10-31-2013, 11:28 AM | #267 |
Drives: 6MT
my 205/50/17 Michelin x-ice xi2 outperform the stock primacy HPs on dry and wet roads by far
10-31-2013, 01:15 PM | #268 | |
Drives: Takumi
10-31-2013, 02:15 PM | #269 |
Drives: 2014 BR"ZED" Sport-tech DGM MT
I'm finding the same with my Yokahamas, but I have less that 60km on them, I just need for them to settle in. It was like driving my go-kart on slick tires on a wet track. While it's a bit of fun the heart rate jumped a few times.
10-31-2013, 04:19 PM | #270 | |
Drives: 2013 WRB BRZ Sport-Tech 6MT
10-31-2013, 05:01 PM | #271 |
You call him Dr. Jones!
Drives: 2013 Twin Mish-Mash
Looks like I might be one of the last ones to get winters installed. Appointment is in a week and a half.
[IMG][/IMG]
10-31-2013, 06:30 PM | #272 |
Snow Don't Hurt!
Just got mine on a few hours ago. Now I want it to snow so I can stop sliding in the rain.
11-02-2013, 08:03 PM | #273 |
Drives: Subaru BRZ Sport Tech Satin White
Look for the Michelin branded aluminum low profile jack. It will easily fit under your car. The BRZ weighs less than 2 tonnes so you don't need a 3 ton jack.
11-03-2013, 12:31 AM | #274 | |
Drives: Raven 6 MT
Powdercoat those b!tches purple. Not the best photo, but they turned out real nice. Originally these were just generic steelies. |
11-03-2013, 10:17 AM | #275 | |
Since 30,000 km is not bad durability from a snow tire that means 6,000 km per winter and then they're worn out no matter how much tread remains. Also, snow tires should not be used down to the wear bars (no tire should actually). 5 mm of tread is not enough to work in snow. Since they start at 9-11 mm originally you only use half the tread. For summer tires 3mm remaining is the least tread you should have for rain. Finally, never use a tire more than ten years old for any reason. They are unsafe. Not all tires will fail catastrophically at ten years, most do not. The trouble is you don't know which tire will blow out at ten years. It might be on your car. |
11-09-2013, 06:53 AM | #276 |
Drives: asphalt FR-S
Blizzak rant:
I put the snows on last weekend - Blizzak ws-70 for their second season. It sure wasn't hard to tell which ones were on the back before. They will only last 2 winters, which is a good thing since they are the worst handling tires I have ever driven on. They do have good snow and ice grip, but are not very good in the rain. On dry pavement they are the terrible. They just don't want to track straight and I'm constantly fighting with the steering. The previous Blizzak iteration, the ws-60, were not like this at all. I'm going to have to adjust the wheel alignment just to accommodate the tires. I'm very disappointed that Bridgestone screwed up what used to be a good winter tire. |
11-09-2013, 09:13 AM | #277 |
Thanks
I think most (all?) snow tires handle generally terribly.
When I was researching snow tires I heard blizzaks are so soft (i.e wear so fast on non snow covered surface) they actually leave a film of black dust on your car. Not sure if that is true but I stayed away. If I drive more often than not on snow covered roads i would have got them though. The reality is in my region I'll probably only need snow tires a dozen or less days of the year. |
11-09-2013, 10:42 AM | #278 | |
11-09-2013, 10:48 AM | #279 | |
High performance winter tires on the other hand, from Pirelli, Michelin and Continental handle in cold weather just about as well as summer tires do in warm weather. In fact, I used a set of worn out Sottozeros as summer all season tires on my Jaguar XF last summer and they were unbelievably good at 5 mm tread remaining. If you want high levels of winter performance buy a set of Sottozeros Pilot Alpin 4 or Conti TS 810 or TS 830. If you want better ice grip with good bare road handling get Conti Extreme Winter Contacts, best all around snow tire made at the moment. |
The Following 2 Users Say Thank You to Suberman For This Useful Post: | grodenglaive (11-13-2013), ZionsWrath (11-09-2013) |
11-09-2013, 10:52 AM | #280 | |
Thanks
Such is the internet market, sucks... |
Similar Threads | ||||
FS: 245/40/18 Michelin Pilot Alpin PA3 Snow Tires | Chuynh207 | Wheels and Tires | 3 | 11-06-2012 01:19 PM |
snow tires | debs0712 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1 | 10-18-2012 12:58 PM |
what tires will you be using this winter for snow? | denverizzles | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 08-01-2012 11:20 PM |
How effective are snow tires? | theredtape | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 06-18-2012 07:49 PM |
Snow tires? | smbrm | CANADA | 12 | 05-27-2012 01:20 AM |
