06-14-2013, 12:10 AM | #449 |
Drives: Whiteout FRS
06-14-2013, 02:57 AM | #450 |
Drives: Toyota 86
06-14-2013, 08:30 AM | #451 |
Drives: argento frs; 90 mustang gt
wonder if i installed mine incorrectly.. still throwing the cel at least once a week.
ive an angled spacer from bigdaddiesgarage. i screwed it in close to bottoming out the spacer, then tightened the secondary nut on it. should it be higher?
06-14-2013, 12:12 PM | #452 |
Drives: Toyota 86
The angled spacer I got was a bit long, so I wasn't able to screw it in that much since the header to overpipe flange was in the way. I just used the secondary nut to tighten it down. If you're still gettig a CEL, maybe you can try backing off the spacer a bit?
The Following User Says Thank You to HRTROB For This Useful Post: | sinigang_guy (06-16-2013) |
06-16-2013, 01:34 PM | #453 |
yup, will have to try this until im able to get a tune..
06-16-2013, 02:21 PM | #454 | |
working on in-cabin and outside samples..
06-17-2013, 12:17 PM | #455 |
Thupercharged
Did anyone hear about the even more recent tooling changes?
I'm waiting on my third header, and they said that the newest tooling batch was completed on 6-7-2013....
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
06-21-2013, 02:48 PM | #456 |
08-16-2013, 01:38 AM | #457 |
Thumper
Drives: 2013 FRS
I just ordered this header from you guys. I haven't quite found a video of my setup.. borla uel, perrin resonated catback, invidia catless front pipe, motiv overpipe. Which of your setups that you have tested would sound most like this...in your opinion? Just cant seem to find one with the combo of resonated catback/catless front pipe with the header.
Car is gone - parts for sale
08-20-2013, 03:32 PM | #458 | |
08-20-2013, 09:54 PM | #459 | |
Thumper
Drives: 2013 FRS
Only one issue. I torqued everything down to spec...even made sure the flanges looked straight and were clean. The header is making a weird sound. As I've seen someone describe it as a tinny(not tiny) sound..not quite like a hissing leak, though. I've only made one 10 minute trip it in but it does it whenever on the gas. It's especially noticeable in the first few gears. I'm hoping it's not a leak but just that the metal is thin. It's not a pleasant sound. Also, the pipes at the first o2 sensor are about touching...its a tight enough fit that you cant push a piece of folded paper through it.
08-20-2013, 09:57 PM | #460 | |
Drives: 2013 BRZ Limited
08-20-2013, 10:00 PM | #461 |
Thumper
Drives: 2013 FRS
I hope I can figure it out. I won't be able to keep it like that.
08-20-2013, 10:01 PM | #462 | |
Hard to say without hearing it first hand. The walls of the header due to thinness will create some extra noise that may fit this description. I'm half deaf anymore though.. |
Similar Threads | ||||
Borla UEL Header, any dynos yet? | FR-S Matt | Engine, Exhaust, Transmission | 111 | 05-16-2016 09:31 PM |
AEM Tuned Intake - Pics / Videos / Dynos - FT-86 SpeedFactory Review | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 136 | 11-05-2015 07:48 AM |
Fortune Auto - SpeedFactory Review - Video / Pics - Tracked / Autoxed / Drifted | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 47 | 01-29-2015 09:15 PM |
Buddy Club Spec II - FT-86 SpeedFactory Review - Photos and Videos | FT-86 SpeedFactory | Engine, Exhaust, Transmission | 35 | 03-17-2013 10:46 PM |
