#86 |
Drives: 2014 ASPHALT FR-S MT
OK whats the name of the file Romraider file im supposed you to be able to see LC in the tables ?
#87 | |
Drives: FT86
their is also a xml file directory thisis the romraider definition files when you open romraider go to definition files and point romraider to the correct definition file for your tune which will be the rom or calid for your original tune something like za1ja01c or similar, then open the appropiate tune file you downloaded. |
| The Following User Says Thank You to steve99 For This Useful Post: | el-92 (10-02-2014) |
#89 |
Drives: s2000
#90 | |
Drives: FT86
if you editing an OFT rom make certian your using the definitions from the OFT site else ecu = brick. Always check a couple of tables like base timing B an OL fuel tables to make sure everything look ok. just to be sure you have correct efinitions an definitions for v2tunes are different to the older v1.5 tunes must use orrect ones for your tune |
| The Following User Says Thank You to steve99 For This Useful Post: | unlimited86 (10-24-2014) |
#91 |
Drives: 2015 Brz Blue Series Pearl White
D00C cal update
Anyone know when the lc and ffs will be available for d00C cals just got oft today and cant wait to tune.
| The Following User Says Thank You to AlexBinJackson For This Useful Post: | KslayFRZ (11-12-2014) |
#92 |
Drives: BRZ Limited
^Yes! and same for B01c. i bought the oft thinking i would already have these features.
| The Following User Says Thank You to WHTEBRZ For This Useful Post: | KslayFRZ (11-12-2014) |
#93 |
Drives: 2013 Frs asphalt
It's available for the bo1c. I just updated my maps about a month ago and it was added on.
Then I had to come back to this page and find out how to lower the limiter lol I think it was at 6500 and I dropped it to 4 |
#94 |
The Mechanic
Drives: Civic Turbo,FR-S
nevermind had an issue with romraider that couldnt be found online but some random poking for and hour and i fixed it
#95 |
I am using the v2.06 Stg2_EL_E85_A01C.bin map.
When I am using launch control, the engine will rev to two different RPM values based on the transmission in neutral vs. in gear (tested with 1st gear). EDIT: all testing values below are at rest, i.e. 0 mph. For example, I have tested it with (3) separate LC RPM Delta values. (Launch Control Disable Speed is set to the default value (6), and Flat-Foot Shift RPM Delta is set to the default value (0) for all tests. Launch Control RPM Delta value set at 3600 (7600-3600=4000 RPM) - clutch off, neutral: RPM=3600 - clutch on, neutral: RPM=3600 - clutch on, 1st gear: RPM=4000 Launch Control RPM Delta value changed from 3600 to 3100 (7600-3100=4500 RPM) - clutch off, neutral: RPM=4100 - clutch on, neutral: RPM=4100 - clutch on, 1st gear: RPM=4500 Launch Control RPM Delta value changed from 3100 to 2600 (7600-2600=5000 RPM) - clutch off, neutral: RPM=4600 - clutch on, neutral: RPM=4600 - clutch on, 1st gear: RPM=5000 It seems that no matter the setpoint, with the transmission in neutral the RPM value = LC delta - 400 RPM. Has anyone else noticed this, and/or is it an expected behavior? It doesn't do any harm, I'm mostly just curious why it happens more than anything. Last edited by acj47; 12-11-2014 at 10:20 AM. |
#96 |
Has anyone else experienced the 400 rpm delta? Just curious if there's an explanation for why it happens.
#97 |
JHerbert Racing
Drives: 2013 Scion FRS
When you upload your edited tune to the oft (I changed the rpm on the launch control) is it supposed to say "The checksum of the file has been corrected" like it does with the off the shelf ones?
#98 | |
Drives: FT86
as per romraider tips link below always check some tables in the rom like ol fuel and base timing B to see all is ok. |
| The Following User Says Thank You to steve99 For This Useful Post: | Takumi788 (02-18-2015) |
| OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
| Is Openflash tablet detectable? | Boofneenee | Software Tuning | 25 | 05-02-2014 10:03 PM |
| WTB Openflash Tablet | Vlady | Want-To-Buy Requests | 0 | 10-25-2013 12:10 AM |
| racerom flat foot shifting | ft86me | Engine, Exhaust, Transmission | 10 | 07-25-2013 03:02 PM |
| EcuTek RaceRom Flat Foot Shifting ! | Visconti | Engine, Exhaust, Transmission | 79 | 11-14-2012 09:36 PM |
