Cosmetic Modification (Interior/Exterior/Lighting) Discussions about cosmetic mods. |
12-13-2013, 11:59 PM | #1 |
Drives: 2013 Whiteout FRS
FRS: 6-pin to 8-pin headlight harness
This harness was made by @DeOppressorLiber
Made and shipped in a timely manner. Big thanks! Last chance to get it right. Very helpful instructions. Here's the harness. Very simple, but well made. A good length in-my-opinion. Not too long, not too short. Wires aren't color coded, so it might be a little tedious to fix if any of them ever go bad, but this is highly unlikely. 6-pin side that connects to the FR-S headlight harness. Fits one way only, so it's pretty self explanatory. 8-pin side to plug into the headlight assembly. Once again, well crafted and sturdy. First contact made! Fits snug. Easy as pie. LED strip on at all times. Isn't that what we all want? Works as intended. Headlights installed with harness. Working as intended! Once again, thanks to @DeOppressorLiber. Shoot him a PM if you want the hook ups! Last edited by m.box.design; 12-20-2013 at 02:15 AM. |
The Following 5 Users Say Thank You to m.box.design For This Useful Post: | Bonburner (09-24-2020), Calavera (12-14-2013), DeOppressorLiber (12-14-2013), Lonewolf (12-30-2014), Redlinedfrs86 (12-14-2013) |
12-14-2013, 08:52 AM | #2 |
Drives: FRS Full Blown Custom
I cant wait to see a pic of the front of the car with them on! Thanks alot!
The Trypticon Transformation in Progress! |
12-14-2013, 10:05 AM | #3 |
Drives: Scion FR-S Whiteout
Yep, I'm bias since I own a whiteout but those head lights look sick as heck on a whiteout! Post pics!
If my calculations are correct, when this baby hits 88 miles per hour... you're gonna see some serious shit.
12-14-2013, 12:42 PM | #4 |
Drives: Scion FR-S
Do your highbeams work with this?
12-14-2013, 12:56 PM | #5 |
12-20-2013, 02:22 AM | #6 |
The Following 2 Users Say Thank You to m.box.design For This Useful Post: | Calavera (12-20-2013), DeOppressorLiber (12-20-2013) |
12-20-2013, 08:44 AM | #7 |
Awesome job.
02-26-2014, 02:04 AM | #8 |
UW Student
Drives: '13 GBS BRZ Limited
Anymore in stock? Tried installing the spyder led headlights into my brz. Their 6 pin connector won't fit my 8 pin connector from the car. Would this solve me problem?
2013 BRZ Galaxy Blue Silica 6-SPD. 18% tint. Invidia N1 Ti-Tip. STI Rep. Lip Kit. BuddyClub LED taillights. Spyder LED headlights.
02-26-2014, 02:15 AM | #9 |
Drives: 2014 Monogram FR-S White MT
so is the led strip at full brightness when your headlights are on?
and does the led strip light up when you turn on your parking lights with hand brake up? |
02-26-2014, 03:08 AM | #10 |
would this harness work with the 10 series/monogram headlights?
02-26-2014, 03:40 AM | #11 | |
Drives: Whiteout FRS
here's how they work: OFF: - All lights off, (NO DRL function - lights off regardless of parking brake position) Parking: LED strip on High (they are on reguardless of parking brake position) Low Beam: LED strip on High + Low Beam HID High Beam: LED strip on High + Activates Solenoid for High Beam HID Note: There is no low power setting for the LED strip when the headlamps are on. They can be pretty bright at night/cause glare. |
The Following User Says Thank You to Tuan For This Useful Post: | subiestyle (02-26-2014) |
02-26-2014, 04:07 AM | #12 |
Drives: Asphalt FRS
The harnesses are AFAIK used for Base 6 pin connector to 8 pin connectors for either the 10series/Monograms headlights or JDM/EUDM headlights. Not sure if he makes a harness for 8 Pin to 8 Pin since in your info it says you drive a Monogram edition.
02-26-2014, 06:38 PM | #13 |
Drives: Raven GT86 & Subaru WRX CS6
Wish l had access to harnesses like this before l installed BRZ lights into my GT:
My DIY wiring guide (repining isn't that hard, but it means you'll need the BRZ harness): http://www.ft86club.com/forums/showthread.php?t=51769 |
02-26-2014, 10:30 PM | #14 | |
Similar Threads | ||||
Harness Bar | diirk | Tracking / Autocross / HPDE / Drifting | 38 | 07-21-2017 01:15 PM |
WTB Stock headlight projectors from retrofit OR a broken headlight | official_george | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-02-2013 03:32 PM |
wiring harness | so26 | Electronics | Audio | NAV | Infotainment | 5 | 10-30-2013 03:19 AM |
WTB: Subaru BRZ Headlight Harness Parts | enderr | Exterior Parts (Aero, Lighting, Etc.) | 3 | 08-28-2013 05:39 PM |
Lighting Harness | wawro569 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 09-09-2012 11:28 AM |
