07-12-2014, 06:39 AM | #267 | |
Lacking brains
Drives: frz
My initial thoughts were track car. After going over the operating costs and $ necessary to make it better than where my (rotorex, ap kit, kwv3, etc) frs is at i decided to make the vette the gf summer mobile. The operating cost difference on track over any real span of time was basically going to cover the cost of a built shortblock and installing at home for the frs. |
07-12-2014, 02:26 PM | #268 |
Drives: waiting on a 2021...
[QUOTE=cf6mech;1842343]I would like to see any vette or 911 in any form, race car etc. beat this guy up this hill.....no big displacement engine involved...its a Gixer engine in that thing, meaning comparisons and bold statements are relative./QUOTE]
How about a Peugot? LOL
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
The Following User Says Thank You to zooki For This Useful Post: | cf6mech (07-12-2014) |
07-12-2014, 09:43 PM | #269 |
Drives: FR-S 10 #103 AT
This looks like a good place to ask a what if question.
Suppose you want to keep the feel of the car as close to factory as possible while getting at least 300 horsepower. To me this means high revving, normally aspirated and disturb the weight balance as little as possible while gaining the hp. What engine do you go with? I`m thinking an aluminum V6, but who makes the best one that`ll rev nice and high and sound like it likes it?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
07-12-2014, 11:21 PM | #270 | |
Drives: 2004 Toyota Tacoma Prerunner
Hmmm.... Maybe a nice honda engine? They're the only ones proven to get high hp, high rev, reliable. 300hp is honestly quite high for NA and lightweight and high rev ...LS1 sounds like the best choice from what I've gathered regarding NA, stock, reliable, etc...only thing missing is the high rev tho. |
07-12-2014, 11:37 PM | #271 | |
Drives: 2015 Series.Blue
V6's have inherent issues (splayed center journals for starters) not to mention any good V6 making anywhere near that power is DOHC. This is going to move the COG up significantly over stock and probably over an LSx swap because the LS motors are pushrod, keeping them compact. That much power in as close to factory as possible? Go forced induction on the stock engine. |
08-16-2014, 03:14 PM | #272 |
Junior
Drives: a car
Anyone crazy enough to get their hands on an S85? Fully dressed it's about 240kg, probably able to mount behind the axle, and you can find some for cheap on M5board if you're willing to tear them down.
08-23-2014, 07:04 PM | #273 |
Drives: ...saving up for FRS/BRZ still
As much as I love the idea of an LSx swap now (especially Vorshlag's/cf6mech's build and its' super high quality engineering/design and how they go about doing it) and really believe it's the best choice for the simplest, most reliable and smartest (best bang for the buck) engine swaps, I still kinda think just buying another car might be a better alternative.
Meaning...after all said and done: an Frs ($20k) and complete swap with all subsystems (another $20k at least) would run at least $40k. And that doesn't get you anything else. You'll have to spend much more on proper wheels and tires (not even an RB kit), suspension, aero, a stronger rear end and half shaft, etc etc. Then even after all that (which would be at least an additional $10-20k), there is still a lot of work to do to make it handle good around the track and most likely won't be as good as some other car around a track. Basically, you'll be in the hole $50-60k minimum for an LSx FRS with questionable track and handling abilities. Or, you can sell the FRS and just buy a used Cayman or even an older used 911 (996 I believe is in the affordable price range yes?) for $20-30k, or even up to $40 or $50k if you want to spend bit more (but for non-rich people, I think 20-30k is realistic/feasible). I am not knowledgable with Porsches, all their past models, which are the best buys and best years, etc, so I am no expert. I've only read a little bit here and there, and watched a few videos on them. But, what I gather is that this would be a good route and option (instead of doing an LSx swap). ....get a used Cayman or 996 gets you one of the (if not THE) best handling track cars ever built! You get a nice lightweight chassis with a 300hp engine, some of the best balanced handling cars ever conceived and only for $20-30k! That's the price of an LSx swap in itself; or, $20-30k cheaper than a said n done LSx FRS! Not to mention Everything on the car will be native and also well built with the highest of quality