Old 10-21-2013, 03:27 PM   #379
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Grimmspeed Exhaust Manifold (Header) Gaskets
Grimmspeed makes some exhaust manifold gaskets for our car which are much thicker than the OEM gaskets we can buy from Subaru. They look like they can seal better than stock. They appear to be the crush variety and metal rather than the pseudo ceramic/graphite/whatever it is the OEM gaskets are made of.
Just a quick pic comparison a used up gasket to a new Grimmspeed one
20131020-SubaruOEM_Grimmspeed_HeaderGasket_HeadtoHead-002 by VictorN07, on Flickr
20131020-SubaruOEM_Grimmspeed_HeaderGasket_HeadtoHead-010 by VictorN07, on Flickr
F1point4 is offline   Reply With Quote
Old 10-21-2013, 03:31 PM   #380
ATL BRZ
Driving Coach
ATL BRZ's Avatar
Originally Posted by F1point4 View Post
Parts:
2x RAM-B-218-1U - 1/4 NPT female base with 1" Ball
2x RAM-B-201U-C - Long Double Socket Arm for 1" Ball
2x RAM-B-231U - Rail base with 1" Ball
1x RAM-B-149Z-GOP1U - Handlebar GoPro Mount kit
1x 1/4 NPT Pipe size Threaded Pipe
3/4" Black Heatshrink for aesthetics (optional)
Very cool mount solution! I'd definitely put one together myself but based on my experience with GoPro filming from inside the cabin, if it's even remotely sunny outside the view out the windshield is very washed out and you can barely see anything. Unfortunately I think that's a GoPro issue and I don't know a way around that. I've been sticking mine to the outside of the car instead of in the cabin for track day filming.
Old 10-21-2013, 03:59 PM   #381
F1point4
Photo Specialist
F1point4's Avatar
Oil Cooler woes update!
Remember this?
Oil cooler sandwich plate hits? bah
20131005-OilCoolerFuelLineContact-001 by VictorN07, on Flickr
Dammit?!
20131005-OilCoolerFuelLineContact-007-Edit by VictorN07, on Flickr
I talked to my @PERRIN_Chris and he said the spacer in the Perrin kit was yay tall and I determined it was taller than the spacer included in the Racerparts Wholesale kit. After shaving down the thermostat edge, it will still hit the fuel line if I rotated the plate more. I didn't want any rubbing at all so I asked @PERRIN_Chris and he would sell me the spacer by itself! Awesome customer service.
Wanted to post some pics of the two kits side by side
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-002 by VictorN07, on Flickr
The Perrin spacer is pretty; its nice and black and has the logo printed on it. The RacerParts Wholesale spacer is 20mm tall. The Perrin one is 25mm tall. The sandwich plate sits around the narrow raised portion on the RacerParts Wholesale spacer
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-013 by VictorN07, on Flickr
Despite the Perrin Spacer being 5mm taller, the hollow bolt is the same height
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-007 by VictorN07, on Flickr
I didn't get a picture of the bottom. D'oh! The Perrin spacer has two grooves for O-rings to seal against the engine block. There are two O-Rings to make the seal. The Racerparts Wholesale just has one large flat rubber gasket. I had a failbro moment; @PERRIN_Chris didn't send me the O-Rings. I am heartbroken. However Bro 2.0 @PERRIN_Mladen pulled through and got me the O-Rings, and they will come in time for the track event this weekend. Thanks man! High quality human right there.
Here is the part installed. Purty
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-017 by VictorN07, on Flickr
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-036 by VictorN07, on Flickr
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-043 by VictorN07, on Flickr
Photo from my camera showing the new clearance. I can rotate the sandwich plate all around and it wont' hit. I love it.
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-031 by VictorN07, on Flickr
iPhone 5S has a spectacular camera too. These are just cropped. No processing.
