Forced Induction Turbo, Supercharger, Methanol, Nitrous |
09-07-2014, 06:20 PM | #1 |
Drives: 2013
Carolina Dyno Prototype Turbo Kit & Shop Car Update
We have had a really busy summer thanks to our great local customers but finally we've had some time to settle down and get back to the shop car. This weekend it started for the first time since we took it home from the dealership almost a year ago. We have been working on a variety of products but the big one of course is our turbo kit. I'll let the pictures do most of the talking.
As with all of our products all fabrication is done in house, and we only source quality motorsports grade components and material. The kit is designed to fit either a Borg Warner EFR 7670 or 7064, of course for our shop car we went with the 7670. We didn't hold anything back going with a divided T4 collector & dual TiAL MV-S wastegates. We built our own end tanks around a 4" bell intercooler core. The intercooler is mounted at the same angle as the radiator and condenser allowing for the biggest possible core without trimming the bumper. The turbo is mounted towards the passenger side which makes for better exhaust routing and allows us to use the factory dipstick boss for our oil drain. We have made a custom stainless steel hardline for the drain that incorporates a dipstick. This allows for a proper oil drain that is virtually vertical and still well above the oil level. It also means nothing has to be drilled, tapped, or modified. We will update this thread with many more details and pictures as we make our final adjustments. We should have dyno numbers by the end of the week. We also got our first impressions of our custom Stoptech complete front and rear big brake kit, even though it was just brief street driving we are happy so far and confident they will do well on track. |
09-07-2014, 06:25 PM | #2 |
Drives: FRS
very cool cant wait to see numbers!
09-07-2014, 06:30 PM | #3 |
dying bird under the hood
Drives: 2013 SWP Limited BRZ
Looking great so far!
09-07-2014, 07:58 PM | #4 |
That's one busy ass shop you got!!! Congrats on that and the car.
09-08-2014, 11:39 AM | #5 |
Drives: 2013 Black FR-S
That intercooler is HUGE! I am guessing this setup is more aimed toward drag? If for road course, aren't you worries about airflow to the radiator?
09-08-2014, 12:00 PM | #6 | |
Drives: 2013
While we haven't had the opportunity to properly test at the track I'm confident we will find a cooling solution without compromising power. |
09-08-2014, 12:01 PM | #7 |
I Love custom Turbo kits
Drives: Limited BRZ
I see you hunting.....
09-08-2014, 12:15 PM | #8 |
Drives: 2013 FRS
Nice looking turbo kit! I look forward to see how that EFR turbo does on this platform. It's a killer set up.
09-08-2014, 01:34 PM | #9 |
Drives: FRS
The Following User Says Thank You to hunter3232792 For This Useful Post: | Sportsguy83 (09-08-2014) |
09-08-2014, 02:21 PM | #10 | |
I think as far as I know the only successful turbocharged 86 out here who can do 25-30 min time attack sessions without heat issues is @ImperiousRex who still saw 230 F coolant at the end of the session which is too hot for comfort still. I look forward to how you address the heat situation on your car. @Speed Element had to ditch the stock bumper crash beam and install a taller/larger radiator and vent the hood. He also doesn't run a skid plate as far as I know. |
The Following User Says Thank You to sw20kosh For This Useful Post: | Speed Element (09-08-2014) |
09-08-2014, 02:22 PM | #11 |
I r excite.
09-08-2014, 02:23 PM | #12 | |
If you're willing to lose the crash beam, then a lot of options open up... |
09-08-2014, 03:12 PM | #13 | |
Drives: 2013
09-13-2014, 04:42 PM | #14 |
Ultimate Member
Drives: 2014 Satin White BRZ
Your setup looks awesome! Are you guys planning on making kits for consumers?
Similar Threads | ||||
All your cooling needs | Evasive Motorsports | Groupbuys | 46 | 07-10-2017 05:47 PM |
Carolina Dyno - FA20 Club Turbo Kit Installed & Tuned | Carolina Dyno | Forced Induction | 21 | 11-15-2014 02:35 PM |
Shop Car Update - StopTech Brakes & More | Carolina Dyno | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 22 | 09-09-2014 09:36 PM |
