Tracking / Autocross / HPDE / Drifting What these cars were built for! |
08-22-2013, 09:16 AM | #281 | |
Drives: FR-S 6MT
08-23-2013, 09:44 AM | #282 |
Drives: 2013 FRS / 2013 427 Vert
I went with 5-40 just for last weekend and my daily driving temp went from ~204 up to ~212 immediately.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
The Following User Says Thank You to Deep Six For This Useful Post: | WolfpackS2k (09-05-2013) |
08-23-2013, 10:10 AM | #283 |
Drives: White
Sans-thermostat plate here, with a 1qt core, daily temps are right about 185-190F at the sandwich plate in stop and go during the day. Temps are about 175-185F during the cooler night time. Oil is 0w30 German Castrol.
I'll be logging and watching temps at VIR next week to see what sort of heat is generated. Logging peak/hold via a prosport sender and comparing to OBDII. The factory and my sender are quite close to each other, so it will be interesting to see how wildly they vary. It's probably pretty important to add to the thread - oil temps are going to vary greatly depending where you are taking your reading. If you are using OBDII (torque, etc), you will probably see a more inaccurate reading, as opposed to an aftermarket gauge and sender. I wouldn't live or die by the obdII readings. You may even see a 30F+ difference between the reading at the filter and a reading in the pan. |
08-23-2013, 03:05 PM | #284 | |
Drives: SSM LT MT BRZ
I am the designer and manufacturer of the sandwich plate, We are still working on getting the production numbers up to try and support everyone let down by other offerings. currently we are just trying to keep up with Robi's orders for his cooling solution but in the coming weeks we will be able to batch these far more effectively. We are working VERY hard to keep these reasonable in price even though obviously there is far more involved here than a simple Cast adapter with no thought to integration on a specific platform...did I mention made in the USA form domestic source 6061-T651 Aluminum and 304SST for the center post, ORB fittings to the AS spec and I make the ORB-AN's in house because I couldn't find offerings in the aftermarket that actually met the AN spec for ID with the optional radius entry? @robispec |
The Following 6 Users Say Thank You to SkullWorks For This Useful Post: | CSG Mike (08-23-2013), Deep Six (08-23-2013), ImperiousRex (08-23-2013), robispec (08-23-2013), WolfpackS2k (08-23-2013), wootwoot (08-23-2013) |
08-23-2013, 07:21 PM | #285 | |
Drives: Moped
08-23-2013, 07:58 PM | #286 |
Drives: Attitude
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | SkullWorks (08-23-2013) |
08-23-2013, 08:20 PM | #287 |
I happen to be one of those waiting patiently.
I will not track anymore without the cooler as 270+ will take its toll eventually.
[SIGPIC][/SIGPIC]
09-03-2013, 07:19 PM | #288 |
Site Moderator
Drives: Stuff
I bypassed it if that's considered a fix. Not a priorty since it's not the primary track car anymore.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
04-22-2018, 08:07 AM | #289 |
Drives: Blue BRZ
how much did it cost you to make a DIY oil cooler, and how was it holding up? thank you
04-25-2018, 09:25 AM | #290 |
Drives: '13 FR-S
I know this thread is ancient and plenty of people have probably covered everything a ton of times, but I recently installed the mishimoto 19-row cooler and an AEM temp gauge (mounted the sensor into the mishimoto sandwich plate).
My first track day with it won't be for a few weeks, but so far so good. The kit went together REALLY easily and fit perfectly aside from needing to shave a bit of extra plastic off the oil fill cap to clear the temp probe from that side of the sandwich plate. Zero leaks, everything flows nicely and the gauge has shown me how freaking effective the 19-row cooler is. Holy cow. |
04-25-2018, 11:43 AM | #291 | |
Undisputed El Presidente
Drives: Zenki 37J ZN6
use quality parts and it won't be an issue. Parts list here: http://www.ft86club.com/forums/showp...&postcount=126 Its around $400 iirc, but that was years ago so prices may have gone up. RacerPartsWholesale.com is cheapest (and linked in the list I shared) |
04-25-2018, 01:20 PM | #292 | |
Re-torque them the night before your track day, and regularly re-torque them to make sure they fail. Heck, even safety wire it if you can. |
The Following 2 Users Say Thank You to CSG Mike For This Useful Post: | CatDaddysBBQ (04-26-2018), Icecreamtruk (04-26-2018) |
04-25-2018, 02:13 PM | #293 |
Drives: 2016 White Pearl BRZ Premium
Wrong Thread!
The Following User Says Thank You to Joesurf79 For This Useful Post: | Code Monkey (04-25-2018) |
04-26-2018, 09:45 AM | #294 | |
Drives: '13 FR-S
Similar Threads | ||||
Oil Cooler | wootwoot | Engine, Exhaust, Transmission | 92 | 12-27-2014 08:10 PM |
ARC Oil Cooler | ill86 | Engine, Exhaust, Transmission | 19 | 10-18-2014 04:30 PM |
One-Off Oil Cooler? | wootwoot | Engine, Exhaust, Transmission | 37 | 07-18-2014 05:42 PM |
Oil Cooler kit for FI applications, getting one? | JoeBoxer | Forced Induction | 84 | 01-20-2013 09:48 AM |
Cooler than drifting! | Rampage | Other Vehicles & General Automotive Discussions | 8 | 04-03-2012 12:55 AM |