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-iPhone5S-044 by VictorN07, on Flickr
20131020-Perrin_RacerPartsWholesale_Spacer_HeadtoHead-iPhone5S-045 by VictorN07, on Flickr
P.S. I still love you @PERRIN_Chris
The Following 2 Users Say Thank You to F1point4 For This Useful Post:
PERRIN_Chris (11-13-2013), PERRIN_Mladen (10-21-2013)
Old 10-21-2013, 04:38 PM   #382
PERRIN_Mladen
PERRIN_Mladen's Avatar
Drives: '11 535i
You have me dying right now!
PERRIN_Mladen is offline   Reply With Quote
Old 10-21-2013, 04:44 PM   #383
F1point4
Photo Specialist
F1point4's Avatar
A Dying Breed/Regular Maintenance
Another part of my install day was to replace my Perrin 2.5" HFC Front Pipe with.... another Perrin 2.5" HFC Front Pipe. Did you know that replacing your front pipe is part of your annual maintenance?
I'm kidding. A while back I had a bung welded in my front pipe for a wideband O2 gauge
Since installing the @P&L Motorsports HFC Coated EL Header, I didn't need this bung anymore. The header has one. @Chris@Phastek wanted the extra bung for his purposes which I shall not divulge but he was kind enough to pick up a new pipe for me. Perrin has decided to stop making exhaust pieces that modify OEM emissions equipment, so this new pipe will be on of the last pipes available.
I took some photos to show how the front pipe ages. Mine has exactly one year and 17000 miles on it. I bought the headerback right when it was released. It turned blue from all the heat. Also mine doesn't even have the Perrin logo tack welded to it. A truly limited edition piece. Bought one of the first and got ended up with one of the last
Thanks @Chris@Phastek for the assistance installing it!
20131020-PerrinHFCFrontPipeRedux-026 by VictorN07, on Flickr
20131020-PerrinHFCFrontPipeRedux-029 by VictorN07, on Flickr
Nothing really has changed. Still the same quality part. Great welds
20131020-PerrinHFCFrontPipeRedux-036 by VictorN07, on Flickr
20131020-PerrinHFCFrontPipeRedux-038 by VictorN07, on Flickr
This is the cat on my original front pipe with 17000 miles on it. 10000 miles of it were Vortech Supercharged. Held up nicely. Great part.
20131020-PerrinHFCFrontPipeRedux-051 by VictorN07, on Flickr
20131020-PerrinHFCFrontPipeRedux-055 by VictorN07, on Flickr
What's wrong here?
20131020-PerrinHFCFrontPipeRedux-059 by VictorN07, on Flickr
Finally some rep. Shoutout to @PERRIN_Chris and @PERRIN_Mladen. My Bros.
20131020-PerrinHFCFrontPipeRedux-061 by VictorN07, on Flickr
Dezoris (10-31-2013), PERRIN_Mladen (10-21-2013)
Old 10-21-2013, 05:00 PM   #384
F1point4
Photo Specialist
F1point4's Avatar
Doctor's Appointment
@Chris@Phastek and I were curious to see what numbers I was making using the latest Perrin tune (I think i'm on V10) as well as all the exhaust work I am doing. It was also great weather to strap her down and do a health check. It was probably about 75-80F outside with low humidity! Thank you cold front.
I've had the kit installed since the beginning of March and have logged 10k miles on it.
Vortech Supercharger with 9PSI 3.48" Pulley
Freshly cleaned air filtre
Perrin Tuned V10
P&L Motorsports EL HFC Coated Exhaust Manifold
P&L Motorsports 2.5" Coated Overpipe V1
Perrin Performance 2.5" HFC Front Pipe
Perrin Performance 2.5" Resonated Catback
Stock fuel system (Injectors/pump)
Stock Crank pulley
Gates Black Belt
Thanks to all for their support throughout my journey so far.
@Chris@Phastek, @Rick@Vortech, @Brian@Vortech, @P&L Motorsports, @PERRIN_Jeff, @PERRIN_Chris, @PERRIN_Mladen, @Dezoris
We did six pulls. I plotted three. So close to 200 torques! I would say Lola's doing just fine
RunFile_005 and 006 are map4
RunFile_002 is map 3. I daily drive and track using this map.
