12-08-2013, 01:26 PM | #2325 |
Road Warrior
Drives: Toyota 86 Satin Pearl White
I'm on 75mm pulley, I asked Bill to give me map 1 on pumpgas and Map 2 with Torco.
12-08-2013, 02:36 PM | #2326 | |
Drives: 2013 SWP BRZ
I started hearing a noise the past few days, it comes and goes, but I'm wondering if its the pulley. |
12-09-2013, 10:10 AM | #2327 | |
NW Region Moderator
Drives: FR-S No More
12-11-2013, 09:29 PM | #2328 |
WUB WUB
Drives: 2013 Firestorm
so is anyone else having issues with their tensioner and the belt?
12-11-2013, 10:38 PM | #2329 | |
Road Warrior
Got me eye on the Raceseng tensioner pulley, they look hardcore compared to the plastic pulleys. |
12-11-2013, 10:44 PM | #2330 |
WUB WUB
is it a manual, or automatic tensioner?
12-11-2013, 10:52 PM | #2331 |
Road Warrior
12-11-2013, 10:54 PM | #2332 |
WUB WUB
that's what it seems to be, but when i get on it, it slacks, and that seems to be why my belt is comin off and eating stuff
12-11-2013, 11:06 PM | #2333 |
Road Warrior
Try the Blue Gates, tension is far better and I'm sure it reduces drag. I've done almost 2000km now no issue and the belt running super smooth now that it worn in.
12-11-2013, 11:09 PM | #2334 |
WUB WUB
even with driving as hard as you can? that's the only times i seem to be having problems
12-11-2013, 11:16 PM | #2335 |
my blue gates belt is working problem free with my 70mm pulley. Then again, I never had issues with the belt, stock or not.
goose, did you check your supercharger pulley to make sure it was rotating correctly? I remember someone having an issue when turning the pulley by hand with the belt off and it had a "wobble." Maybe this is cause it to come off? I don't beat on my car but I have done a lot of logging so a lot of WOT pulls and i've never had issues. I have been "stomping" it lately (low rpm, just WOT) with the blue gates belt and putting some more strain on things and still no issues. |
12-12-2013, 04:20 AM | #2336 |
Drives: 2013 Black FR-S
I've tracked this kit maybe 5 times and had no problems with the belt. 75 mm and 70 mm pulleys.
@whataboutbob, what about you and all your autoX? |
12-12-2013, 10:12 PM | #2337 |
AutoX-10/10ths every run
@sw20kosh I had the idler pulley go out on me and tried to space the replacement unit Innovate sent me out so that the belt was more centered on it. The next AutoX event I took a very nasty spin and came back into grid to find that it had thrown the belt completely off, but the belt was not damaged. I immediately removed my spacing modification and put a new belt on and did the rest of my runs. I've probably put about 2K miles and a couple of AutoX days on the setup since and have had no belt or idler pulley issues since. FYI I am still using the 75mm pulley and plan to continue to do so.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
12-13-2013, 04:43 PM | #2338 |
The Following User Says Thank You to DriftEm For This Useful Post: | akuhei (12-13-2013) |
Similar Threads | ||||
Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
