03-04-2024, 08:30 AM | #211 | |
AutoX-10/10ths every run
With the traction mod in place, the distance between two mounting points is slightly different. The brace seemed to be designed to have a bit of room available _below_ where the normal trailing arm mount is located, but with the traction mod in place that area was occupied. I'll have to take a photo to illustrate, but I haven't gotten to do doing that yet.
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
The Following User Says Thank You to whataboutbob For This Useful Post: | norcalpb (03-04-2024) |
03-04-2024, 11:22 AM | #212 |
Drives: 2018 BRZ
Well, my impatience got to me, I ordered the GP Sports mod from RHDJapan. I figured even if the new MCA mod is excellent, it'll probably be quite a bit more expensive (judging by the cost of the V1) and potentially difficult to source.
The Following User Says Thank You to Ohio Enthusiast For This Useful Post: | norcalpb (03-04-2024) |
03-04-2024, 02:41 PM | #213 | ||
The Following 2 Users Say Thank You to norcalpb For This Useful Post: | Racecomp Engineering (03-04-2024), whataboutbob (03-04-2024) |
04-03-2024, 03:52 AM | #214 |
Drives: 2022 BRZ MT Ignition Red
Just ordered today; its back in stock
Now to figure out what I’m gonna do about ride height droop on stock 22 brz suspension (if it turns out as bad as some of y’all had noticed in your cars). |
The Following 3 Users Say Thank You to Subababarururu For This Useful Post: |
04-03-2024, 04:31 AM | #215 |
Drives: Toyota GT86
Thanks for the heads up. I wonder what’s different about the new version
SpareRoomRacing Youtube: https://www.youtube.com/@spareroomracing3168/featured Build Thread: https://www.ft86club.com/forums/showthread.php?t=153004
04-03-2024, 09:09 AM | #216 | |
- Andrew |
04-03-2024, 09:14 AM | #217 | |
https://mcasuspension.com/gt86-and-brz-traction-mod/
The Following User Says Thank You to whataboutbob For This Useful Post: | Racecomp Engineering (04-03-2024) |
04-03-2024, 10:39 AM | #218 |
Drives: 22 BRZ limited
Looks like they include a different subframe bolt and some bushings.
The Following User Says Thank You to dragoontwo For This Useful Post: | autoracer86 (04-03-2024) |
04-03-2024, 12:42 PM | #219 |
Drives: Toyota GT86
I think I am going to order one. Install seems easier than when I did the subframe bushings lol.
04-03-2024, 02:26 PM | #220 |
I ordered last night, will be sure to take photos but like others said looks like they revised the bushing slightly
Kyle H. - #89 STX
04-03-2024, 02:29 PM | #221 |
Wes
Anyone running this mod with Racecomp T2 coilovers?
Instagram: @gt86ws
04-03-2024, 02:46 PM | #222 |
The Following User Says Thank You to Racecomp Engineering For This Useful Post: | StraightOuttaCanadaEh (04-03-2024) |
04-03-2024, 03:21 PM | #223 |
Wes
Okay, I'm getting mine installed at the end of this month, maybe I should get this mod thing as well and do it at the same time.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Racecomp Engineering (04-03-2024) |
04-04-2024, 11:50 AM | #224 |
Drives: 17 Asphalt 86
Been eye balling these forever and might pull the trigger now. Is there need for an alignment installing these? Having one done soon
Is there notable improvement to ride quality? primarily street driven in my yellow/B6 setup. |
Similar Threads | ||||
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? | davidchoi | Cosmetic Modification (Interior/Exterior/Lighting) | 49 | 11-22-2014 10:17 PM |
"Clicking" or "knocking" caused by rear seat pull down lever. | husker741 | Issues | Warranty | Recalls / TSB | 6 | 11-27-2013 02:30 PM |
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") | levifig | BRZ First-Gen (2012+) -- General Topics | 48 | 08-09-2013 06:34 PM |
Factory suspension "sticktion" | andrew20195 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 04-02-2013 02:49 PM |
"Official" Suspension/Brake Thread | NYC BRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 27 | 06-27-2012 09:14 PM |
