02-23-2014, 01:24 AM | #379 |
02-24-2014, 09:35 AM | #380 | |
Drives: Avensis 2.2 diesel
What kind of car na supra is on the track? Does it have a good balance and is it easy to drive at the limits? It would be a lot of cheaper to buy than twins, so that's why i'm asking. |
02-24-2014, 09:44 AM | #381 |
Drives: 2013 SWP BRZ
What would be optimal camber for NT01s to keep them from wearing out the shoulder prematurely? Currently running -2.0* front and -2.2* rear with RCE T2's using OEM top hats and crash bolts up front.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 Last edited by smbstyle; 02-24-2014 at 04:49 PM. |
02-24-2014, 01:16 PM | #382 | |
Balance is okay, and the car is more forgiving overall, but modding options are limited with a NA-T conversion or a TT base. |
02-26-2014, 07:25 PM | #383 |
Hey @CSG Mike , not sure if you saw my other post:
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
02-26-2014, 07:56 PM | #384 | |
Anyways, do you have pyrometer readings or tire pictures? |
02-26-2014, 07:59 PM | #385 |
Nope; haven't run on them yet.... just not sure if my -2.0* up front is anywhere close to where I need to be.
02-26-2014, 09:08 PM | #386 |
Drives: pet dragon
I currently have eibach pro kit performance springs installed, and there is a noticable stiffness compared to stock suspension. would it be bad to track with these? a friend from a shop i know told me not to since I don't have coils. I don't see the problem tracking with these when people track with the softer stock suspension. but might as well be safe and ask the forums :P
edit: i've done many canyon trips but i want to get some track experience before i do too much modifications. ive already learned the limits of my stock tires and suspension due to an accident i had in one of these trips hoping to gain more legal experience with a stiffer suspension and stickier tires, which I am getting installed this weekend. Last edited by Jeong; 02-26-2014 at 09:19 PM. |
02-27-2014, 01:13 AM | #388 | |
02-28-2014, 11:15 PM | #389 |
Drives: 2013 Scion FR-S, Raven, Manual
Hey Mike, if you had to choose between the Bilstein B14 and B16, which would you choose?
This being a car that is a daily driver with the ambition to track maybe once every couple months.
02-28-2014, 11:16 PM | #390 |
B16. Get them put on, get it corner balanced professionally, aligned professionally, and dampers dialed professionally. Then forget about em and enjoy.
02-28-2014, 11:21 PM | #391 |
Expanding on that, I want to be able to retain my current drop of 1.5-2.0". I do not want to sacrifice handling. Will it be worth it to go into roll center/bumpsteer correction, as well as extended top hats for the rear to prevent bottoming out, and perhaps the ground control camber plates up front to preserve travel and allow for the precise alignment I'll need?
03-01-2014, 12:40 AM | #392 | |
On that note, higher spring rate does not mean a worse ride.... with proper dampers. |
Similar Threads | ||||
Simple question, hard to find answer... | Mango22 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 5 | 05-16-2013 06:23 PM |
Silly question about protecting track rims | sw20kosh | Tracking / Autocross / HPDE / Drifting | 16 | 04-25-2013 12:34 PM |
Asking the question that I already know the answer to. Are the engines the same? | Bigmaxy | Engine, Exhaust, Transmission | 10 | 01-19-2013 07:47 PM |
Random dog-related question for those who have their BRZ | GMU-BRZ | BRZ First-Gen (2012+) -- General Topics | 11 | 05-31-2012 07:48 AM |
Got my answer - BRZ comes with HID headlights as STD | Z_Rocks | BRZ First-Gen (2012+) -- General Topics | 20 | 01-10-2012 09:54 AM |
