07-30-2013, 10:49 PM | #1233 | |
Drives: RED BRZ
The bolt pattern and PCD of our cars are 5 x 100 and not 5 x 108. You also have to consider the offset and width of the mag wheels you are choosing. For offset, the safe values are from +35 to +48. The lower the offset the more it will stick out from the fender. The higher the offset the more it is tucked into the fender. In terms of width, the safe values are from 7.0 to 9.5 inches. For reference our stock mags are 5x100 bolt pattern, 17 inches in diameter, 7.0 inches in width, offset +48. For mags (17 to 19 inches) that would fit your 86 you can source them from: Originals: AUTOPLUS SPORTZENTRIUM, AUTOLINE MOTORSPORT and TYRE RACK ROTA and LINEA CORSE mags: STIVO CONCEPTS Original and Replica mags: AUTOKOZMETIX, BANAWE CAR CARE CENTER, BENS OK, BLUELINE CAR ACCESSORIES, CONCEPT ONE WHEELS, GARAGE ONE, GOMAGS, KO HIGH OCTANE MARKETING and almost any mags shop in Banawe. You will have more options in terms of design if you went with 18 inch mags. You can make arrangement with them to ship to Koronadal if your car is not in Metro Manila. Hope this helps. |
07-30-2013, 11:18 PM | #1234 |
Drives: Toyota T86
big thanks NIKDENG!
07-31-2013, 10:55 AM | #1235 |
Drives: Subaru BRZ ZC6 Lightning Red
some members here meetup on a regular basis. check out the fb group, they post it there
"He who shall be last, shall be sideways and smiling." - Jeremy Clarkson, Top Gear S19E3
07-31-2013, 09:01 PM | #1236 | |
Drives: Toyota 86
PM me sir if meron get together again... will check updates as well sa FB group. Godspeed |
07-31-2013, 11:22 PM | #1237 | |
08-01-2013, 12:02 AM | #1238 |
Drives: A Car
TRD Sound Changer
Hi guys! First time to post here. Anyway, I accidentally bought 2 sets of the TRD sound changer so I'm selling the extra set. The item is brand new. I just got it today, fresh from Japan. If anyone is interested, send me a message. Thanks!
08-01-2013, 03:08 AM | #1239 | |
Drives: Toyota 86
The Following User Says Thank You to HRTROB For This Useful Post: | rockers_kitoy (08-02-2013) |
08-01-2013, 11:36 AM | #1240 |
Drives: Gt86
08-02-2013, 12:28 AM | #1241 |
check PM
08-02-2013, 12:46 AM | #1242 |
Drives: Gt86
08-04-2013, 12:49 PM | #1243 |
Drives: Black 86
if you guys need tires for 18's and 19's I have Achilles Tires for you guys at very reasonable prices 0917-8838471
08-04-2013, 08:26 PM | #1244 |
Drives: Toyota 86
@dagame.. missed this invites, sayang. We did went there at BRC the next day. hope to see you guys soon to get pointers...
08-04-2013, 08:30 PM | #1245 | |
Drives: Toyota 86
08-04-2013, 10:55 PM | #1246 | |
Drives: RED BRZ
For 18x9.5 wheels at the rear, the higher offset 44 tucks the wheels in by 13.5 mm so you can lower your car even with wide tires (series 245 and above) without any rubbing issues. Go with this set-up if you track your car. Will give you the slammed look when lowered. The lower offset 38 at the rear makes the wheels almost flush with the rear fender with just a 4.5 mm clearance. You can still lower it but are limited to series 235 wide tires and below without having to tinker around with suspension geometry and fender rolling. Will give you the stanced / flush look when lowered. |
The Following User Says Thank You to NIKDENG For This Useful Post: | melon (08-06-2013) |
