#16941 |
Wayward Member
Drives: Hot Lava 86
Hmm... Carbon fiber lip kit? Maybe... Carbon fiber trim/spoiler to go with? Or stay color-matched? *Thinkthinkthink*
#16942 | |
Drives: '06 AM V8V Coupe
I think the cost in Ti is the super high amount of energy required more than anything else, so 3d printing would probably not work so well. |
#16943 | |
Kuruma Otaku
The 3d printing of sintered Ti has been used for a while now to make medical and dental implants. The fact that sintering isn't 100% density is probably an advantage there so bone can grow into the parts or something. With selective laser melting/fusing, they are fully melting the powder so the parts are 100% density, basically the same as cast. I've seen Inconel parts made this way. I'm guessing that Ti could be SLM printed as well, which would be awesome. However part size and machine prices are not where I would like them to be. Heh...
Because titanium. |
#16944 | |
WUB WUB
Drives: 2013 Firestorm
#16945 |
Drives: RX-7 / BRZ
Crowded traffic. So the state decides to build another bridge. Bigger, wider, more lanes. And the possibility (since it is 6ft away from the old bride) that each bridge will be for one way traffic...
Nope they tore down the other bridge and the only difference it they added a shoulder on the new one. Hooray for re-establishing the same traffic flow (or lack of.) |
#16946 | |
Kuruma Otaku
I still think that they can do it in normal atmosphere if they include fluxes and deoxidizers in the powder. The lasers can do fancy things really quickly with how they pulse. A flux just floats on top to provide a physical barrier from atmosphere when the metal melts, but leaves a slag on top when cool. Laser could be setup to fire different strength and duration. First pulse is set up to melt the metal and flux. It cools leaving metal under slag. Second pulse is set up to vaporize just the slag on top, leaving just the pure metal for the next powder layer to cover. Something like that. Edit: @serialk11r Did I read above about you saying positive things about the 2GR? I thought I mentioned before that there is a member on here that has/had a 2GR-swapped Spyder and you were all 'meh'? Was it @Rampage ?
Because titanium. Last edited by Dimman; 08-24-2013 at 03:10 PM. Reason: edit: |
#16947 |
Site Moderator
Drives: ichi 86 Project
Damn it! Song "Sail" stuck in my head...
#16948 | |
I don't like the 2GR stock, that's for sure. In a Spyder, it's too much power for my taste. In a bigger car like the Evora, let that thing spin to 8000 and then we're talking. |
#16949 |
Poor College Kid
Drives: ~.~
The Following User Says Thank You to Kelbyat07 For This Useful Post: | ichitaka05 (08-25-2013) |
#16950 | |
Kuruma Otaku
I'm pretty sick of my clutch in the Supra. It was selected for when the the car is tuned to take advantage of the turbo's 400whp capability. So now I have worse than normal lag, a heavy and grabby clutch, finicky idle and tip-in at low rpm and only about 300whp. If I get the standalone and tune, I lose the idle and tip in issue, gain 100whp, but still have the unpleasant clutch and lag. A 2GR Spyder with D4-S (not sure if that works with a transverse layout, though) ends up with only very slightly worse power-weight, better handling and fuel economy, stock engine/clutch drivability and no lag. Woulda, shoulda, coulda...
Because titanium. |
#16951 | |
Drives: Attitude
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | Dimman (08-24-2013) |
#16952 |
WUB WUB
we can dance if we want to,
we can leave your friends behind. because your friends don't dance and if they don't dance well they're no friends of mine
The Following User Says Thank You to wrxgoose For This Useful Post: | ichitaka05 (08-25-2013) |
#16953 | |
A 2GR Spyder would have a 40-60ish weight distribution, it would hook up the rear tires pretty well. Lotus lets them rev up to 7200rpm with the sport button, meaning you could likely drop in some slightly bigger cams that make peak power at 6500 or so and get over 300hp (probably want a standalone to unlock more horses though as the stock ECU probably dumps way too much fuel down the exhaust at high rpm). Actually speaking of rich AFRs, I wonder if using E25-30 increases horsepower on a stock vehicle because I think ethanol is supposed to do better when running ultra rich than gasoline. lol. I mainly say that because in 1st gear the clutch springs get loaded up just from letting off on the throttle a tiny bit, even with my shit Primewell rear tires. It's extremely uncomfortable. I think a 2ZZ would make me happy, though I would get the cams regrinded for less low rpm torque for the same reason. Not hard to hit 5000rpm and get the real power. |
#16954 |
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
Waldo is back! Oh how this forum has grown.
![]() Walk like a King, Be like a Sir, Swag it out like a Boss |
The Following User Says Thank You to S2kphile For This Useful Post: | M-17 (08-26-2013) |
h6 swapouts? any thoughts or advice? | f1ver | BRZ First-Gen (2012+) -- General Topics | 53 | 11-21-2014 11:46 PM |
Aspera's thoughts on AWD/RWD... | aspera | Scion FR-S / Toyota 86 GT86 General Forum | 89 | 11-16-2013 02:55 PM |
random casual discussion on dynamic brakes | serialk11r | Other Vehicles & General Automotive Discussions | 4 | 07-16-2012 09:34 PM |
The "if you wanna kiss the backside of white musicians make a thread about it" Thread | aliphian | Off-Topic Lounge [WARNING: NO POLITICS] | 8 | 12-19-2011 07:59 PM |
