Drives: GTS86
Originally Posted by Koa View Post
Dude.. you've been acting like a complete douche about OFT. (refer: http://www.ft86club.com/forums/showpost.php?p=1971497&postcount=12 ) Now dismissing one of the people who has done so much for the community?
Kick rocks, seriously. Go put that "experience in programming and computers" to use and figure it out yourself
Lovely
Not Banned really?
You should add brown neck ring.
rcampici is offline   Reply With Quote
Old 12-18-2014, 05:50 PM   #254
Koa
Sweeper
Koa's Avatar
Originally Posted by rcampici View Post
Lovely
Not Banned really?
sucks you don't have any people experience given your other accolades. Must be a lonely life you lead with an attitude towards others like that
Any time you want a refresher course on how to refresh web pages, though, let me know. I'm no CS savant, but I can press F5
Old 12-18-2014, 06:00 PM   #255
rcampici
Drives: GTS86
You forgot to add Keyboard warrior to you accolade.
And just for your information I help lots of people on Aus Forum and I am appreciated as I do so without attaching a demeaning ego trip.
And yes its best to work things out for ones self, it saves lots of bulshit from people like you.
As far as people skills are concerned, you need to look in the mirror.
As far as computer skills, the point was that a well written web site does not require to refresh the page to access latest information.
But I see you are a follower rather than a leader and as sheep do, follow the leader.
Also while you are at it, look on how many are moving away from the OFT for lack of support, what does that tell you? DON'T ASWER THAT
So be a good fellow and just go away.
Old 12-18-2014, 08:32 PM   #256
Koa
Sweeper
Koa's Avatar
aaaaahahahahahahahahahaha oh Robert. The only arena you lead in is douchebaggery. Carry on in your fickle, sad little world
Old 12-19-2014, 08:35 AM   #257
s2d4
s2d4's Avatar
Man, that dude give Aussies a bad name......
Keep up the good work Steve.
The Following User Says Thank You to s2d4 For This Useful Post:
Koa (12-19-2014)
Old 12-19-2014, 09:01 AM   #258
vgi
Drives: frs
It balances out pretty well as Steve is an Aussie too.
What's "Mafscaling Master" anyway?
vgi is offline   Reply With Quote
Old 12-19-2014, 12:53 PM   #259
s2d4
s2d4's Avatar
Indeed.
No idea, the guy does have a tendency to take out his frustrations over his own stupidity on others.......
Koa (12-19-2014)
Old 12-19-2014, 01:13 PM   #260
Koa
Sweeper
Koa's Avatar
Originally Posted by s2d4 View Post
Indeed.
I feel vindicated though.. Okay last post, I'm letting it go
The Following User Says Thank You to Koa For This Useful Post:
blue cat (12-20-2014)
Old 12-20-2014, 11:27 AM   #261
blown
Drives: ft86
is it safe to start and idle only a car with a stock maf tune and perrin big maf intake? I plan on checking the idle and vac leaks before towing the car to a local tuner.
blown is offline   Reply With Quote
Old 12-20-2014, 04:32 PM   #262
steve99
Drives: FT86
yes that should be no problem to start and idle car. the perrin big maf 3" maf scaling is it end of first post.
you would be able to drive it to tuners if your not boosted, its just going to have large fuel trims and probably not very smooth.
Old 12-20-2014, 04:45 PM   #263
blown
Drives: ft86
I should of been more clear, the ecu is flashed with ecutek from delicious tuning running sprintex 210 kit (stock fueling). my motor blew with their tune and I've replaced it with a low compression 9.5:1 built motor running 900cc injectors and I've added the 3inch perrin intake. hoping I can start it to idle and check for vac leaks before towing to local tuner.
Old 12-20-2014, 05:14 PM   #264
steve99
Drives: FT86
been told if you have cchanged injectors not a good idea to start untill injector scaling fixed up in tune, as may run extremly rich causing problems.
Old 12-23-2014, 07:53 AM   #265
2016 Camaro SS
2016 Camaro SS's Avatar
Drives: Fast
Who did the MAF scaling on the Grimmspeed Intake? I'm about to do some logging tonight to tune for it.
2016 Camaro SS is offline   Reply With Quote
Old 12-23-2014, 08:19 AM   #266
vgi
Drives: frs
@2016 Camaro SS cool screen name (among all these **frs**, **brz**, **ft86**, **hachiroku**). i can imagine you walking into a gay bar and greeting peops with "whassup f@gs?"
there is a thread on OFT greemspeed intake:
http://www.ft86club.com/forums/showthread.php?t=78903
look through, get that rom, and copy over the maf scaling
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
