Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-12-2013, 12:21 AM | #1 |
Drives: WRB 2013 Subaru BRZ Limited
PST Carbon Fiber Driveshaft
Ok guys installed my PST carbon fiber driveshaft, now as some of you know the shaft does not come with instructions, I mean 4 bolts... how hard is it?! HaHa
Required Tools: 14mm Wrench 14mm Socket Extention (I used a 4in) 0-100 Ft LBS torque wrench Wooden Hammer White out Removing the old shaft is easy and CAN be done with the car on jack stands but trust me WAY easier to put the car on a lift. First we lifted the car up, (leave the ebrake off) Break the torque on the (4) bolts (14mm) that are on the Rear Diff leave one bolt in hand tightened. Hold the shaft up while you remove the carrier bearing 2 (14mm) bolts Remove last bolt on the Rear diff holding up the shaft. (you MIGHT have to loosen your mid pipe, our Perrin Res Midpipe had to be loosen to let the bearing through) Once Bearing is out slide the shaft out of the transmission (some oil will come out not much though)(lightly tap the drive shaft with the wooden hammer to help it come out of the rear diff) Do the steps in reverse to install your new drive shaft!! Torque bolts on drive shaft to 55FT LBS (mark ONE bolt hole with white out where it connects to the rear diff this will be explained later) Now this is the bit that we had to figure out on our own! PROBLEM!!!! At around 70-80mph there was a vibration not crazy but you could tell that something was not right. Had to talk to a few people at Subaru and PST to figure out what was going on... we found that the shaft can be installed 4 different ways, so if one way did not work, rotate the plate 90 degrees (where your white out mark comes in) and test drive again. Make sure you torque the bolts back down before test driving again until you find a rotation with little to NO vibration. It should feel smooth not harsh or noticeable. Once we got it all figured out everything felt much better no more vibrations at 70-80+ and the car feels more alive than it did not like it was dragging its feet... haha As always feel free to ask questions, and anyone who is in the San Diego area that would like to feel it or need help with the install let me know! BIG shout out to the guys at Frank Subaru who always get me great deals on performance parts for my BRZ really wish more FRS guys went there HAHA!!! And Rally Sport Direct who again get great deals on awesome parts!!!
Full Perrin Intake/ Perrin Cat-Back /PST Carbon Fiber Drive Shaft/ 5% Tint All around Build Link:http://www.ft86club.com/forums/showthread.php?t=44038 |
The Following 3 Users Say Thank You to crank For This Useful Post: |
08-12-2013, 10:52 AM | #2 |
Drives: 86
What other mods do you have on the car?
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
08-12-2013, 11:02 AM | #3 | |
degrees
Drives: 6MT BRZ
I've been reluctant to buy one since carbon driveshafts are typically half the weight but twice the diameter (or more). Physics says this would negate most or all of the weight savings. But, perhaps it works more efficiently on our cars due to the low curb weight. Here's a good article on the subject of rotating mass: http://www.w8ji.com/rotating_mass_acceleration.htm Read "Drive Shaft Example" toward the top and "Rotating Mass" toward the bottom. |
08-12-2013, 02:53 PM | #4 |
I believe the PST one is close to stock diameter?
08-12-2013, 03:22 PM | #5 |
degrees
Drives: 6MT BRZ
I've only seen the Powertrain Industries and Driveshaft Shop shafts in person. If PST is as small as stock then that could easily make the physics issue moot.
DSS was a reasonable size but I didn't like their carbon layup. PTI had forged ends but the tubing diameter was massive. That leaves PST. Looking forward to what @crank can add. |
08-12-2013, 03:49 PM | #6 | |
Yes it is very close I will get the measurements later
08-12-2013, 03:50 PM | #7 |
And yes to me worth every penny!!
08-12-2013, 08:43 PM | #8 |
Nice info and thanks for posting!! I was not aware the initial placement during install could make a different which could be adjusted (plate rotate) if needed as you noted.
The Following User Says Thank You to Captain Insano For This Useful Post: | crank (08-12-2013) |
08-13-2013, 12:17 AM | #9 |
Drives: Firestorm 86
What's the weight if these carbon drive shaft?
I've read stock is about 25 lbs and there's an aluminum drive shaft thats about 12 lbs |
08-13-2013, 01:49 AM | #10 | |
the shaft is 13.9lbs and is close to the stock diameter I will try to get a measurement next time I have the car up for an oil change which is coming up what is the cost of the aluminum shaft? and is it really 12 pounds? whats the diameter?
08-13-2013, 01:54 AM | #11 |
Drives: Attitude
08-13-2013, 01:56 AM | #12 | |
Here's the tread http://www.ft86club.com/forums/showthread.php?t=44150 |
08-13-2013, 01:57 AM | #13 |
Yeah that concerns me because if the diameter is much larger you run the risk of hitting your resonator if you have one, or hitting one of the screws pointing down about midway down the tunnel, with the carbon one there is about a 3 in clearance
08-13-2013, 02:01 AM | #14 | |
Drives: Attitude
Similar Threads | ||||
DIY: Driveshaft Shop (DSS) Carbon Fibre Driveshaft | F1point4 | DIY (Do-It-Yourself) Guides | 67 | 04-17-2021 05:21 PM |
Driveshaft Shop Carbon Fiber Shafts Explained | Driveshaft Shop | Engine, Exhaust, Transmission | 121 | 11-17-2017 11:57 AM |
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! | F-T | Exterior Parts - The Rest | 285 | 08-24-2015 04:42 PM |
FS SoCal PST Carbon Fiber Driveshaft | evilconcarne999 | Transmission and Driveline | 8 | 09-02-2013 04:36 AM |
Automatic Carbon Fiber Driveshaft? Yes! | RallySport Direct | Engine, Exhaust, Transmission | 13 | 12-15-2012 12:40 AM |
