04-11-2016, 05:17 PM | #2255 | |
The Stig's German cousin
But yeah, ruling out knock would be my first step. My tune has been rock solid on the street but I saw very minor IAM drop at an autocross, and it wasn't even that hot out. Still need to verify it can handle 95-100 degree temps without changes, or maybe I'll add some 100 octane on race day. |
The Following User Says Thank You to renfield90 For This Useful Post: | DocWalt (04-11-2016) |
04-11-2016, 05:20 PM | #2256 |
Drives: Many
No idea. I bought the strano bar and then ordered the endlinks separately.
These posts pointed me in the right direction: http://www.ft86club.com/forums/showt...02#post1621802 http://www.ft86club.com/forums/showthread.php?t=76075 |
The Following 2 Users Say Thank You to e1_griego For This Useful Post: | smg1138 (04-11-2016), strat61caster (04-11-2016) |
04-11-2016, 09:26 PM | #2257 |
Drives: 1993 Impreza w/ WRX Swap + FWD!
Bilstein. The Endlink mounts are in a much different location so ya, had to use adjustables. I have zero clunks as well.
04-11-2016, 09:35 PM | #2258 |
Drives: Ultramarine FR-S
I have the whitelines and they clunked a lot when I first got them. Issue seems to be that you really need to tighten the crap out of the adjustable bit of them. Once i did that they have been totally fine.
04-12-2016, 11:36 AM | #2259 | |
Drives: 2013 Raven FR-S
04-13-2016, 12:00 PM | #2261 |
04-13-2016, 12:30 PM | #2262 |
Drives: Many
Can build your own if you want to go that route:
http://forums.vwvortex.com/showthrea...-Sway-Endlinks If the stock bar used m10-sized things then there are a few other universal options, but m12 is more limited. |
04-13-2016, 12:48 PM | #2263 | |
Drives: 2014 FR-S
04-14-2016, 10:28 AM | #2264 |
About how much rear toe are most people running in STX? Right now I'm at zero toe front and back, but feel like adding some rear toe could help with stability. Would 0.15 each side be too much?
04-14-2016, 10:54 AM | #2265 |
Drives: '22 BRZ
I'm at 1/8" total toe in. Seems fine, but I don't have enough experience with other RWD cars or different alignment settings to know what's best in this case.
04-14-2016, 11:13 AM | #2266 |
Drives: 2017 BRZ
I'm considering a little, but am running zero. I haven't found stability to be an obvious issue. Every setup is different in other ways too so different things may work for each of us.
04-14-2016, 03:00 PM | #2267 | |
Drives: 2014 FR-S
http://www.ft86club.com/forums/showt...=101262&page=3 Last edited by Silverspeed; 04-14-2016 at 03:03 PM. Reason: I'm dumb and forgot to post the reason for posting... |
The Following User Says Thank You to Silverspeed For This Useful Post: | smg1138 (04-14-2016) |
04-16-2016, 09:29 PM | #2268 |
The Blue GT lost 11 lbs today!
We installed a new battery from NAPA today, the original was weak after 4 years. I put in the spec battery for a 2013 Honda FIT, a 151R with 410 CCA. The new battery is just 19 lbs. net weight compared to the stock battery at 30 lbs and the terminal orientation is correct for the Twins.
I modified the existing hold down with two sections of 3/8" OD Aluminum rod just over 2" long. I drilled two 5/16" dia. holes in the front of the bracket and then drilled some 3/16" holes in the aluminum pegs. I used some self tapping screws to hold everything nice n tight. Total project cost was under $100.00. New juice and less filling! ! |
The Following 3 Users Say Thank You to Blue Gt For This Useful Post: |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
