Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
Drives: 2013 Black BRZ Limited 6MT
Grinding Gears + New Trans
Car started to grind gears shifting from 5th to 6th and various other methods during higher RPM shifts.
Brought my 2013 limited BRZ into my local dealer and within 10 minutes a tech drove with me in the car, felt the issues, and ordered me a new trans. While this sucks.. I'm glad I was able to get a warranty replacement so quickly and easily with no hassle whatsoever. Here's hoping for better luck with the new one. ![]() Edit: have 8k miles on the car
Zeta Stage 2 Drop In + Red Silicone Tubing || Zeta SS Cat Back || DC Sports Cat-Delete Front Pipe || Torque Pro + MiniOBD Bluetooth || Fumoto F-108 Drain Valve || Konig Daylite Gold 17x7 +40 14.2lbs || Anarchy Motive Shift Knob
![]() Future: Catted header, OEM Audio+ |
#2 |
Well, let's hope the new transmission lasts longer .....
![]() Do they have any idea of what went wrong with the old one .. ?? humfrz |
#3 |
Nope.. they are a relatively small dealer that hasn't sold many BRZ's.. so I'm assuming they're just going to swap it and return the tranny to Suby for diagnostics.. but I doubt I will ever find out the true cause. The fact that they were able to get a trans so quickly leads me to believe that this is a somewhat known issue.
#4 | |
![]() humfrz |
#5 |
Drives: 2013 Raven Scion Frs
Heard this cause was the trans fluid they used, knock on wood my car shifts smoothly and I even did a clutch pedal adjustment half the time I flat foot shift lol.
#6 |
Drives: Satin White BRZ Limited
I had an issue with my tranny also. But it was a 4th gear grind at high RPM. I'm getting it warrantied this week. I have a friend with a FR-S with 30K miles on the car with no grinds whatsoever, so I don't think every tranny suffers from this problem.
#7 | |
Mine almost always grinds while cruising in 5th and then shifting into 6th.
#8 |
Drives: fr-s
A little birdie informed me that the Aisin 6MT in these cars is S-H-I-T
![]() The only thing left on the table is a TSB |
#9 |
Drives: Firestorm FRS
Had the same thing happen to mine at similar mileage (6k). I have a thread that I started somewhere around here and the same deal, shifting from 5th to 6th. I had it replaced and so far no issues, now at 12k. Here's to hoping that is it.
#10 |
Drives: FR-S,GTI
Same thing here. Got a new transmission and it works great.
No more grind. |
#11 | |
There do seem to be a lot of people with tranny problems here on the boards, but if that's representative of total numbers, the vast majority are working perfectly fine. |
#12 | |
Drives: fr-s
Taking into account some opinions from a good source, I would not be surprised at all about a TSB being issued for the MT. Maybe in the next 6 months?? Who knows.. What I do know is that I'm never buying a 1st year car again. 2nd year maybe. 3rd year better. |
#13 |
This thread regarding a grinding 4th and 6th gear mentioned a TSB 03-71-13. Might be related if someone can link the TSB PDF.
#14 |
In Autobahn withdrawl
Drives: 2015 BRZ Limited Man., WRB
They're shit. Either that, or the fluids they used were shit. Mine ate the synchros by 5000 miles without any tracking or beating it up. When they drained it the fluid was filled with metal shavings. Numerous other people in here have had the same problem and tranny replacements.
Speeds at each gears. | mickey177 | Engine, Exhaust, Transmission | 10 | 08-25-2016 06:40 PM |
fs: Perrin trans mount and whiteline trans bushing | RWD_FR-S | Transmission and Driveline | 1 | 01-02-2014 05:34 PM |
You know what really grinds my gears...... | z3ro | Off-Topic Lounge [WARNING: NO POLITICS] | 7 | 10-10-2013 01:55 PM |
2nd gears a b*tch | Carbon420 | Scion FR-S / Toyota 86 GT86 General Forum | 32 | 01-29-2013 05:09 PM |
Changing Gears | Naughty | AFRICA | 10 | 01-09-2013 12:30 PM |
