Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#43 | |
i can't see the advantage of an ignition/load-based strategy over one that actually cuts fuel based on manifold pressure. different strokes for different folks, i guess... certainly wouldn't be the first time we've disagreed on a technical issue like this, probably not the last ![]() |
#44 | ||
Drives: '04 350Z/ 2013 LR BRZ (LM)
#45 | |
The Following 3 Users Say Thank You to transition For This Useful Post: |
#46 | |
Drives: 2013 FRS
#47 | |
In any case.. i'm glad that you've found a way around it, even if we disagree on the implementation details. It will certainly save an engine... and at the end of the day that's what matters. |
The Following User Says Thank You to jamesm For This Useful Post: | raven1231 (07-16-2014) |
#48 | |
Drives: 2013 FRS
As an aside, the Denso logic makes this quite effective since engine load isn't just a raw MAF value but rather an engine speed (/rev) corrected load variable. So adding a breakpoint just above the desired engine load and then another one just above that and mapping in substantial ignition retard does the job very well. Arguably better than a rather simple MAP induced cut which is oblivious to any thing that would change engine VE and result in a condition where the ECU sees same nominal MAP value with vastly different engine load. |
#49 |
Drives: 2013 FRS
Sorry for being picky but when comparing two competent NA tunes (even a 91oct vs 93oct in this case), pickiness is required since we are not dealing with huge power differences. So not being picky and ignoring sampling bias (unintentional I'm sure) can lead the casual observer to skewed or exaggerated results.
In the dyno files you kindly provided, I tried to compare a warm 5th gear OFT off-the-shelf run to a warm 5th gear custom Ecutek run but was unable to find anything that fits the bill. So I compared the one (and only) warm 4th gear OFT off-the self run to ALL of the warm 4th gear Ecutek custom tune runs and come up with this: ![]() Not surprisingly this is more in line with what I would expect between a good 91 and good 93oct tune (the difference in power being primarily at high RPM due to running more advance up top with 93oct). The differences everywhere else are rather minor as one would expect with an NA car already running at or near MBT. The other graphs provided involve [unintentional] sampling bias which accounted for most of the dyno differences. And again, forgive me for getting picky but I do spend a lot of time calibrating our OTS maps. So when someone compares them to something else, I apply the same pickiness in analyzing the data as I do with creating the OTS map. Not necessarily to refute the comparison but also possibly to learn from it. So please don't take my involvement in this thread the wrong way. Still, it would be nice for the purpose of transparency to change the graph in your original post to the one provided above. I think it is as fair as possible given the sample pool you provided. And again, thank you for being transparent and providing all the dynojet run files. ![]() Cheers, Shiv Last edited by Shiv@Openflash; 07-16-2014 at 06:44 PM. |
The Following 2 Users Say Thank You to Shiv@Openflash For This Useful Post: | chas3wba0 (07-16-2014), skidmark86 (07-16-2014) |
#50 | |
#51 | |
I'm convinced you should have been a lawyer.
![]() Quote:
#52 |
Drives: 2013 FRS
#53 |
#54 |
Drives: 2013 FRS
The Following User Says Thank You to Shiv@Openflash For This Useful Post: | skidmark86 (07-16-2014) |
#55 |
Drives: FT86
Agree this thread has seen a lot of good info revealed and sensible logic based debate.
I have learned much from this so thanks to all ![]() |
The Following 2 Users Say Thank You to steve99 For This Useful Post: | jamesm (07-16-2014), Shiv@Openflash (07-16-2014) |
fi and openflash tune | Hachi6 | Forced Induction | 59 | 11-20-2015 01:28 PM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
OpenFlash Tuning Tech: Tales from the Dyno (Stock, Ecutek and OpenFlash tunes) | Rombinhood@OpenFlash | Software Tuning | 237 | 02-10-2014 03:35 PM |
>>> Circuit Motorsports > Scion FR-S + E85 + HKS Header + EcuTek Tune! | Circuit Motorsports | Software Tuning | 9 | 12-14-2013 11:38 AM |
Borla UEL Header, works automotive parts and ecutek tune | clayrush | Engine, Exhaust, Transmission | 14 | 06-27-2013 03:37 PM |
