Forced Induction Turbo, Supercharger, Methanol, Nitrous |
03-18-2014, 02:19 PM | #1 |
Drives: 2022 BRZ Limited
Rotrex vs Turbo (AVO) for Track use (transient response, IATs, heat management, etc)
As the title says I would like hear about your experiences exclusively for track use, and supporting data of any sort would be highly appreciated. And yes, I searched but couldn't find anything other than the subjective opinion(s).
FYI, I plan to use OEM DIT oil cooler that comes with Forester(yes, I know) and Koyo radiator regardless of the FI application to help eliminate the heat issues (even before the FI route to be exact). I have owned turbo cars in the past and even though I liked the rush/kick of the turbo for the street use, I was happier with NA cars when it comes to heat management, linear power delivery and reliability for longer spirited driving and track use. Below are the information I gathered so far on both FI application: Turbo advantages:
Turbo disadvantages:
Rotrex advantages:
Rotrex disadvantages:
I am not really worried about the dyno numbers since after owning Corvettes and bikes everything feels pretty slow anyways I wanted to switch to a lighter platform after owning high HP cars mainly because I felt the weight is the single most important thing when it comes to track use. That being said, I also think the car is lacking a little bit of power and if Subaru offered a ~250-270 whp BRZ from factory I would get that in a heart beat instead (even if the cost would be 6-7k higher than what it is now). Hopefully, one of the FI applications will address this and I will be able to get the power levels I plan and get rid of the notorious torque/rpm dip in the process
The Following 3 Users Say Thank You to glamcem For This Useful Post: |
03-18-2014, 02:24 PM | #2 |
Drives: fr-s
The Following 2 Users Say Thank You to evan For This Useful Post: | DriftEightSix (03-19-2014), NickFRS (03-20-2014) |
03-18-2014, 02:32 PM | #3 |
I'm also interested in comparing specifically the Rotrex system to a turbo, since it similar in some ways and I'll be doing track days with 20-30 minute stints. I'm not sure how long it'll stay on topic before it grenades into another generic TC vs SC thread. Good luck.
03-18-2014, 02:36 PM | #4 | |
03-18-2014, 03:32 PM | #5 |
Please people lets keep this on topic. I'm also genuinely interested in a more direct comparison for track work.
I know @CSG Mike has driven both at the track, but not sure about anybody else. I also don't think we can speak for the reliability of any of the systems at this point, most 86 have less than 30k miles and probably not nearly as much track miles. A big plus for the Rotrex IMO is the turn key solution - install, tune, and your ready to go. I haven't heard any install issues, like I've heard with pretty much every other kit on the market. That in itself is impressive. Also to note, I've researched quite a bit and it seems a lot of track guys use Rotrex units and speak highly of the reliability. Seems like some pistons + minor engine work + c30-94 + miata seems a good recipe for relable 300whp. While the turbo track guys also like to say turbos are "just as reliable", every one I've seen speak up (online at least) has had at least some sort of problems at the track. More moving parts, heat, etc. is obviously going to present more challenges, but I would love to hear more direct experiences with turbo 86's at the track. |
03-18-2014, 03:42 PM | #6 | |
03-18-2014, 04:08 PM | #7 |
I believe I'm one of the more qualified individuals to answer this question. I have, however, NOT had any seat time on track with the Kraftwerks kit. They are not willing to allow me to drive their car for me to get impressions.
However, @Zach3794 has stepped up to the plate, and I'll be doing some logging in his car at the next Winmax 86 CUP event. Give me a list of specific questions, and I'll answer them to the best of my ability. The more specific your question, the better I can answer. For the record, CSG is a dealer for both rotrex kits, as well as the AVO turbo kit, among other FI options. |
The Following 4 Users Say Thank You to CSG Mike For This Useful Post: |
03-18-2014, 04:27 PM | #8 | |
Thanks again
03-18-2014, 04:32 PM | #9 | |
Oil temps will universally be higher on a turbo car that has an oil cooled turbo. You'll need a cooler that can keep up. Under hood temps will be higher with the turbo car, even with a vented hood. IAT will vary, but assuming a similar level of boost the Turbo car (with base AVO turbo) will have a higher IAT as well. With similar boost, the AVO car will have a small AUC advantage, but that AUC advantage is not sustainable. At heat-soak equilibrium conditions, the JR kit will make similar AUC. With a turbo car you add power with a bigger turbo (diminished transient response), or more boost (higher IAT); your cats are probably deleted to begin with. With a SC car, you can add power with more boost (higher IAT), or increasing VE (deleting cats, same boost). Do you have specific questions? |
The Following User Says Thank You to CSG Mike For This Useful Post: | glamcem (03-18-2014) |
03-18-2014, 04:47 PM | #10 |
Thanks,
Since the car will be in the power band under curve area or the "umph" feel is not that important for me (to each his own). Did the the rotrex car you drove at the track have the OEM header and exhaust? I wonder if the OEM catback will provide adequate flow since I'd much rather keep the OEM catback for sound and cost purposes and I am definitely not worried about 3-5 whp that I can gain with that. I will most likely change the OF/FP combo only. Thanks again
03-18-2014, 04:50 PM | #11 |
Drives: 85 corolla gts
I am a huge turbo fan. With that said my opinion for extended track use, I would recommend the supercharger. If for nothing more then the linear power band and consistent power production. You can make a turbo set up work well at the track, but I feel you will have a considerable amount spent on heat shielding, air ducting and such.
03-18-2014, 05:08 PM | #12 | |
03-18-2014, 05:17 PM | #13 | |
Do you recall what kind of power it was making with the full OEM exhaust? And your oil temps between sessions? IIRC, in one of your earlier posts you mentioned that the JR car you drove didn't have the oil cooler, do you have updated results or before and after results to see the effects of the oil cooler and /or radiator?
03-18-2014, 05:23 PM | #14 | |
We were at 245whp from a 172whp baseline with JUST the kit on and no oil cooler, and no other modifications. The 245whp wasn't a hero run. Rather, it was fully heat soaked, and what you'd see in a real world condition. The car does make more power with an oil cooler, since the tune will compensate for the lower oil temperatures. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | *LongFella (03-18-2014), glamcem (03-18-2014) |
Similar Threads | ||||
Transient ignition and knock count | brn12345 | Software Tuning | 19 | 06-10-2014 11:46 PM |
Transient Ignition Retard Tables from RomRaider | Ralph Spoilsport | Issues | Warranty | Recalls / TSB | 31 | 05-24-2014 07:48 AM |
Avo turbo heat management on track | ICantAffordAnLFA | Forced Induction | 18 | 09-09-2013 11:00 AM |
MP3 management software for PC? | mit_peid | Electronics | Audio | NAV | Infotainment | 9 | 06-08-2013 08:14 AM |
ROTREX SC Brainstorming | MANDALAY | Forced Induction | 61 | 12-11-2012 05:57 PM |
