Forced Induction Turbo, Supercharger, Methanol, Nitrous |
09-16-2013, 04:42 PM | #15 | |
In Test:Oil Fed SC
Drives: Vortech Prototype Test Car
The circuit is seeking a resistor on the line. My failsafe method utilizes a relay and unless wired right, this causes this code and it tells me when my failsafe for my meth kit has activated, it happens anytime here is a break in the wires to my ebcs, which my setup does by design. My car setup does this by design with my methanol injection kit, the solution is to place a resistor in lieu of the evap valve load (which is what the ecu is expecting on these wires whether you run a factory rom or ecutek)or the ebcs solenoid i use has the same exact load, both identical, if your ebcs is different that mine this may not apply, I run a Perrin pro unit.so... My tuner and I decided it was smarter to leave the code enabled so I could know if there was a problem with my failsafe setup ... a dpdt relay is all the meth kit uses for this so you could rig it up if your tuner know how to use relays I'm not a fan of perm disable of codes unless there is no other way, its a Less than ideal thing for a tuner to go disable all your codes and then when you have a problem, you're hunting in the dark! Hope this helps Curious what ebcs is causing this? |
09-16-2013, 04:47 PM | #16 | |
I Love custom Turbo kits
Drives: Limited BRZ
But the code is there connecting the stock EVAP solenoid. I'm not using EBCS anymore. All EBCS controls are removed from the tune. Sent from my HTC One X using Tapatalk 4
09-16-2013, 04:51 PM | #17 | |
In Test:Oil Fed SC
My tuner leaves map1 oe, so no ebcs in that map, evap valve functions as normal if it were connected electrically. I actually plan to add a relay to my shit so in map1 my evap valve works for real on map1 Map 2 adds duty cycle changes for ebcs operation No codes When my meth kit sees a fault, too much flow or not enough, it reduces my boost by disabling ebcs I'm curious if you return your boost and vacuum setup to oe if you still get a code Itsvavpain but I did it, I disconnected and reconnect all my hoses to check for a leak and low and behold the clamp on the manifold side of my PCv check valve leaked, but only at 11psi and above causing a rich condition @&$!?! |
09-16-2013, 05:33 PM | #18 | |
Drives: Limited BRZ
Would definitely love the code to go away but have no clue. I ran the EBCS with my las JV tune, but the tune itself still had no EBCS control stuff, it was just an open valve. I believe JV tune had the CEL disabled by default. Once I got FA20club tune (did not have CEL code disabled) is when I saw the CEL for the first time and has never gone away no matter that its connected exactly stock, hoses clamped, etc.
09-16-2013, 06:16 PM | #19 |
Boost equals pleasure
Drives: MT Raven FRS Lexus ES300 &Turbo tc
It's disable for now until I zip tie the lines.
09-16-2013, 06:35 PM | #20 |
In Test:Oil Fed SC
09-16-2013, 08:33 PM | #21 |
I think it's a leak.
09-16-2013, 08:39 PM | #22 |
In Test:Oil Fed SC
09-17-2013, 09:52 AM | #23 |
I have the greddy turbo kit. I check everything this morning. I didn't see anything that would cause the P0451 code to pop up. I just reload my old tune this morning to see if the P0451 code will show up again, so far so good. I will contact you if I need any help.
The Following User Says Thank You to Cessblood For This Useful Post: | 448hpsti (09-17-2013) |
05-04-2014, 12:33 PM | #24 |
Anybody figure out what was going on in these cases?
I had the CEL (P0441) and SL light come on last night after about the initial 100 miles of FI driving. All the Evap lines seem to be attached (I added hose clamps pre turbo install). I also have a check valve between the PCV and manifold. |
05-16-2014, 05:58 PM | #25 |
I'm still battling this. Any suggestions.
1) I've added a check valve between the Evap purge solenoid and the manifold (allows flow to the manifold). 2) I've disconnected the Evap hose at the metal (fixed) line in the engine bay and blew through the hose toward the solenoid and manifold. With the solenoid/valve closed, no air goes through. When I trigger the solenoid with 12V, I can blow through it with slight resistance. 3) With that same line disconnected, I blew back toward the tank (via the fixed line), and air easily moved (and vented) to the back of the car. 4) Ironically, the vent valve (near the charcoal canister) actuated while I was testing this, and when the valve was on (vent closed), I could not blow through the vent anymore. I would feel the tank pressurizing, and then when I stopped blowing all that extra pressure came back out towards me. After reading the factory service manual, all of these "tests" are passing... which doesn't leave me with very much more to try. The code is triggered on a daily basis... which is quite annoying. |
07-15-2014, 12:21 PM | #26 |
Drives: Subaru
Did we get a fix for this?!?
07-22-2014, 04:33 PM | #27 |
I haven't figured it out yet... although I stopped playing with it.
BTW a "gross leak" is actually defined as a very, very small leak in the service manual. I forget the actual spec, but a pin size hole would constitute a "gross leak". I suspect that is my problem at the charcoal canister output line junction (o-ring seems loose), but I haven't had the car smoke tested yet. |
12-02-2014, 10:05 AM | #28 | |
Drifter-Wannabe
Similar Threads | ||||
Will headers cause me to not pass smog? | 67corvette | Engine, Exhaust, Transmission | 39 | 11-13-2018 11:12 AM |
emission standards? | rainmonkey | Northern California | 10 | 04-23-2013 07:50 PM |
Will the borla headers pass emmision test? | Frsexxxy | Engine, Exhaust, Transmission | 3 | 03-24-2013 09:39 AM |
Does the US BRZ meet emission standards of all 50 states? | slowbrz | BRZ First-Gen (2012+) -- General Topics | 11 | 11-15-2012 01:31 AM |
Emission and noise restriction in DMV | guy | Mid-Atlantic | 6 | 11-14-2012 12:30 PM |
