10-17-2013, 11:34 AM | #477 |
Drives: white out frs
I'm wondering if shorter or adjustable rear end links adjusted shorter than stock might help me to factory angle? My frs is lowered on Ohlins r/t about 1.25 with cusco LCA'S. I think that the rear sway bar may be limiting suspension travel do to the angle of the rear bar being a lot higher than stock. Going up drive ways at an angle will lift one wheel do to sway bar going beyond flexable range one link way and the other side down also on hitting switch backs on an incline during aggressive driving . Also on rear suspension compression equal on both sides the sway bar angle to high where it meets end link doesn't have full pivot motion anymore hope I'm explaining please help
10-24-2013, 02:10 PM | #478 | |
Drives: BRZ - Dark Grey
I have 2 quick questions, well one might end up a lot longer...but either way: 1. What is factory rake? This is usually comparing measurements from some part of the chassis right? If I'm not mistaken, a couple inches in front of the rear wheel well, and a few inches behind the front wheel well. I'm assuming it would be measured in ratio rather than just a static measure in inches/cm. 2. How does rake affect the handling of the car and what's the magnitude of difference given say a 1/2 inch vs a 1/8 inch difference? Thanks! |
10-25-2013, 02:24 PM | #479 | |
However, it may be better to think of rake in terms of "roll axis." This is what you get when you draw a line from the rear roll center to the front. Harder to measure, but this is a better idea of looking at how things change. 2. A complicating factor in feeling the effects of changes in rake/ride height is changing the amount of bump travel you have. All else being equal, lowering the rear can increase understeer in a steady state corner since you have lowered the rear roll center...however if you are now sitting your rear on the bumpstops you will have some snap oversteer issues. On the other hand, raising the rear would make the car more prone to oversteer...but COULD help you put power to the ground on exit. Assuming you have adequate travel to work with, a 1/2 inch change in ride height can be noticeable IMO. - Andy |
11-13-2013, 01:09 AM | #480 | |
Drives: 2006 Cayman S, 2007 Outback 2.5i
Older 911s with sticky tires and a good track setup will lift an inside front tire all the time, sometimes pretty high off the ground. You can see it really clearly at about 3:15 and 8:50 (and I'm sure a couple other spots) in this video: [ame]http://youtu.be/QOAXHR3grlY[/ame] |
The Following 2 Users Say Thank You to chrisl For This Useful Post: | Racecomp Engineering (11-13-2013), solidONE (11-13-2013) |
11-13-2013, 11:41 AM | #481 |
Drives: FR-S Whiteout
So what is the main contributor, besides the tires, to the inside wheel lifting? Thick swaybar?
Intent > Content
cowardice is the mother of cruelty. |
11-14-2013, 01:36 AM | #483 |
Drives: Mazda 3
I'm curious about the top hats that add bump travel. Are the shocks okay with working at essentially higher ride height (how the shock sees itself) than it was designed to do? No one seems to have this concern but I figured it's good to get confirmation.
11-14-2013, 01:37 AM | #484 |
Okay.. So my question is on caster angles for the 86. I've read some good feed back from folks who have increase caster by 1 to .5 degrees on this car from the factory setting with good results via camber/castor plates or offset bushings.
How does increasing castor improve handing characteristics in terms of grip and feel? Would it increase cornering speeds or transitional response or both or neither? Will it likely result in faster lap times?
Intent > Content
11-14-2013, 10:38 AM | #485 | |
Even with a mild drop, lowering camber plates will be fine. - Andy |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | autobrz (11-14-2013) |
11-14-2013, 10:39 AM | #486 | |
- Andy |
11-19-2013, 01:34 PM | #488 |
Drives: Subaru BRZ - GBS
Hey guys,
Couple questions - What would you recommend for camber in the front of the car? Lots of folks say bolts, but frankly bolts seem like a hack to me. If I went with top mounts what is the preferred front top mounts for a Tarmac 0 setup, and will I need to change the rear top mounts? Thanks! |
11-19-2013, 02:30 PM | #489 |
Do you know how much camber you want? If it's a lot, say more than -2.5, then you'll want plates. We're still able to get well over -2 with just bolts on Tarmac 0 and Tarmac 2 with stock top mounts, but some other set-ups you'll be stuck with less.
Advantage to stock top mounts is no noise ever and slightly better ride so if that's important to you than it's worth sticking with them. Higher quality camber plates will be quiet if installed correctly but may ride a tiny bit harsher. You do lose the rubber though and get slightly quicker response. Most camber plates out there work with our Tarmac coilovers. Vorshlag and HVT work well. It looks like there may be a few coming from other manufacturers soon. We can work out a package if you're interested. Not too much need to change rear top mounts from stock...I'd do it on a car that is pretty track focused but the gains aren't huge. - Andy |
11-20-2013, 07:59 PM | #490 |
Ok, I have some catching up to do. I'll be back...
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