20131020-FallDynoCheckup-012 by VictorN07, on Flickr
20131020-FallDynoCheckup-006-Edit by VictorN07, on Flickr
Amadeus (10-21-2013), Dezoris (10-31-2013)
Old 10-21-2013, 10:52 PM   #385
F1point4
Photo Specialist
F1point4's Avatar
Random old photos
These sort of fell through the cracks
20131006-PostTrackCarWash-008-Edit by VictorN07, on Flickr
20131005-OctGrandPrixCarsAndCoffee-001 by VictorN07, on Flickr
Rally BRZ on the left
20131005-OctGrandPrixCarsAndCoffee-022-Edit by VictorN07, on Flickr
20131005-OctGrandPrixCarsAndCoffee-078 by VictorN07, on Flickr
20131005-OctGrandPrixCarsAndCoffee-095 by VictorN07, on Flickr
This was nice
20131005-OctGrandPrixCarsAndCoffee-192 by VictorN07, on Flickr
Badges of Honour
20131004-PostTrackInspection-003 by VictorN07, on Flickr
Look forward to doing much more
20131004-PostTrackInspection-010 by VictorN07, on Flickr
Old 10-22-2013, 10:19 AM   #386
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Love your pictures and your progress reports! Great stuff.
Mad1723 is offline   Reply With Quote
The Following User Says Thank You to Mad1723 For This Useful Post:
F1point4 (10-22-2013)
Old 10-22-2013, 10:18 PM   #387
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Great build! Looks like I'm going your route. Getting a vortech soon and also planning to get a homebrew oil cooler. Thanks for the heads up.
Tye300 is offline   Reply With Quote
The Following User Says Thank You to Tye300 For This Useful Post:
Old 10-23-2013, 05:22 PM   #388
stevo_12v
stevo_12v's Avatar
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I quite like those WHITELINE gloves that mechanic has on!
[CENTER]
Build thread
stevo_12v is offline   Reply With Quote
Old 10-29-2013, 10:56 AM   #389
F1point4
Photo Specialist
F1point4's Avatar
Track Day!!!
Still working on the rest of the media. First go at using a GoPro and Adobe Premiere Pro CC. I think it came out good overall. Lot's of room for improvement (as my instructor showed me when I let him have a proper go in my car) Love the very end.
[ame="http://www.youtube.com/watch?v=Ge0phVWFOrg"]The Drivers Edge - MSRH - CCW - Day 2 Session 4 - YouTube[/ame]
Old 10-29-2013, 11:09 AM   #390
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Looks fun, Victor... I've never got to run MSRH in a CCW direction... looks fun! Oh, and you definitely need a louder BOV. I could still hear the engine a little bit.
cobrabyte is offline   Reply With Quote
The Following User Says Thank You to cobrabyte For This Useful Post:
F1point4 (10-29-2013)
Old 10-29-2013, 11:23 AM   #391
F1point4
Photo Specialist
F1point4's Avatar
The worst part about the BOV is that the whistling tells you when i let off the gas. :|
people said they could hear my car in the paddocks hahaha.
Now that I tracked it and DD'd it with the BOV, I'm deciding if its something I want to keep.
Old 10-29-2013, 11:30 AM   #392
cobrabyte
cobrabyte's Avatar
It definitely doubles as an audible throttle position sensor... I could hear every time you lifted! In all seriousness, it did look like a fun track day. Hope you get a chance to drop by this weekend if you're not going to be at COTA or TWS.
Asphalt Scion FR-S aznsensazian FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 21 03-17-2014 01:13 PM
Asphalt FR-S pics Rob_g CANADA 24 09-03-2012 05:01 AM
Asphalt in the snow Double4Free Scion FR-S / Toyota 86 GT86 General Forum 5 06-10-2012 01:56 PM
Asphalt 6MT FR-S Symbiont Southern California 22 06-06-2012 07:47 AM
ant08 Asphalt MT ant08 Member's Car Journals 3 06-04-2012 04:16 PM
