Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-27-2014, 03:07 PM | #29 |
Drives: Scion fr-s
I really do think you are confusing yourself..
What do you guys think? @CSGmike @ElementTuning |
02-27-2014, 03:13 PM | #30 | |
Trust me, I'm the Doctor
For you to be experiencing that on the street tells me that either something is wrong with your car or you are driving it WAAAY too hard to be safe on the street. Even when canyon carving with < half tank, I don't get this issue. I get blinky tc light all the time there (b/c of dust conditions, I only run the 88 in vsc sport mode, NOT tc/vdc off mode) but that only activates brakes (and yeah, I get cooked brake pad smell after a while with it too.... I need to be smoother), not robs engine power. So, there's either something the matter with your fuel system or there's something you're not telling us about your driving style.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
The Following User Says Thank You to SirBrass For This Useful Post: | canu_50 (02-27-2014) |
02-27-2014, 03:29 PM | #31 | |
Drives: Ultramarine toyobaru
On what planet does this compare to putting on a fire suit and helmet... good chat. |
The Following User Says Thank You to headlikeahole For This Useful Post: | wparsons (02-27-2014) |
02-27-2014, 03:31 PM | #32 |
Drives: Scion fr-s
Like i said, it only happened to me on long left sweeper at 160 km/h (100MPH) with r-compound tires.
02-27-2014, 03:50 PM | #33 | |
Drives: 2013 Asphalt 6spd
You yourself said that traction is for increased safety, so is a helmet, how is that confusing? you take the precautions you choose to, that is all. Oh that "good chat" line doesn't help the conversation. |
02-27-2014, 03:52 PM | #34 | |
Drives: Scion fr-s
We don't need mommy over our shoulder to tell us if i need vsc or not. I like to drive the car the way i bought it for! |
The Following User Says Thank You to canu_50 For This Useful Post: | SirBrass (02-27-2014) |
02-27-2014, 03:57 PM | #35 |
Drives: Scion fr-s
Also, just to let people know, i do run VSC and TC off all the time. But one thing people doesn't know or are not aware of, is the electronic diff. The car will cut power to the rear wheels if it feels like a wheel is spinning and the other is not.
I.E Winter when one wheel is on ice and the other on asphalt. This is to protect the Diff. It did happenened to me a couple of time also at drift event (probably because of gravel or sand under one wheel). So don't forget that this could also be what happenned with OP, and would tend to believe happened also to our friend that has fuel starvation! |
02-27-2014, 04:08 PM | #36 | |
You get more grip from a non slipping tire than you do from one that is slipping (either locked up or spinning), so if the TC is cutting power to the point that you can barely move, you'd have next to no traction anyway so you're still screwed. Launch your car at 4000rpm on dry pavement, and then do the same on a snowy road. The TC is MUCH more invasive on the snow than it is on the dry road, AND you get much more acceleration on the dry road than on the snowy one. Your post makes it sound like as soon as there is any slip it cuts 100% of the power until you back off the gas, which just isn't the case. You're the first to state that it will actually cut power. Anything else just states that it will apply brakes to the wheel in the air. I've experienced it applying brakes to a wheel in the air and it most definitely did not cut power. It doesn't do this to protect the diff, it does this so if the diff is unloading you still have forward power. Without the brakes being applied it would simply send 100% of the power to the wheel without grip like a normal open diff does.
The Following 3 Users Say Thank You to wparsons For This Useful Post: |
02-27-2014, 04:22 PM | #37 | |
Drives: Scion fr-s
02-27-2014, 05:21 PM | #38 |
Drives: Pavement MT GR86
Not sure what tc you guys have but it will kick in on stock tires stock tune at 4500ft elevation driving mildly spirited.
When I put new tires on the car it toned down noticeably.
GR86 MT premium
02-27-2014, 05:24 PM | #39 |
With full nannies on it is very intrusive.... Aka over protective.
In the summer I usually turn it off, in the winter I use vsc sport most of the time. The only time I have it fully on is if I forget. It's terrible
GR86 MT premium
02-27-2014, 07:46 PM | #40 |
Drives: Toyota Gt86
I find that on DRY road with good pavement condition It is ok to have everything OFF
BUT when it's slippery or it's raining... man... the car can spin so fast sometimes that You must be on the balls to catch it on time. That's why I usually drive very slowly when I see it's slippery or during the night If I have all the nannies OFF or use VCS. The funny thing is I have the Micheling ALPIN3 or whatever is the name, but still... as soon as it starts to rain, the car handle like shit in corner with TC OFF etc. |
02-27-2014, 07:52 PM | #41 |
You might have your tire pressures too high or those are bad in the rain.
My Dunlop sport maxx are way better than the stock in the rain.... I mean 5krpm and power and it will slide but not unless you want it to
GR86 MT premium
02-27-2014, 07:56 PM | #42 |
Drives: Scion fr-s
Alpin are winter tire.. Not sport maxx..
