Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
#43 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
However, if you have been as nice to them and professional as you have indicated, if I were on the other side of the desk, I would review costs associated and offer some sort of fix or replacement but caution strongly that modifications have chain effect impacts on other equipment that may not have been directly modified and that is purely a one-of and goodwill. Keep in mind guys, the dealers are not direct employees of Toyota. They are merely reps and they get comp'ed for the warranty work they do by Toyota. I don't know for a fact but I would bet that Toyota has a $$$ amount they allocate for warranty repair (eg: it should only take 1 hour to change a bad clutch thus only $xxx is allotted - anything more and you are eating the difference). That is why most reps don't like warranty work especially if they didn't even sell the car. I am not excusing them for the attitude but that's the pain they feel. I hear the same complaining every year when I meet with all our Canadian service dealers and they will always say the same thing year after year.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
The Following User Says Thank You to Frost For This Useful Post: | shiro (12-19-2013) |
#44 | |
Drives: 2013 Subaru BRZ
@shiro: Based on your video, that noise sounds like a faulty AVCS sprocket or a loose timing chain to me. It's too fast to be a bottom end knock. |
The Following User Says Thank You to andrew20195 For This Useful Post: | shiro (12-19-2013) |
#45 |
Good luck @shiro getting that fixed under warranty.
On a side note is there a chance that you may have dropped something into the intake while removing the turbo? A small nut or clip or anything will destroy an engine in just a few seconds if it makes it into the intake. I've seen engines come back that had damage to every cylinder from a single 10mm nut bouncing around inside the combustion chambers. |
#46 | |||
Drives: 2013 Scion FR-S, 2014 Lexus IS350
I contacted my dealership today on an update since the regional manager seen my car yesterday. The service manager basically told me that in order to press forward they will need to tear the engine down on my dime. Depending on what they find there is a very small possibility that Toyota would help cover any costs. My only concern is that the service manager continued to point out I made extensive modifications to the engine but he would not specify any of them except the timing chain. His conversation felt more like I was being talked down on kind of like being punished and saying, "you know what you did!" LOL, that exactly what he said too… Oh well, the integrity of that dealership has been lost. If I decide to pay a dealership to tear the engine down it will not be that one. Still corporate and I continue to play phone-tag for the last couple of days. It would be nice to talk to the regional manager directly… More to come later Quote:
#47 |
Guy on internet
Drives: Slowly
Didn't read through all 3 pages. I'm just gonna chime in.
1. Any kind of FI on your engine would likely get your warranty claim denied. It doesn't "void" it, in fact nothing "voids" your warranty. Warranty just doesn't cover damage caused by aftermarket components. 2. It's impossible to install the front cover upside down. The front cover covers the cam sprockets which control the VVT. 3. Tuners absolutely change ignition timing to make power. Not so much the Variable Vale Timing. Mechanics can observe the advancement percentange from each cam sensor and compare to another vehicle operating under the same condition to determine if the VVT is altered. Which is very unlikely since your engine does not run. An easy way to tell if an ECM had been modified is by checking the CID. If the ECM is confirmed altered, they can and often do deny any engine repair. 4. Sounds like the service manager is just trying to tell you that they won't be fixing it under warranty. He doesn't necessarily know exactly what had happened, all he knows is that the car was once turboed and tuned. I'm very surprised that Toyota had you remove the mods for diagnostic. IMHO, your engine is not covered. You run the risk of damaging your engine when you modify it, it's not fair to have someone else pay for your consequences. Now bite the bullet and build one that can take the turbo! ![]() |
The Following 2 Users Say Thank You to pche For This Useful Post: | shiro (12-20-2013), strat61caster (12-19-2013) |
#48 | |
The Following User Says Thank You to shiro For This Useful Post: | pche (12-20-2013) |
Tags |
avcs, dealership, engine issue, timing retard..litterally, vvt |
Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
Continuously Variable Transmission | Lexicon101 | Other Vehicles & General Automotive Discussions | 79 | 06-26-2015 03:18 AM |
Fuhumo valve and the dealership | Xdragonxb0i | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 17 | 03-31-2013 12:55 PM |
Valve Timing/Computer | miss paula | Issues | Warranty | Recalls / TSB | 3 | 09-20-2012 03:27 PM |
Rotrak variable supercharger | madfast | Other Vehicles & General Automotive Discussions | 10 | 01-28-2012 11:14 PM |
