Old 06-24-2014, 11:50 AM   #1
STS-V
Stealth Trunk Subwoofer Enclosures?
Any budget cost effective stealth subwoofer enclosures out there? I cant find anything.
STS-V is offline   Reply With Quote
Old 06-24-2014, 12:07 PM   #2
cnk
Drives: '13 DGM BRZ Limited
What's your idea of stealth and budget?
Old 06-24-2014, 01:24 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
http://customsubenclosures.com/produ...fer-enclosure/
this is the one i use, only thing i dont like about it, is that it doesnt come with anything to mount
Old 06-24-2014, 01:53 PM   #4
k.houan
k.houan's Avatar
Drives: BRZZZ
Anything cheaper?
Sent from my LG-E980 using Tapatalk
k.houan is offline   Reply With Quote
Old 06-24-2014, 09:23 PM   #5
STS-V
So how did you mount it?
Originally Posted by k.houan View Post
Anything cheaper?
Thats what Im trying to find out.
Old 06-25-2014, 10:51 AM   #6
WhiteFRS69
WhiteFRS69's Avatar
ended up using one L bracket and some Velcro
Old 06-25-2014, 02:52 PM   #7
STS-V
Got any pics? did you go round? 10? black? drivers side?
Old 06-25-2014, 03:37 PM   #8
WhiteFRS69
WhiteFRS69's Avatar
round, black, 10inch ALPINE SWS-1023D
Old 06-25-2014, 03:38 PM   #9
WhiteFRS69
WhiteFRS69's Avatar
if you want better pics, let me know, pretty crappy photos
Old 06-25-2014, 04:07 PM   #10
Integrity Concepts
Integrity Concepts's Avatar
Drives: Concepts
We offer 4 models of stealth style and compact vehicle specific fiberglass subwoofer enclosures for the 2013 and up FR-S / BRZ / GT 86 platform. A 10" model for both sides of the trunk and an 8" model for both sides.
While our options may not be quite as inexpensive as the one previously shared in this thread, we feel that our product is a better value, and here is why:
Our enclosures are made from thick 100% hand laid fiberglass CSM, pulled from a front and back mold, unlike the competition or custom built enclosures that use a stretched fabric front for a base shape. This means our enclosures will have a higher strength to weight ratio for reduced flexing and better sound. This also means that our enclosures maintain a consistent internal volume from 1 part to the next, so you can trust that you are getting the intended airspace. We incorporate ribs into our designs to keep the larger flat areas on the floor of the enclosures from "oil canning" or flexing, which means you'll hear your music not the flexing of the enclosure and that again equates to a better sound experience. Our enclosures include a mounting bracket so the enclosure stays in place without all the hassle of trying to figure out a mounting solution. We also designed ours to incorporate a grill option so that your woofer stays protected from moving objects. Lastly our enclosures compact design takes up less usable space in the trunk.
Combine all of the above design and build aspects with the fact that we coat the inside and out of each enclosure with Cascade Audio Engineering's VB-1X liquid sound dampening compound, include high quality Knukoncepts twisted pair 12 gauge sub wire, gold plated bolt through terminal posts, and line the inside with polyfil dampening material for tuning. We also offer a 5 year warranty and a 30 day return policy. All of this leads us to believe that our enclosures are more than worth the minimal price difference.
If customization is what you want, we offer a full range of options and finishes, and can even tailor the internal volume to your subs recommended spec!
While none of the enclosures mentioned in this thread may be within your set budget, it's hard to understand how a stealth style enclosure could be priced any lower, unless you just wanted a cheap plastic box pressed from a couple sheets of ABS, which would not only flex and rattle, but would be unable to house a woofer with any kind of true punch. Compare any of these fiberglass enclosure options to a custom fiberglass enclosure built by your local audio shop for $600-$800 and up, and these really are the budget savvy option and in our opinion a no brainer. A slim wood box against the back seat would come in at a much lower price point, but is not considered a stealth option. So again I guess the question is, "What is you idea of stealth and budget"?
In the end, remember that a subwoofer is only as good as the enclosure it is mounted in.
Check us out online at: www.IntegrityConcepts.net
Visit our prototyping and build thread here: http://www.ft86club.com/forums/showthread.php?t=31813
Integrity Concepts is offline   Reply With Quote
The Following 3 Users Say Thank You to Integrity Concepts For This Useful Post:
ericmpena (06-25-2014), KGFRS86 (06-25-2014), WhiteFRS69 (06-25-2014)
Old 06-25-2014, 04:54 PM   #11
mines13
mines13's Avatar
Drives: '13 FR-S '12 CBR1000RR
Send a message via AIM to mines13 Send a message via Yahoo to mines13
+1 on the Integrity Concepts enclosure, worth every cent.
mines13 is offline   Reply With Quote
The Following User Says Thank You to mines13 For This Useful Post:
Integrity Concepts (06-25-2014)
Trunk Space / Subwoofer Box ckcrown84 Electronics | Audio | NAV | Infotainment 29 08-14-2017 01:26 PM
Anybody running OEM Kicker trunk subwoofer ? Simon99 Electronics | Audio | NAV | Infotainment 16 04-24-2014 08:02 PM
Custom sub enclosures vinceqt Electronics | Audio | NAV | Infotainment 5 02-10-2014 04:36 PM
Anybody tried these sub enclosures before? mit_peid Electronics | Audio | NAV | Infotainment 29 01-09-2014 01:09 PM
