03-12-2014, 09:44 PM | #575 |
Drives: 2013 BRZ, WRB
The coolant in your engine is regulated. The coolant in your radiator is not. So a guy in Canada (eh?) commuting to work in Winter would see his oil chilled quite undesirably.
Water entering the radiator does so at the temperature of the water outlet manifold, but under low load, that water flow is really small and it's cooling rapidly as soon as it hits the radiator. |
03-13-2014, 02:55 AM | #576 | |
Drives: 2022 BRZ Limited
03-13-2014, 03:23 AM | #577 | |
Have you guys seen how little the contact area is? |
03-13-2014, 05:38 AM | #578 | |
That Guy
Drives: 2013 asphalt FRS MT
Thanks for the eye opener, eh. |
03-13-2014, 05:58 AM | #579 |
Drives: Silver BRZ
anyone used the larger Rotrex unit? If so, what power is it making
03-13-2014, 11:37 AM | #580 |
Drives: 2013 Black FR-S
So we know the ecu pulls back at 240 F oil temps. Does it pull back power at the lower end of the spectrum too? Anyone know this temperature?
03-13-2014, 11:43 AM | #581 |
Drives: Attitude
I can't verify what the engine control logic is, but oil that is TOO cold isn't good either - I think we can all agree on that. It's about the middle path, as Aristotle said.
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | glamcem (03-13-2014) |
03-13-2014, 02:20 PM | #582 |
03-13-2014, 08:28 PM | #583 | |
Drives: 2015 Series.Blue
Yep, not hot enough and you don't boil off the water and fuel that gets into the oil. You also don't set off the additive pack until it's warm (additive pack stuff could take up an entire other thread) Keep in mind that any thermostatic oil cooler is never truly closed all the way (how else would you fill the heat exchanger?), same goes for the coolant thermostat. Factory oil to water coolers are used all the time because they're cheap. While they work, there's a reason race cars run thermostatic air-oil coolers... |
The Following User Says Thank You to Poodles For This Useful Post: | CSG Mike (03-13-2014) |
04-15-2014, 05:23 PM | #584 |
Novice Drifter
Drives: 2013 Asphalt FR-S
i read somewhere that there is a 10psi pulley....is that the factory pulley or the upgraded? @*LongFella are you running the perring overpipe too with your exhaust setup? thanks
04-15-2014, 08:25 PM | #585 | |
Drives: lexus
The Following User Says Thank You to 4032pauln For This Useful Post: | FullTuneZN6 (04-15-2014) |
04-15-2014, 09:02 PM | #586 | |
Drives: 2014 Scion FR-S|Whiteout
I believe the kit is stock at 10 psi. Don't quote me though, I'm not 100%. Nope on the Perrin over pipe. I will eventually do the whole exhaust including headers, but I'm waiting "patiently" as CSG Mike recommended. I figured if this secret is really good, which I'm sure it is, I'll spend the money on it...upgrade the entire exhaust too, and have a custom tune done
My 2014 FRS build thread: http://www.ft86club.com/forums/showthread.php?t=52071
“You might be poor, your shoes might be broken, but your mind is a palace.” - Frank McCourt |
The Following User Says Thank You to *LongFella For This Useful Post: | FullTuneZN6 (04-15-2014) |
04-15-2014, 09:02 PM | #587 |
Oh and don't forget I want to eventually run e85
04-17-2014, 08:48 AM | #588 | |
Drives: lexus
Tags |
jackson racing, jrsc, rotrex, supercharger, track |
Similar Threads | ||||
Kraftwerks Rotrex Supercharger Discussion | nelsmar | Forced Induction | 697 | 01-18-2022 12:06 PM |
Jackson Racing Supercharger Press Release and Info | CounterSpace Garage | Forced Induction | 110 | 01-03-2017 09:04 PM |
Jackson Racing supercharger | NoppyNop | Forced Induction | 241 | 06-26-2014 03:05 PM |
HKS GT Supercharger (Rotrex) in development! | madfast | Engine, Exhaust, Transmission | 206 | 12-14-2012 03:28 PM |
Jackson Racing FR-S | Unleashed | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 3 | 11-18-2012 02:29 PM |