standards. The suspension, drivetrain, wheels, tires, brakes, chassis, balance, weight, etc etc etc are all built around and with the engine and overall car and chassis. Additionally, you can smog it and register it with no problems in Cali (good luck with this with an LSx swap lol). It's easy as selling the FT, then buying a used Porsche, then having fun with it right away from the first day owning it, you can even go to a track the first day and it'll handle super well out the box ...vs...frs, do the swap, figuring out any and many problems that arise, going to the track and trying to dial in the suspension and grip for the LSx's massive power, and maybe able to have fun with it after a month or 2 of working out all the engine and suspension kinks. Anyways...I think you get my point. I'm sure the 450hp LSx FRS will be faster than a Cayman or 996...but only in a straight line on a drag strip I bet. A Cayman or old 911 will for sure spank an LSx FRS around a track. 300hp is plenty...especially in a well engineered porsche. Yes..I'm sure the Cayman or 996 will be expensive to maintain...but remember, you still have that extra $20k in your pocket from going for the Porsche instead of doing an LSx FRS project Don't get me wrong though...I'm still really loving that LSx swap idea and will follow that Vorshlag build. ....but, for me, if I ever have that kind of extra money to spend (for a big swap mod or a better car)...I'd just sell the FT and get a used Cayman or older 911(996) and be happy ....anyone else agree and think the same? (..in that, getting a used Cayman/911/996 instead of doing a $25k LSx swap, is a good/better choice)? |
08-23-2014, 08:10 PM | #274 |
Lap time enthusiast
Drives: Asphalt '13 FR-S 6MT
@Food
I don't get the point of this thread. I've met exactly 0 people who track the car or engage in any kind of serious motorsport do a "big" engine swap on the car. The two most popular swaps that I know of are the SuperGT BRZ with an EJ series swap, and the drag BRZ by Ali Afshar with an H6 swap, which aren't "big" engines. You're assuming that these cars you see with LSx and 2JZ engine swaps are being tracked for some reason, and you're dead wrong about that. They're all street and drag cars. Last edited by raul; 08-23-2014 at 08:35 PM. |
08-24-2014, 01:21 AM | #275 | |
Drives: FRS Silver LS1 swapped.
Yah nobody does that,....its silly....its all about bragging rights and straight line speed. [ame="https://www.youtube.com/watch?v=IuILPHgBUNY"]V8 Miata racing at Infineon - YouTube[/ame] Last edited by cf6mech; 08-24-2014 at 01:37 AM. |
The Following User Says Thank You to cf6mech For This Useful Post: | jebuwh (08-24-2014) |
08-24-2014, 02:37 AM | #276 |
Again...Can't wait to see the progress of your car cf6mech.
I guess...I just wish a quality full LSx swap could be a bit cheaper and more attainable...like $10-15k for the entire thing attainable ...maybe so I guess..with a junker LS1 and tranny (but a Magnum XL ain't gonna be easy to find used and cheap lol) |
08-24-2014, 04:50 AM | #277 | |
I'm the dummy who takes the hit $$ wise so in the future someone can buy a high mileage cheap twin used, find a used LSX and used Magnum XL ( which is an option tranny to replace the crap Chinese made Getrags installed in Mustangs , so they will be available out there used in time) and do this swap way cheaper than my costs. Just saying........But then again the shop working on my car gets calls daily wanting to know when the kit will be available to do it now. Last edited by cf6mech; 08-24-2014 at 06:19 AM. |
The Following User Says Thank You to cf6mech For This Useful Post: | civicdrivr (08-24-2014) |
08-27-2014, 04:47 PM | #278 |
08-27-2014, 06:27 PM | #279 | |
08-27-2014, 07:18 PM | #280 |
Drives: '13 BRZ
I thought motor swaps were legal in Cali as long as the motor was from the same MY as the car or newer and maintained all the emission controls (cats, charcoal canister, tune).
Similar Threads | ||||
After the "Ferrari" 86, we now have the "Porsche" BRZ | Nardi330 | Scion FR-S / Toyota 86 GT86 General Forum | 30 | 07-06-2013 11:41 AM |
Portland people meet with Seattle area people before going into ForumFest 2013? | stockysnail | Northwest | 24 | 06-18-2013 06:19 PM |
First spotting in the wild! | pr0j | AUSTRALIA | 3 | 07-22-2012 03:48 AM |
Official: The new Ferrari V12 Ferrari Berlinetta | Levi | Other Vehicles & General Automotive Discussions | 27 | 03-07-2012 11:31 PM |
First Ferrari, now Porsche??? | zoomzoomers | Other Vehicles & General Automotive Discussions | 35 | 02-26-2012 11:47 AM |
