Engine Swaps Discussion of engine swaps. |
#29 |
Drives: '13 BRZ
#30 |
Drives: 2013 Raven Black FR-S
A proper ls2 swap done right was quoted at 25k total from Pure Automotive Performance. To me if you want to be different and have that money go for it, otherwise I would just go turbo fa20. It comes down to what you want. I have a built 2jz here at my house I would love to swap but it is going to cost a fortune to do it right and not only that will add 200lbs to the cars weight. Pay to play.
-Raven Black 13 FR-S : The daily driver
![]() -88 supra turbo : 2jz 66mm single on E85 in the process ![]() |
#31 |
Road-hole
Drives: 2013 Whiteout FR-S
yeah ok...
Just add on 1300 lbs...lol...
Do you have any idea how big a difference the same hp in a car 1300 lbs lighter makes???(caveat: if you can put it to the ground) stock camaro ss 400-420 hp, equivalent to frs with 300 hp. frs with 400-420 hp, equivalent to camaro ss with 600 hp... frs with 600 hp, equivalent to camaro ss with 1000+hp. Jaden btw... after an ls swap, you can make an frs with 600hp that is carb legal... |
#32 |
Road-hole
yeah...
#33 | |
Road-hole
don't forget also...
That brings total cost to about the same as a new FRS... Jaden |
#34 |
Drives: AP2 S2000, S14 240sx
#35 |
Road-hole
keep checking sites like copart.com
I did a quick search to try and find the one that I had previously been looking at but didn't, if you search on sites like copart.com, you'll find some.
I'm thinking of getting one and then a wrecked 2014 camaro ss and doing a full drive train swap. I may even cut into the frame and weld in the front clip of the camaro and give it a slightly longer wheel base, like 107". Then build a custom front bumper cover and fenders etc.. build a wide body for it. This'll be a few years down the road, but like my papaw always said, measure twice, cut once, so I will do as much planning measuring etc in advance. The mounting points for the rear end on the camaro and frs don't seem to be very far off of each other, fabbing up some bolt on adapter plates shouldn't be too difficult. (I'm talking about the ENTIRE rear end, not just the differential). add on an e-force and you've got 600 carb legal hp and over 500 torque that the car can actually handle...also, by swapping out the front clip and the full rear end, you've got the camaro's big brakes too...Hell you could even order the carbon ceramics from the z/28 if you REALLY get a wild hair up your ass. wrecked camaro ss' are going for about 8-9000 Jaden The stripped cars go for less, but are less common than wrecked cars. and the donor car only needs to have an intact drivetrain, it doesn't need to be salvageable at all... Last edited by Jaden; 12-11-2014 at 11:47 AM. |
#36 |
Drives: VW MK6 GTI | 13 Mustang GT
It would probably be more cost effective to trade the 86 for a Mustang GT then add a Roush, Steeda, Cortex, or Hotchkiss suspension kit to that.
#37 | |
Road-hole
I don't understand why you guys don't seem to understand...
Jaden |
The Following 2 Users Say Thank You to Jaden For This Useful Post: | AZFA20 (12-12-2014), civicdrivr (02-13-2015) |
#38 |
Drives: RAVEN
Generally, when someone ask a simple question about doing an engine swap, it falls under the heading of "If you got to ask, you probably should not go there".
Engine swaps are hard to do. Much harder to do properly. And the real kicker is that right about the point where you and your wallet want to quit, the real heartbreak starts:sorting the running car is always frustrating. A safe dollar value for a drivetrain swap that you do the labor on should fall around $15,000. I know, it's shocking when you can probably do a spreadsheet that shows you can do it for $5000. Trust me, been there and learned the hard way on both my projects and other peoples projects. My hope is that the FRS follows in the footsteps of the Miata when it comes to a good LSx swap kit. They have several to choose from and a strong well-informed community to enable such swaps. |
The Following User Says Thank You to NOHOME For This Useful Post: | Jaden (12-26-2014) |
#39 |
Killer For Hire
Drives: 93 Rx7 LSx 383
While in a different chassis altogether my rx7 swap cost a lot, but the end result is awesome.
I just kept nickel and diming myself to death. "I could buy a stock LS6 intake for 450, but a FAST 102 costs 800 and flows better..." "I could buy a stock ECU and screw with the wiring or I can get a standalone for 1500 more..." etc etc etc and then the total passes 25k |
The Following User Says Thank You to TEDDER1 For This Useful Post: | flippy (01-30-2015) |
#40 |
Sweeper
its not hard at all
1. take car to dealer 2. trade in for vette there swapped |
The Following 2 Users Say Thank You to Koa For This Useful Post: | hmong337 (02-01-2015), Whatabouteggs (01-30-2015) |
#41 |
Drives: 2013 FR-S whiteout
There is a wire on the ECU you'll have to unplug for the idle control valve because the FA has an extra wire, or you could just adapt the FA's idle control valve to work with the LS1 but that's probably a lot of work. Other than that it just drops in.
The Following User Says Thank You to SloS14 For This Useful Post: | Calum (02-01-2015) |
#42 | |
http://www.ft86club.com/forums/showt...ure+Automotive Check post #15 for the video of the start up in its early iterations. It later got a stroked bottom end with the exhaust cut outs if my memory is correct. http://www.ft86club.com/forums/showthread.php?t=79911 Last edited by White64Goat; 01-30-2015 at 08:36 PM. |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
Hard choices | pearsor1 | BRZ First-Gen (2012+) -- General Topics | 24 | 02-24-2014 07:41 PM |
How hard is it really? | Kimsey47 | Issues | Warranty | Recalls / TSB | 13 | 08-16-2013 11:01 PM |
Was I being hard on my car? | Fr-s13 | Scion FR-S / Toyota 86 GT86 General Forum | 49 | 07-04-2013 09:54 PM |
The hard part is done! | koteman | Other Vehicles & General Automotive Discussions | 27 | 10-11-2012 01:02 PM |
