08-06-2013, 09:25 PM | #43 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
is there any better aftermarket coil plugs?
i want to replace all 4
08-06-2013, 09:36 PM | #44 | |
Grip>Slip
08-06-2013, 09:37 PM | #45 | |
Love Boost!!!!!!!!
08-19-2013, 02:39 PM | #46 |
Dodging cones
Drives: 2013 BRZ Limited, 93 Z28
This hit me yesterday. I was running the car hard, shifted into second, looked down as the car seemed slightly sluggish to find a CEL. Taking it to Mastro Orlando tomorrow.
08-26-2013, 12:01 PM | #47 |
Got this morning on the way to work. Wot in 4th. No popping.
Running e85 with Visconti flex fuel kit. Cleared the code and did not come back the rest of the commute. Will try and reproduce it and switch back to pump and try again. Sent from a Motorola DynaTAC 8000X |
08-28-2013, 10:51 AM | #48 | |
08-28-2013, 02:37 PM | #49 |
Dodging cones
Mine hasn't returned, and mine went through 4 runs at an autocross (though mind you, it was ~10F cooler day at this autocross with 4 runs than the one with 6 runs I popped the CEL on)
The Following User Says Thank You to Kido1986 For This Useful Post: | Yruyur (08-28-2013) |
08-30-2013, 11:33 PM | #50 |
I got a data log tonight when the cel came back on tonight. Thought it would be interesting but didnt end up seeing anything that stood out.
08-31-2013, 12:29 AM | #51 |
Drives: A lot of supercars.
Mine used to come on until a toyota tech flew in and looked at it. Checked DI seals since ive had leaks before, coil packs and said nothing was wrong.. once I got my car back I haven't had the p0351 pop up once.. so odd. Seems to run smoother and quiter than normal though. Used to get a crackling sound from the bay in 1st gear WOT in high rpms once the engine warmed up each morning. That's all gone.
08-31-2013, 07:49 AM | #52 | |
Drives: 2013 Asphalt FR-S
~Namaste~ |
08-31-2013, 08:41 AM | #53 |
Bet they flashed.
09-01-2013, 05:53 PM | #54 |
I guess so. Just extremely happy its running perfect. Starting to Love driving it again.
09-04-2013, 08:10 PM | #55 |
Hadouken
Drives: Whiteout FR-S
Was driving in the high desert and heard some loud popping coming from the front of the car as I was getting off the Freeway. Got a CEL a few days later, and I pulled a P0351 off of it. It cleared itself after a few days. No CEL's or popping since, but not sure what if I should still take it in to get inspected or wait and see. So happy i got the extended warranty since I'm over the 37k
09-04-2013, 08:30 PM | #56 | |
Similar Threads | ||||
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
