Old 11-13-2013, 07:27 PM   #1
red_comet
Severed Member
red_comet's Avatar
Drives: Argento 2013 Scion FR-S Manual
+1 wheels, stock suspension?
If anyone is running 18's on the stock suspension, I'd love to see a picture.
I live in a place where lowering the car would rub like nuts, and I'd like to eliminate as much wheel gap as possible without going to super heavy 19's (or super expensive lightweight 19's).
Meaty tires are welcome!
Thanks
87 Volvo 760 Turbo <3
02 WRX THE QUEEN IS DEAD, LONG LIVE THE QUEEN!
06 Xfire Bite me I liked it
13 FRS doriftoooo!
DON'T PANIC
red_comet is offline   Reply With Quote
Old 11-13-2013, 07:54 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Assuming same overall diameter, going with a larger wheel does not mean you will eliminate wheel gap.
-alex
Old 11-13-2013, 07:57 PM   #3
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Hello red, try looking through the stickied thread named wheel gallery. Good luck.
Additionaly, 18's won't fill up your fender gap if you choose the correct size tires, only lowering it will.
Hitch hikers guide is one of my favorite movies.
red_comet (11-14-2013)
Old 11-13-2013, 09:09 PM   #4
rainmonkey
Drives: BRZ - Dark Grey
look for @Sony he has pictures of his car on 18's and i believe he's still on stock suspension.
rainmonkey is offline   Reply With Quote
The Following User Says Thank You to rainmonkey For This Useful Post:
Old 11-13-2013, 11:07 PM   #5
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
I'm on stock with 18x8.5 front 235/40 and 18x9.5 rear 265/35 and my car def is a little harsher ride bc of low profile but def worth it shit looks sexy as fuck man lol don't worry about going +1
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
The Following 2 Users Say Thank You to ScionFR-S For This Useful Post:
normancw (11-13-2013), red_comet (11-14-2013)
Old 11-13-2013, 11:16 PM   #6
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
If you're keeping stock rolling ration only size of wheel itself changes. Wheel gap only closes with lowering. Or: lowering springs or coilovers.
Old 11-14-2013, 04:07 PM   #7
red_comet
Severed Member
red_comet's Avatar
-alex
+1 Size wheels with thicker tires WILL cut down on dead cat gap, though admittedly not as much as lowering.
I've got in mind- 18x8 235/40r18.
13 FRS doriftoooo!
DON'T PANIC
Old 11-14-2013, 04:11 PM   #8
red_comet
Severed Member
red_comet's Avatar
I checked out his BRZ. Looks sick- tall tires without going nuts... meaty enough to cushion the ride, not too much as to bog the drivetrain or cause splashiness.
13 FRS doriftoooo!
DON'T PANIC
Old 11-14-2013, 04:25 PM   #9
Mach V Dan
FT86Club Official Vendor
Drives: 2013 BRZ, 2015 WRX, 2000 RSTi
18x8.5" Rota D.
--Dan
Mach V
Mach V Dan is offline   Reply With Quote
The Following User Says Thank You to Mach V Dan For This Useful Post:
Old 11-14-2013, 05:48 PM   #10
Gunman
Drives: 2019 Mazda Miata RF
You'll close the gap about 3/8", but also raise the car 3/8". It's up to you which looks worse, the gap, or the ground clearance. That's also a 3.18% change in circumference, so the odo will be off a fair amount.
Old 11-14-2013, 05:56 PM   #11
mav1178
mav1178's Avatar
so..... like this?
18x9 +34 & 18x9.5 +39, 245/35-18 & 255/35-18 Toyo T1 Sport.
Not lowered yet because this was a test fitment.
(honestly the gap is the same/smaller, but looks way worse in person...)
-alex
Old 11-14-2013, 09:35 PM   #12
red_comet
Severed Member
red_comet's Avatar
so..... like this?
-alex
What tires are those? Also, what's the offset of those wheels?
Thanks for the pic!
13 FRS doriftoooo!
DON'T PANIC
Old 11-14-2013, 09:38 PM   #13
red_comet
Severed Member
red_comet's Avatar
Originally Posted by Mach V Dan View Post
18x8.5" Rota D.
--Dan
Mach V
That looks very slick! Closer to what I'm thinking.
13 FRS doriftoooo!
DON'T PANIC
Old 11-14-2013, 09:48 PM   #14
mav1178
mav1178's Avatar
You should re-read my post. I typed it out for you...
-alex
Stock BRZ Suspension SubiePig Brakes, Suspension, Chassis 4 10-09-2013 10:02 AM
Perfect Wheels for Stock Suspension pcamaliga Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 05-12-2013 02:36 PM
17” OZ Alleggerita wheels with stock 215/45-17 tires… 17x7.5 or 17x8 wheels? SteveH Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 02-14-2013 10:26 PM
Aftermarket wheels with stock suspension Thongpocket Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 8 01-24-2013 05:08 PM
Not modding - wheels and suspension available Z86 AUSTRALIA 0 10-08-2012 09:48 PM
